One light with two INDEPENDENT switches
/ One light with two INDEPENDENT switches #1
RSKY
Elite Member
Kentucky, West of the Lakes, South of Possum Trot.
Kioti CK20S
I cannot find a wiring diagram anywhere for this. I want to wire a light to come on by the entry door when a garage door opener activates. There are two openers in the garage. Is this possible without causing problems?
Thanks for your input.
RSKY
/ One light with two INDEPENDENT switches #2
I think that just requires a 3-way switch on each opener.
Diagrams here:
Wire-3-way-switches
Bruce
/ One light with two INDEPENDENT switches #3
Do I understand that you want a light to go on when either, or both, of two garage doors openers is activated?
First question: do the garage doors have an output to an external light? Assuming they do, the answer depends on how that output is configured, and how the openers are wired. In the best case, if the outputs are electrically isolated, and the two openers are on the same leg of the electrical service, you can just run a wire from both outputs to the light, either one will light the light and having one on when the other is off or having both on at the same time. You can determine this using a voltmeter.
If the two openers are not on the same leg, when both are on the voltage of one will be the negative of the other, and the difference between them will be twice your line voltage (ie 220V). You can test this by turning both on and measuring the voltage between them with a voltmeter, if it is anything other than zero you have a problem. You might be able to solve this by having an electrician move one to a different leg.
If the opener outputs are not electrically isolated, when one is on and the other is off electricity will flow from the one that is on to the one that is off. You can test this by turning one on and the other off, and measuring the voltage. If it's anything other than zero you have a problem.
In summary: measure the voltage between the two outputs using a voltmeter in every possible configuration: both off, each one on with the other off, both on. If it is anything other than zero in any configuration, you have a problem. If it is always zero you can just connect the two outputs together and to the light.
If the simple connection isn't possible, there are other ways to do it but it requires using relays. We can cover that in another posting if necessary.
/ One light with two INDEPENDENT switches #5
Another way to solve your problem might be one of the motion detector light fixtures??
/ One light with two INDEPENDENT switches #6
If I understand correctly, what you'd like is an inside indicator light to alert you to an open garage door, correct? If so, I'd use the same type circuit that a dome light uses, and have the ground tied to the closed limit switches on the openers. That way you would be alerted to an open condition even if the door is open partially.
Our garage has two doors and two openers. We usually close the garage door and walk into the house thru a door in the center back wall of the garage. The lights on the openers are on their front and so the back of the garage is always gloomy if not completely dark. I want to put a single fixture over this door that lights with the garage door lights and goes out with them. I would probably be better off getting two cheap fixtures side by side wired to each opener. RSKY
/ One light with two INDEPENDENT switches #8
I think it could be safely done with a low voltage circuit triggering a relay to operate the light. You could install a alarm contact/reed switch next to each door with a magnet on the door(s) to trigger the relay.
/ One light with two INDEPENDENT switches #9
I would put in two small spot lights tied directly to the garage door openers LIGHT that exists now, point the spot lights where you want them.
Mark
/ One light with two INDEPENDENT switches #10
Like this:
/ One light with two INDEPENDENT switches #11
Mark
That would absolutely be the simplest way.
/ One light with two INDEPENDENT switches #14
In our neighborhood, I'd bet they'd do it like this....
Unscrew a light bulb from the opener.
Put it one of these...
Then one of these strung across the ceiling with staples through a hole knocked in the wall with a sledge hammer...
What's wrong with that???
:confused3:
/ One light with two INDEPENDENT switches #15
/ One light with two INDEPENDENT switches #16
Well, if you put one of these adapters: Leviton 1403 Two Outlet Socket Adapter, Black - Light Sockets - Amazon.com (or one of the adapters MossRoad linked to) in the socket, you could power a LED spotlight such as: WoneNice LED Spotlight Flood Light 10w Garden Outdoor Ip65 Waterproof Floodlight Warm White (3000k-3500k) - Silver - - Amazon.com to light up the area.
Aaron Z
In all seriousness, that's probably the easiest way to do it. However, he'd have to duplicate the setup, as he wants to have it work for either opener. So, double the cost and he'd have to have two lights mounted next to each other. It would look kind of odd.
If it were me.... I'd use an X10 powerflash module, a magnetic switch on the door, and an x10 wall switch to control the outdoor light. Wham, bam, thank you OW MY EYES, THAT LIGHT IS BRIGHT!!! ;)
Install a floodlight.
Wire it for a regular wall switch, but:
Install this higher powered X10 wall switch.
X10 XPS3-IW WS13A High-Wattage 20A Relay Switch
Plug in an X10 power flash module to an existing wall outlet in the garage.
X10 PSC01 X10 Powerflash Interface
Install this wide gap magnetic switch on the garage door and wire it to the power flash module with garage door opener switch wire.
SECO-LARM SM-216Q/GY Wide Gap Magnetic Contact - Gray
If he has two (or three, or four) garage doors, just add another magnetic switch to each door. They all can be connected to the same power flash module. If any of the doors are opened, the light will turn on.
/ One light with two INDEPENDENT switches #17
On a related note.... he could also put an X10 outlet in his house with a night light plugged into it. If someone leaves any of the garage doors open, the night light will be on. Doors close, the night light goes out. I'm going to do this myself, as for the past 18 years, our car has been kept outside. I finally cleaned my garage and got the car inside for the winter. However, we keep forgetting to close the garage door from the house, and its not easily seen from the house. So, this will be a cheap way for us to see with a nightlight in the kitchen. ;)
