Case 444 Garden Tractor Hydraulic system help?
/ Case 444 Garden Tractor Hydraulic system help? #11
Looking at that drawing, I'd do it in the attachment lift cylinder circuit.
The second picture I posted, reminded me that the "Hydraulic PTO" on the back, is connected first inline after the pump. And there is an optional Flow Control valve available for extra slow ground speed when using the tiller.
And had a drawing of the transaxle.
Are you saying I can send the pump output to the loader before the Travel Control Valve (TVC) and then send it to the TVC by way of the power beyond port on the loader valve.
James
/ Case 444 Garden Tractor Hydraulic system help? #13
James
J.J. answered that in post#2
If you put the loader in front of the transmission, you may lose traction/mobility when using the loader.
You could install a divider valve and send 3 GPM to the loader and the rest to the drive.
I have a divider/priority valve on my steering and lift circuit.
The steering is primary, and the loader uses what is left over.
If not steering, the lift gets full flow.
The "drive" would be the TCV.
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
2016 Ford Fusion AWD Sedan (A59231)
2016 Ford Fusion...
2019 Kenworth T880 Tri-Axle Dump Truck (A59230)
2019 Kenworth T880...
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
iDrive TDS-2010H...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
