Nomad welding table advice
/ Nomad welding table advice
Eric, I'm pretty sure you'll get a lot of use out of those - just a word of caution though, I wouldn't recommend wasting your money on HF's excuse for F-style welding clamps - I bought a couple when they were on sale just to try out, ended up using 'em for temporary paper towel holders :rolleyes: Instead, for not a lot more money the Stronghand clamps (1200 pound rated) have worked really well for me - they come with pipe adapter and a "step over" spacer, can be reversed to use as a spreader, and cost about HALF what a plain Wilton costs - I have a couple of the Wiltons, and only use 'em when I run out of the Stronghand ones. Here's where I get mine, the 8" 1200 pound ones are often on sale for around $20 - Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies HTH... Steve Here's one project where I needed nearly every clamp I had - if you click the "+" sign, the two overpriced Wilton's are in the upper left corner (with the copper plated lead screws)
Thanks for the lead.
Have several from TSC that have copper plates screws seem pretty good overal.
Sent from my iPhone 5s 64Gb using TractorByNet
/ Nomad welding table advice #22
Thanks for the lead. Have several from TSC that have copper plates screws seem pretty good overal. Sent from my iPhone 5s 64Gb using TractorByNet
Eric, how do you make your TSC purchases? Online or cross border shopping?
Terry
Eric, how do you make your TSC purchases? Online or cross border shopping? Terry
well TSC purchases are in Canada and Tractor Supply Co purchases are made cross border in store or online ship to store.
Just depends which is the best deal with the %16 exchange rate!
/ Nomad welding table advice #24
well TSC purchases are in Canada and Tractor Supply Co purchases are made cross border in store or online ship to store. Just depends which is the best deal with the %16 exchange rate! Sent from my iPhone 5s 64Gb using TractorByNet
Oh. You have TSC stores in Ontario?
Terry
Oh. You have TSC stores in Ontario? Terry
yes it's a subtle difference but like I said
Usa Tractor Supply Co
Can TSC
Can do online shopping for both and ship to store for both
Thanks
/ Nomad welding table advice #26
..... for not a lot more money the Stronghand clamps (1200 pound rated) have worked really well for me - they come with pipe adapter and a "step over" spacer, can be reversed to use as a spreader, and cost about HALF what a plain Wilton costs - .....
I have to agree about those clamps. A great tool, and a great value from ENCO. The V pad is a must if you work with tube and pipe.
/ Nomad welding table advice #27
Can TSC
Thanks
Still not sure if you mean that Tractor Supply Co ships to TSC. If so, do they charge for across the border shipping?
/ Nomad welding table advice #28
yes it's a subtle difference but like I said Usa Tractor Supply Co Can TSC Can do online shopping for both and ship to store for both Thanks Sent from my iPhone 5s 64Gb using TractorByNet
Thanks for clarifying, Eric. I see that they only have stores in Manitoba and Ontario.
Terry
No
Tractor Supply Co is usa based and does not ship cross border to TSC.
I was letting members know that where not aware that TSC and Tractor Supply Co are virtually the same stores-for those who did not know that. Different names for Can/USA although very similar.
Hope this helps
A bit of a story here but here goes;
Was trying to order the tables online the other day and had issues. Msg popped up call this 1-800 number as we are having trouble processing your order.
Called and told the girl I had a %25 off coupon single item.
Told her I wanted 2 tables. Was on hold for a minute.
She gave me both tables %25 off shipped together for $6.99 sweet!
/ Nomad welding table advice #31
A bit of a story here but here goes; Was trying to order the tables online the other day and had issues. Msg popped up call this 1-800 number as we are having trouble processing your order. Called and told the girl I had a %25 off coupon single item. Told her I wanted 2 tables. Was on hold for a minute. She gave me both tables %25 off shipped together for $6.99 sweet! Sent from my iPhone 5s 64Gb using TractorByNet
Nice!
Sent from my iPad using TractorByNet
Got my tables in after a shipping error. Physical US address I used previously would not accept the Fed Ex shipment therefore I had to Waite a few more days to pick them up. Very easy assembly and very impressed overall with the quality of the chicago Electric tables. Thanks to all that replied and steered me in the cheaper direction! I realize I cannot beat on these tables but it is what it is until I can build my 4x5 table with 5/8 plate. Here is a few pictures I took.Sent from my iPhone 5s 64Gb using TractorByNet
/ Nomad welding table advice #33
Is that a Harbor Freight table ir Tractor Supply? I need a small table that I can modify to store flat when not in use. Thanks
harbor freight. Got em for $59.95 each and $6.99 shipping.
/ Nomad welding table advice #35
I just ordered three of them online at the $59 price, $6.99 shipping. Both of the local stores were sold out. I am getting ready to build a grapple and I don't want to do it on the floor. They will make good tool stands and movable work tables when not needed for welding.
/ Nomad welding table advice #36
Yeah I think I will get a second one and make a quick connect feature for longer work. Looking forward to your grapple project!
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63689)
PENDING SELLER...
WESTENDORF 12' LANDSCAPER BOX GRADER (A63291)
WESTENDORF 12'...
UNUSED WOLVERINE 44" HYD MINI STUMP GRAPPLE (A64281)
UNUSED WOLVERINE...
2019 Forest River R-Pod RP-191 Travel Trailer (A61574)
2019 Forest River...
2023 Case TV450B (A62177)
2023 Case TV450B...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
