Tiller Tractor HP vs implement rating
/ Tractor HP vs implement rating #1
intothefray2007
London, ON
Massey Ferguson 65
Hey guys,
So I have a 50HP MF65, and I'm working on 1.10m (approx. 42in) wide beds. Now I didn't realize this but not many implements are made to be that narrow while also being rated to work on tractors with this kind of horsepower.
So, my question is, can someone explain to me what the effects of using lower rated implements (say, a 20HP PTO rated rototiller) on a 50HP tractor?
Is the implement going to break right out of the gate, is it going to wear prematurely?... :confused:
Thanks!
/ Tractor HP vs implement rating #2
I wouldn't be too concerned about it for PTO implements. The Rating mostly tells you how much HP is needed to operate it. But having more power shouldn't affect it as long as you have a slip clutch that will do it's job.
Now for instance a plow or other pull type digging implements could be an issue since you would be able to bury it deeper and possibly overpower the construction intent.
Makes sense to me. I'm not too worried about the tiller since I'll be running that at a relatively low speed and no more than approx. 8 in deep.
I do have a tandem disc hoe for cultivating/weeding that I feel may wear out or break while hooked to the MF65. It's old, but in good shape. How can I tell what the hoe is rated at without having any information as to make, model, etc.? Is there a way to calculate that, or is it strictly based on construction design and materials?
/ Tractor HP vs implement rating #4
I wouldn't be concerned about a disk either as long as you aren't piling a bunch of extra weight on top of it to make it dig deeper than what it was designed for. They will only go as deep as the weight and soil conditions allow so having extra power pulling them should not be an issue.
/ Tractor HP vs implement rating #6
Do you have a cat I or II 3pt. If it is a Cat II you will need the bushings for the cat I pins on your implements, or you will damage the 3 PT bushings. Hope this helps
/ Tractor HP vs implement rating #7
Some of the 42 to 48 tillers I have looked at were Cat 0. Might consider getting a 60 or 72 and removing outer tines to get the desired width.
/ Tractor HP vs implement rating #8
I WOULD be concerned with it.
The HP ratings of PTO implements are NOT what is required to run it. The HP is based on the gearbox size of the implement as well as driveline size. IF you get into anything that works the tiller hard, your tractor has the power to keep running it and possibly destroying it. Never know when you may hit a large rock, or get tangled in some roots. And rather than stall the tractor you may destroy the tiller.
Now the tiller should have some type of protection, slip clutch or shear bolt that will help.
But IMO you need something rated for the tractor.
Befco T50, 50" tiller is rated for 50HP and has cat 4 driveline. Thats getting closer.
The tractor (MF65) has Cat I and so does the tiller, so no worries there.
Good point. However, I need a 42in width max based on how the beds are setup, and they just don't make those at that kind of HP. I think I'm willing to risk it based on the fact that I'm virtually stone/root/obstacle free. But I will definitely see if the tiller has a shear bolt or slip clutch as the specs don't explicitly mention either of those.
Short of getting a lower HP tractor, which I can't afford to do this year... :(
/ Tractor HP vs implement rating #11
No need to get a lower hp tractor unless you want to. You need to loosen the slip clutch up and allow it to slip to make sure it isn't stuck, then tighten it up to the point where it does not slip in normal use. This should be done every season after the unit has been stored. As was mentioned above this will limit the stress to the lower hp gear box. If you don't have a slip clutch I would install one, much cheaper than a new tiller or new tractor.
/ Tractor HP vs implement rating #12
My KK tiller has a type of slip clutch that has no springs to loosen off or tighten. I was told that it is preset to slip at the required tension and that I shouldn't do any adjusting on it. It does slip when a rock hangs up so I know it is working. There is nothing in the OEM book about checking it like you have to do with the ones with coil springs.
Just thought I should mention that in case his new tiller has this type of slip clutch. A properly working slip clutch will assure no damage is done to the tiller regardless of tractor HP>
/ Tractor HP vs implement rating #13
Why not just run at a lower rpm? Might not till as fast but would not make as much hp.
/ Tractor HP vs implement rating #14
The rpms' are not the concern as pto speeds for this sized equipment are 540 rpm whether 20 or 50 hp. The concern is the potential for much higher torque available in a stall with a higher hp tractor.
/ Tractor HP vs implement rating #15
Ok I was just thinking less hp and less torque at say 450 pto rpm instead of 540 pto rpm.
Tractor data has some spec sheets with hp and torque curves for most tractors so maybe the OP could see where in the curve his tractor makes less hp than the gear boxes limit. Then he could run the smaller equipment with less worry.
/ Tractor HP vs implement rating #16
I do see how the stall would not come till the gear box potential would break though.
/ Tractor HP vs implement rating #17
I use different rototillers and different HP tractors on a regular basis. The rule of thumb is that too much HP will quickly tear up a tiller. My setup is to use a tractor hp that matches or is a whisker less than called for. My equipment is well maintained but also used to the max and I often till trash, lots of rocks, clay drain tiles and things like that.
There are times when I may have to use a 75 hp tractor with a 50 hp tiller so I just back it off a bit by looking at the power curve for the tractor. I find the rpm speed where the hp matches what I need and stay close to it. So far, it's worked for me. I use higher dollar tillers and they can take more abuse but I would be more careful with short line things in a commercial application. Homeowner use is more forgiving, especially in good soil and worked carefully.
On the slip clutch thing, it is my understanding that manufacturers want them tested and recalibrated on an annual basis to make sure they slip when they are supposed to. I have never done that and don't know anyone that has for what it's worth. Just my two cents.
Good point, I was already thinking of running at a lower RPM if only to not completely destroy my soil structure. Tractor Data tested my engine and reports about 40 RPM at PTO, so that's good. However I couldn't find the torque vs HP graphs you mentioned on the MF65.
/ Tractor HP vs implement rating #19
If you adjust the slip clutch you can limit the forces applied to the gear box so it wouldn't matter which tractors you used. You can additionally vary your pto speed or adjust your travel speed as you see fit, separate issue from protecting the tiller, pto drive shaft and gear box.
The purpose of the slip clutch is to prevent excess torque overloading the implement and drive shaft. Reducing engine speed in some cases may increase the available torque and is not accurate or consistent enough to control. Also there is a big difference between the engines ability to produce the spec torque values and what is required in actual use to drive a given implement. You have to have the resistance to rotation in order to develop the maximum torque.
/ Tractor HP vs implement rating #20
Spot ON. :thumbsup:
In lieu of clutch, OEM shear bolt protection will suffice.
larry
Railroad Maintenance Machine (A61570)
Railroad...
2014 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR8EH765283 (A61165)
2014 International...
2019 Dodge Grand Caravan Van, VIN # 2C4RDGBG8KR553728 (A61165)
2019 Dodge Grand...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2018 Komatsu D61PX Crawler Tractor Dozer (A61567)
2018 Komatsu D61PX...
2009 Freightliner B2 Bus, VIN # 4UZABRDJ99CZ73715 (A61165)
2009 Freightliner...
