Gas leak
/ Gas leak #1
NCMau
Gold Member
NC
MF 202/Ford 8N
Can JB Weld be successfully used to fix a small leak in a gas tank, or is there beside welding, a better product available?
/ Gas leak #2
There are some two part putties that are better, autoparts stores have them. There is a other product that is similar to silicone but drys hard. I forget the name of it but it is in a red & yellow tube in the epoxy area & states gas tanks on it.
Mark
/ Gas leak #3
Mark
SealAll fixed a plastic gas tank on a generator with it!
/ Gas leak #4
Seal-All is good stuff. A plastic tank is tough to fix though. A lot of puttys and sealers don't like to stick to it. Sometimes a soldering iron will melt a crack back together.
/ Gas leak #5
The rubber piece were the cut off goes into the tank was cracked, not the tank! I fixed it for my uncle, he didn't want to spend $25.00 on a piece of rubber & plastic cut off!
/ Gas leak #6
Yes it can, there are different types of JB weld also.
/ Gas leak
Thank you all for the inputs. I'm more educated now!
/ Gas leak #8
Plastic tank or metal? I poked a piece of 1/2in rebar thru my tn75 fuel tank once. I had already replaced the tank before and I didnt like the thoughts of buying yet another. I went to the scrap yard and cut off a piece from a plastic car gas tank. I then took a large soldiering iron and started just heating around the hole until it turned shiny and sticky. I then would push the piece of plastic into the hole with the hot soldering iron. I was able to compeletly seal up the hole. I used the iron just like a acet torch and the extra piece of plastic was my filler rod. It was slow go, but the tank never leaked. Lots of videos on youtube showing plastic welding.
/ Gas leak #9
Id be afraid the gas or fumes would ignite in the tank, a soldering iron and gas fumes don't coincide, not saying it wouldn't work but I wouldn't want to do it, I'd get some jB weld waterweld, it's impervious to gas or diesel and works pretty good, bound to be safer than anything with heat!
/ Gas leak #11
I've heard of clean tanks blowing! Air pocket of fumes, one guy on here blowed his fingers off!
/ Gas leak #12
Need to leave the cap off.
An even better way is keeping a steady flow of high volume low pressure air through it to blow away any "pockets" of fumes.
Sent from my iPhone 5s 64Gb using TractorByNet
/ Gas leak #13
FILL IT UP COMPLETELY with soapy water. I have soldered Gravely tanks many times using that method. We are talking just a small tank you can pick up and inspect, not a large automotive tank. Fill it up and then shake it around, dump it out and let it dry out. If you pick it up and stick your nose in there and it doesn't smell like gas, you will be good to go.
/ Gas leak #14
My 10.5 hp Briggs on the wood splitter was a target of some varmint and got chewed on. The fuel tank had a dime sized hole in it. I tried my best with fuel safe epoxy and it lasted about 2 years. I then removed the tank, washed it out with soap, and welded it up with a soldering gun. I used strips cut from oil jugs as my filler rod. It worked great and has held up for about 4 years. A new tank would have been about $80.
/ Gas leak #15
I used JB Weld many years ago to fix a leaking crack in the plastic fuel (diesel) tank on my B7100, only because the dealer did not have a new tank in stock and I didn't want to wait. It lasted a year before it started to leak again.:laughing:
New/Unused Landhonor Mini Grapple Bucket (A65583)
New/Unused...
East Texas Gooseneck Trailer (A65563)
East Texas...
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
