hydraulic wing snow pusher
/ hydraulic wing snow pusher #1
toxic
PEI, Canada
Kubota m7060 , John Deere 4200, Kubota ZD 326 & ZD 21
I've been wanting to build something like this for a while and after finally being able to use my new M7060 on Sunday moving snow I decided now was the time. I move snow commercially at 85 places ranging from small single car driveways to commercial parking lots of 1-2 acres and have been looking for something to speed up the process. As well as the new tractor worked it was pretty frustrating having so much traction and hp but only a 6 foot bucket to clear the large areas. So yesterday I started building a snow pusher. The main mold board is 34" high and 7 feet wide. Attached to each side is going to be 30" wings that are hydraulically adjusted 180 degrees. Hope to have this done in the next couple of days and i will post pics as work progresses.
/ hydraulic wing snow pusher #2
Are you going to have it trip, or use a rubber edge? We have a HLA Snowwing at work (HLA Snow) and the guys who use it love it.
Aaron Z
Aaron Z
Neither. Making it a fixed steel edge, Simple and effective as long as the operator is careful. I have used rubber edge pushers before and was very disappointed with there performance so it was never even considered. I have always just used buckets for snow removal which obviously don't have any trip mechanism so that is my reasoning for make the blade that way.
Bit more progress this afternoon until I ran out of .030 wire in my mig so I called it a day. Hopefully get the wings attached tomorrow.
/ hydraulic wing snow pusher #7
Nice, I look forward to the "wings" design, I'd like to attach "one" on mine and have it removable from side to side to push back snow banks etc.
/ hydraulic wing snow pusher #8
Funny, I was just looking at my plow blade yesterday and this idea came to mind. Pondered for a while about how I would go about it. I also didn't know that there were commercially available ones. I thought i was so creative for thinking of it... :laughing:
Little bit of progress this morning. Hopefully my steel guy can get the material cut for the wings and hinge this afternoon. 20150107_122526.jpg
Side view. I was trying to keep it as close to the tractor as possible. 20150107_122612.jpg
Finally got the rest of the material I need for this project. Had to wait a few days for the 400F Cutting edge to come in is why I've been held up. So I got to work this afternoon and got one side wing attached. The other side should be a cinch now so I'll get it on in the morning then get to work making them swing hydraulically.
The sides a way overkill but that's better than too weak i guess. 32" high by 30" deep 3/8 steel plate and the cutting edge is 6" ラ1/2 hardened steel. The hinge is 3/4" rod inside 3/8" wall tubing.
Here is one side mounted.
/ hydraulic wing snow pusher #14
Beautiful.....:thumbsup:
I'd like to see what you do to "hold' it in place.
/ hydraulic wing snow pusher #15
looks good!
A friendly suggestion; maybe bevel the front edge of the wing so that it doesn't want to dig in.
Or use a flexible edge for the wing part?
I used aluminum on my rear blade wings with bolts and slots so that it can follow the surface contour while still cleaning well.
Sent from my iPhone 5s 64Gb using TractorByNet
/ hydraulic wing snow pusher #16
Nice work! I'm thinking about building a pusher for my Cat 246 skid steer.I have a few commercial accounts.I have An 8ft fisher plow...was thinking of adding a pivot and 2 ft wings to get an 8ft pusher or 12 ft straight plow....
Been busy lately but managed make a bit of progress yesterday. Pretty much have one side buttoned up. Other side should be a snap now that i have a template.
/ hydraulic wing snow pusher #19
looks good!
Bit more progress this afternoon. Got the hinges done on both sides. All that's left is to add some gussets and finish welding everything. Hopefully it'll see primer tomorrow afternoon.
JOHN DEERE 9420R ARTICULATING TRACTOR (A65057)
JOHN DEERE 9420R...
MAC FLAMELESS HEATER (INOPERABLE) (A68842)
MAC FLAMELESS...
2018 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A67714)
2018 INTERNATIONAL...
110 GAL WATER TANK (A68842)
110 GAL WATER TANK...
2016 MAGNUM  MLT6S (A68842)
2016 MAGNUM MLT6S...
2011 SHBO MANIFOLD TRAILER (A67714)
2011 SHBO MANIFOLD...
