Black pipe or galvanized for shop air lines?
/ Black pipe or galvanized for shop air lines? #161
Can somebody please explain about the tee pointing up. I think I will have my line overhead and pointing tees up seems awkward to plumb.
If your line is overhead and the lines come straight down, any moisture will drain to your service connection. If you are running flush to the ceiling, put a drip leg in your takeoffs with a drain valve.
/ Black pipe or galvanized for shop air lines? #163
In our commercial shop that I ran in 1.5" black threaded with 1" drops, I didn't come off with an inverted tee and elbows to attain a vertical down, I just added a WOG valve below each drop termination (with a 12" drip leg) to drain off moisture. Cheaper than all the fittings. Works fine.
/ Black pipe or galvanized for shop air lines? #164
Over 30 years ago we installed over 200 feet of 3/4" pvc for airlines surface mounted in our shop. Have had various breaks caused by items falling against it. Had one employee hang about 100 pounds of tools and parts from hooks he made to fit over the pvc. No flying pieces anywhere, the worst required a 4 inch repair to repressurize to 175#. Shop was sold 10 years ago, current owner is still using same pvc for air. In use 24/7 since 1977, currently on at least 3rd compressor.
/ Black pipe or galvanized for shop air lines? #165
Water and debris destroy tools. That is why, if you are serious, you need to invest in a drier.
Clean, dry air= happy tools, and quality paint jobs.
And, yes it is possible.
I agree 100%
/ Black pipe or galvanized for shop air lines? #166
If I ever make one again I will definitely use the PVC or PEX and not metal. Mine is all 3/4 copper with a 6' rise from the tank and 2 drain drops. They get a lot of the water yet plenty still makes it to the tools if I work it hard. My next trick is going to be making a drier that I can mount on the tank. Until then I just give the couple good air tools I have another shot or oil and a trigger pull before I put them away. For some reason my crappy HF tools just keep ticking away in the same half assed fashion they did when new no matter how bad I treat them. It certainly doesn't look very difficult to fab up a condenser and an automatic fan to dump that moisture into another vessel rather than just dumping it into the tank to condense.
/ Black pipe or galvanized for shop air lines? #167
You will be following BAD advise to use PVC.
Sure, many have and have not had any issues.
But there are FAR better alternatives that arent really any more expensive than PVC these days
/ Black pipe or galvanized for shop air lines? #168
If you use pvc, use SCH80 pipe and fittings. It's not cheap.
A better system is nylon air line, this is what it was designed for. Like the Northern Tools kit as mentioned previously. This kit uses the fittings and line, that's used in truck air brakes. It will expand and contract some in length with extreme temp changes. So alow for this when installing.
Dave
/ Black pipe or galvanized for shop air lines? #169
DO NOT use PVC for compressed air. There is a reason you can't legally use it in commercial applications were it's exposed. I know the reasons are lost in this very long thread, but it looks like we need to repeat it. Use anything you want EXCEPT PVC pipe.
/ Black pipe or galvanized for shop air lines? #170
PVC pipe has always been officially not advised for air lines. I even had to convince my
building dept to allow me to do a pressure test on my 4-in PVC water main using
air, rather than water.
Now that said, not all PVC is the same. PVC hoses, unlike PVC pipe, are fiber-reinforced and
designed for use with compressed air. I love my PVC hoses: cheap, flexible, easy to install,
no corrosion issues, almost no fittings.
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
CFG Industrial MX12RX (A60463)
CFG Industrial...
2007 Volvo VNL Truck Tractor (A61307)
2007 Volvo VNL...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
Richardton 960 (A60462)
Richardton 960...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
