BX 25 in 10ft dump trailer??
/ BX 25 in 10ft dump trailer?? #1
Newfiestang50
Does anyone know if a BX25 can fit in a 6x10 dump trailer. Some say it will with the backhoe turned and FEL hung out over the rear tailgate. I am buying a dump trailer but don't really want a 12 ft'er if I can get away with a 10. Any help would be great.
/ BX 25 in 10ft dump trailer?? #2
I just went through this, purchased a new dump trailer and new BX25. I thought I wanted a 12' dump but went with a 14, absolutely glad I did. Even with the 14', there's not much room after closing the rear gate. I have no doubt that the BX25 with BH can go in the 10' trailer, however I believe the issue is that there is no room for movement to get the proper weight distribution and you'll end up with a load that rear-biased which can be dangerous.
/ BX 25 in 10ft dump trailer?? #4
Not a dump and not a bx25 but similar sized tractor in a 10 foot trailer
with so much wieght hanging off the back I drive up as far forward as possible
/ BX 25 in 10ft dump trailer?? #5
A BX25 weighs close to 3k lbs. I would never put it on a tiny single axle trailer, and seeing the pic 2 posts above with it on a 10' dump trailer, I think the OP would be sorry in the long run trying to squeeze it on a 10' dump trailer. A 12' or preferably 14' is best keeping everything inside and room to move and balance. Here are some pics of me bring my BX home in December on a 14' trailer. I had a LandPride grapple on the Kubota and the bucket loaded separately behind it (took up no length as it was under the BH. The grapple was within a few inches from the front of the trailer. Good luck...
/ BX 25 in 10ft dump trailer?? #6
omg my trailer doesn't have brakes either ! everyone's gonna die !!!!
/ BX 25 in 10ft dump trailer?? #7
It looks like you need one of those roadside education class's that law enforcement offers.$$$$$$$$$$
/ BX 25 in 10ft dump trailer?? #8
That is pretty scary especially with no brakes. I have a hard time believing that trailer is even rated for the load. I would change your set up if that goes off your property. Just my :2cents:
/ BX 25 in 10ft dump trailer?? #9
Looks like a 2000# axle under it with tires that are rated for 1800# (if that)...
Aaron Z
/ BX 25 in 10ft dump trailer?? #10
Hope the input so far has helped you make the decision to NOT do a 10' trailer. Weight, distribution, safety, convenience, adaptability, etc. I'd suggest the 14' dual axle if you can afford it. I have a 12' dual axle and a 16' dual axle myself. I'll use my new with brakes that I don't have hooked up 16' to move my tractors and the 12" for rock, dirt, gravel, lumber, loaning to family.:)
/ BX 25 in 10ft dump trailer?? #11
This is a well built trailer from c channel and tubing not your run of the mill home depot angle iron trailer. It has 10 ply tires and its use is limited to driving about a half hour at the most on back roads (50mph). It's incredible how far a little bit of common sense can go
12' is what I was thinking however I like the 10' for two reasons, its just smaller and will suit my needs just fine. The other thing is that I am having trouble finding a 12' one that is rated for 5 tonne. Where I live once you go to 6 tonne it has to be licensed as a commercial trailer which means commercial inspection yearly plus 5 times the license fee. These are the main reasons I am looking/preferring a 10'er.
/ BX 25 in 10ft dump trailer?? #13
Heck, I put my BX 25 on a 5 x 10 trailer, and I upgraded the axle to 3500 pound axle, with electric brakes. The front end loader stucco over to the front and was held down just behind the Craig, and the backhoe stuck out over the back. Only used it in emergencies, maybe two or three times. Then I got a great deal on a 7000 pound flat deck trailer with the beavertail and lovely ramps. It was an 18 footer, so now I have lots of room for everything. And, with brakes on both axles, it is a lot safer, too.
Even so, if I really had to, I could always take the front end loader off and the backhoe off and put the tractor in the old 5 x 10, for example, if I want to take it in for some service on the main part of the tractor. The tractor itself only weighs about 1500 pounds.
/ BX 25 in 10ft dump trailer?? #14
Why do you need a 10,000 lb trailer (muchless a 12,000 lb) to haul a 3,000 lb tractor? Or are you saying that every 12 footer just comes rated at 12,000 lb and you want to avoid that?
/ BX 25 in 10ft dump trailer?? #16
must be a canadian thing :thumbsup:
/ BX 25 in 10ft dump trailer?? #17
OP stated he wanted a dump trailer. Many 12' dumps are rated at 12k lbs, 14' are 14k lbs, etc.
/ BX 25 in 10ft dump trailer?? #18
Ive had no issues with a 10' dump trailer and the BX. The truck is only a 1/2 ton so I didn't want to go with a larger trailer.
/ BX 25 in 10ft dump trailer?? #19
Greetings 4shorts, have you had occasion to trailer your BX25 with both the front bucket ..and.. grapple? If so, how do you transport both? Perhaps lift one into your truck bed? Thanks, John
/ BX 25 in 10ft dump trailer?? #20
Common sense would tell us not to use under rated 4 lug axles to haul this much weight, no matter the distance.
3015 (A56857)
3015 (A56857)
2008 Ford F-250 Pickup Truck (A61573)
2008 Ford F-250...
2015 Ford Transit Connect Cargo Van (A61573)
2015 Ford Transit...
2010 INTERNATIONAL PROSTAR PREMIUM ROAD TRACTOR (A63291)
2010 INTERNATIONAL...
JOHN DEERE 460M SILAGE BALER (A63291)
JOHN DEERE 460M...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
