Oil & Fuel Problem with starting JD 2305
/ Problem with starting JD 2305 #1
FloydB
Eugene, Oregon
John Deere 2305
When I last used the tractor (yesterday), ran fine. Today, went to start it and it ran for about 2 seconds then shut off like it was out of fuel. It has 7/8 tank of diesel. I primed the fuel pump and tried to start again. Same results. Have tried at least a dozen time and tractor will not stay running longer than one to two seconds.
/ Problem with starting JD 2305 #2
Drop fuel filter and see if there is water in the bowl. Change filter if there are a number of hours on this one.
Look for fuel blockage as well as check that the fuel shutoff solenoid is working.
:welcome: to TBN
/ Problem with starting JD 2305 #3
/ Problem with starting JD 2305 #4
:welcome:
To the forum. I sure wish that Oregon had beat OSU.
/ Problem with starting JD 2305 #5
mdd
They could have ... if.... :D
/ Problem with starting JD 2305 #6
Is the pto switch turned off?
/ Problem with starting JD 2305 #7
It's more likely to be the diode if it's start and dies almost immediately.
It was the PTO lever that was in-between positions. Easy fix to a dumb problem that I should have checked first. Thanks to all.
2019 John Deere R-4038 (A63118)
2019 John Deere...
1040 (A61165)
1040 (A61165)
2013 Ford F-150 Pickup Truck (A61568)
2013 Ford F-150...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
2025 BrushFox XHD-78HF 78in Hydraulic Rotary Brush Cutter Skid Steer Attachment (A61567)
2025 BrushFox...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A61567)
2023 Caterpillar...
