400CX loader question
/ 400CX loader question #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
I have a 400CX loader on my tractor.
I see (in pictures) that the newer 400CX loaders have an added link between the booms and dipper arms (where the arms pivot). There is also a strut from that link to the mast. The link I'm asking about is in the red rectangle of the picture.
Is this part of the self leveling bucket, or is it something else altogether?
/ 400CX loader question #2
Yes, that is the star of the self leveling show. As the boom moves, that strut causing the bucket to pivot.
/ 400CX loader question #3
Arlen4720 is correct I have the 400x loader with out the self leveling jd used to have a video of this on their Web site maybe still there
/ 400CX loader question #4
Roy i believe that was always the difference with the 400 loaders... unlike the 300 where
the CX only designated higher/stronger lift.
the 400CX always had the self leveling ,, any chance you have
a 400x mislabeled?
/ 400CX loader question #5
If you aint got that part you aint got a 400CX you have a 400X
Does yours look like mine? The pics are my 400X
/ 400CX loader question #6
I will say though I THINK the self leveling parts and maybe the curl cylinders are the only differences, a dig around JD parts may confirm.
So it possible yours was / is a 400CX that for some reason the self leveling parts were removed or is a 400X that for some reason the masts have the 400CX stickers on them - mystery it is.
/ 400CX loader question #7
400X:
400CX
FYI, there are no serial number breaks listed in JDP for either loader so there is no "old" or "new" 400CX or 400x.
I do have a 400x...made a mistake when I first opened this thread.
It's pretty strong...especially considering the 73" bucket. The masts are looser then my 430 loader. There is an adjustment at the latches so I reckon I'll have to adjust them.
/ 400CX loader question #9
Cool. I tightened mine down since I do t ever take it off. Enjoy they are very nimble tractors for the amount of power you get.
/ 400CX loader question #10
Congrats on your new tractor, Roy! Do you still have your 4400? Oh yeah, cab and eHydro on this tractor? All that snow you folk's have been getting these past couple years must have tripped the "go bigger" switch, eh?
Regards,
AKfish
The load compensating springs in the loader masts also make the loader a bit, "loosey, floppy" - IMO.
/ 400CX loader question #11
I like to tighten mine down also. Pick the wheels up off the ground with the bucket, then tighten the jam bolts down tight. That will make it nice and solid.
Regards,
AKfish
I traded the 4400...got almost exactly what I paid for it, 4 years ago. It's still here waiting for the dealer to pick it up.
The 4520 has a power reverser transmission, not eHydro.
Wasn't so much the "Go Bigger" factor....it's the "Jeez!! It's Freakin' Cold" factor
How ya doing, AK?
Thank you for the tip!!
/ 400CX loader question #14
How ya doing, AK?
I hear ya on "freakin' cold"! I finally got a cab tractor... just over 4 years ago. Between my neighbors, the rural road to the highway, Post Office boxes, etc. after a big snow dump will take me 6-8 "tractor hours" to get everything cleaned up.
And 3 days after that to finally get warm again!
Doin' good Roy. Much better now... Still have a plate and 7 screws in my lower leg but I got the Doc to take out those 4 bolts! The heads were rubbin' bad with boots on. But, I can run, walk and skip! Yee Haa!
AKfish
/ 400CX loader question #15
What is everyone's opinion of reinforcing those struts, I bent both mine. I am thinking I hit a rock plowing snow and sprung them then when I went to lift up a log they just buckled! I have two new ones ordered for 140 each, dont need to do that again.. Here is my concern though, when I hit the rock I remember thinking dang, surprised I didnt break something. What I am thinking now is JD has those "struts" designed to give, possibly bend before you break something else and by over engineering them I am going to subject myself to a more catastrophic failure... On the other hand I dont need to be picking up a $4,ooo seed tote and have them buckle under the weight spilling seed
2019 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A69167)
2019 HINO 268 4X2...
NILFISK POWER WASHER (INOPERABLE) (A68842)
NILFISK POWER...
2013 PETERBILT 367 BODY LOAD NITROGEN TRUCK (A67714)
2013 PETERBILT 367...
2018 MAGNUS MINI VAC TRAILER (A67714)
2018 MAGNUS MINI...
Asphalt Roller Tire (A68134)
Asphalt Roller...
Unused 2023 Cross Tech Brushwolf Alpha XP 74in. Brush Cutter Skid Steer Attachment (A66734)
Unused 2023 Cross...
