JD 5085/frontier sb3107
/ JD 5085/frontier sb3107 #1
Nube
Batik,NY
JD 5075
I need to hook up my JD 5085M with a good sickle bar mower. JD now uses Frontier for their sickle mowers. Their 3107 is their 7 foot model BUT is rated for tractorsup to 50 hp, my JD is 85.
Do I roll the dice with the Frontier OR look for something else? If something else what?
I will use the mower to cut along ponds, dikes, steep mounds about four times a year. And trim trees & brush on hiking trails (vertical cut) maybe twice a year
Will the higher HP of the tractor damage the sickle mower?
Your suggestions will be appreciared
Thanks
/ JD 5085/frontier sb3107 #2
no it won't damage it. The PTO is still spinning at 540 RPM
Sickle bar mowers don't require much HP.
/ JD 5085/frontier sb3107 #3
As long as there's a shearbolt or slipclutch ahead of the expensive parts of the sicklebar, I wouldn't think there'd be a problem.
/ JD 5085/frontier sb3107 #4
Ok, I gotta ask... Why a sickle-bar mower? The new price on the Frontier models I've looked at are just as expensive as a comparable brush-hog type.
And there's more upkeep and they're not near as rugged, either.
Is it 'cause you need the offset from the rear tire and/or the slopes you need to mow are short and steep?
AKfish
AKfish
Yes can't get close enough w bush hog without sliding into the ponds
/ JD 5085/frontier sb3107 #6
Have you looked at any offset flail mowers? I agree w/ ak about the upkeep and ruggedness of sickle-bar machines, not that flail mowers are any less expensive but they can sure take some abuse.
Yes, I have looked into the flail mower and the disc mowers. From what I could see the flail mowers are almost 4X the price of a sickle mower and the disc mowers are about2X . Both are out of my price range
/ JD 5085/frontier sb3107 #8
Nube,
Your statement about trimming trees and brush with a sickle bar mower vertically really caught my attention. Does this work for trimming "reasonably" sized brush? I've got 2 1/2 miles of access road to a cabin with varying amounts of brush along it, and have been looking for a good solution. The hydraulic orchard trimmer saws are kinda overkill.
Nube,
My understanding is that they will cut from 90 degree vertical to 45 degre below horizontal.
