Idea for Backhoe Ripper
/ Idea for Backhoe Ripper #1
walker450
OK
M5040, BX25D, F2880, ZD1211, GR2120, KX-040-4
Has anyone seen or thought about having a serrated edge (front of back) on the ripper tooth? This way when you get to a big root that can't just be pulled out, you place the cutting edge along the root and push down with the full weight of the machine a few times, cutting the root. You wouldn't have to cut all the way through, just enough that the backhoe would break the root. Imagine a big sawzall blade on a backhoe.
I used an axe yesterday and that gets old... I'm taking my cordless sawzall today but that still requires getting off the machine to use it.
/ Idea for Backhoe Ripper #3
Thanks for that link, I have the DR ripper on my BX, & I was planning on grinding a knife edge on the front of it before the next time I used it to dig up a stump. Hadn't considered doing the back edge. Maybe serations on the back edge, & knife edge on the front?
It'll be a lot of grinding though, I believe its over 1" thick.
/ Idea for Backhoe Ripper #4
I'm interested in using the DR ripper on my bx as well. Were you able to use your existing pins or did you have to do something else?
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
ATTENTION PLEASE READ (A64126)
ATTENTION PLEASE...
2016 Ford Fusion Sedan (A61574)
2016 Ford Fusion...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
