Help me insulate my pole barn
/ Help me insulate my pole barn #1
NonTypicalCPA
SW Michigan
Kubota L3940
After 10 years the gas company has finally run natural gas on my private drive, so I'm going to add a furnace and heat my pole barn - 30x40x12. Problem is it isn't insulated, except I planned ahead when I built and put in insulated doors. I want to tackle this project myself. If I start with the ceiling how should I proceed? Currently it's open rafters. Can I just add a rigid foam board type on top of the rafters? Or should I add a sheeting to the bottom side of the rafters and blow in or roll in insulation on top of the sheeting?
/ Help me insulate my pole barn #2
What size is the truss spacing?
The problem with the rigid insulation is that it gets pretty expensive. Since you lose the most heat through the ceiling/roof, you want the highest R-value possible in the ceiling, and that means going with the 2" thick stuff (R10) which will cost you something north of $1250 (going off normal Lowes/Home Depot pricing).
Mine has 4' truss spacing, and my neighbor gave me a big pile of 4' wide insulation rolls from a demolition project he did a while back (sound studio). I secured them with twine and some 1"x1" wood slats. I'm going to cover it with steel panels, and then blow insulation over the top. The steel panels will run me about $650 at Menards (best price I've found so far).
This is what it looks like now that it's hung, and the partition is up and insulated....it'll be a while before I get to sheeting it in steel. I'll probably add a vapor barrier as well (I already have the material left over).
/ Help me insulate my pole barn #3
You probably will need some sort of hard sheeting. The roof above should be ventilated somehow, and all it takes is a gust of wind when you open one of the big doors to "blow out" the foam sheeting. It will probably move and squeak each time someone opens and closes a small personnel door also.
/ Help me insulate my pole barn #4
Regardless of what you do about insulation you might want to look into overhead radiant heaters. They do a better job of heating areas with high ceilings than trying to heat the air.
Space Ray
/ Help me insulate my pole barn #5
I haven't checked this out myself but was told that a do it yourself kit for sprayed on foam insulation was very little more money than fiberglass bat insulation. I googled it and there are lots of kits but I didn't go to the next step of comparing prices. If I ever insulate my storage this is probably the way I would go.
/ Help me insulate my pole barn #6
I second the spray foam. It will fillr all voids that any other insulation can not get to.
/ Help me insulate my pole barn #7
The problem with spray foam is you have to have something to spray it on. If you insulate the underside of the roofing, you have just that much more overhead space for all the heat to go into. I think a ceiling (liner panel) over a vapor barrier with lots of cellulose blown in on top of it is the most cost effective way to go.
Spray foam makes more sense in the walls to me. Of course there are lots of other options there also.
/ Help me insulate my pole barn #8
I want to do my garage also. Besides the insulation keeping the temp more stable, I can paint the hard ceiling white and that gives a lot more light to work by underneath.
I definitely need to add the ceiling then insulate, I have gable vents in the peaks. I was thinking spray insulation in the walls, but I would probably hire that out and I'd like to make this a do-it-myself project. My father in law spray foamed his shed and loves it, but his pockets are deeper than mine. I'm going to get a quote just to find out the cost.
Thanks for the link Mendonsy, I was planning on looking into that type of heater, but wasn't to that point yet. Any idea how much they cost compared to a forced air unit?
/ Help me insulate my pole barn #10
As I have advised a number of times, bite the bullet and use prefinished white metal liner panel for the ceiling. It weighs less so you don't add as much load to your trusses and it eliminates painting for the next 40 or 50 years. Plus it looks a lot better than any kind of plywood, OSB, drywall etc.
That's what I'd really like to do. Will have to price it out.
Where are you located in SW Michigan? I'm in Paw Paw.
/ Help me insulate my pole barn #12
That's what I'm doing for my shop. To cover a 24x40' section of ceiling worked out to $650 from Menards (haven't bought it yet). I'll have the metal liner, then the insulation already in place, then I'll blow insulation on top of it all...should be more than enough.
/ Help me insulate my pole barn #13
I don't have any real solid numbers for you, but a couple of the places that I work with have installed them. They both think that they are great. I suspect the unit is a bit more than a similar size forced air unit but there isn't any cost for ductwork so it probably comes out about even.
/ Help me insulate my pole barn #14
I agree. I also agree with Kenny concerning blown in insulation on top of the metal liner. It's the cheapest system you can install. You can also add R value at whatever pace your budget will allow by simply blowing in more insulation. This system also minimizes the cubic feet of space you have to heat.
/ Help me insulate my pole barn #15
Near me is an Amish community. One of the businesses is a metal fabrication business. I bought 2500 sq ft of white metal liner panel for $1450.
Looks like our local Menards would run about $750 for a 30x40. Any tricks to install it? I hate working over my head.
/ Help me insulate my pole barn #17
Wheeled scaffolding or an FEL. Plenty of help. Patience and diligence.
/ Help me insulate my pole barn #18
Find a friend with one of these....makes life way easier! I bought this for $1K, added $250 worth of batteries, and I'll make money when I sell it, but I may think about renting it out a few times to see if it can pay for itself.
Assuming you don't have a friend with one, they aren't that expensive to rent for a day, and you can almost certainly do your whole ceiling in a day using one. I've been using mine to run electrical wires, hang lights, build the partition wall, etc and it makes things way faster. You can put a whole sheet on one, raise it up into the general position, tweak it by hand, and hit it with the cordless screwdriver....done.
/ Help me insulate my pole barn #19
I installed my pole barn ceiling (40 x 48 with 12 foot ceiling) essentially by myself. I got a high lift drywall lift and I have two rolling bakers scaffold units. There was a lot of climbing up and down but nothing that hard to do. Other people have done things like build a platform on the back of a truck.
Did we ever find out what the truss spacing is? Liner panels are rated for 4 foot spans. Anything larger will require some added structure.
My recommendation would be to first frame in attic access holes. Then install a vapor barrier (about 6 mil) under the trusses. Then the metal goes on and finally blow in the insulation. I installed wiring and outlet boxes for hanging lights before I installed the ceiling. I would not do that again. It caused a lot of extra work in cutting the outlet access through the metal panels. If I were doing it again I would complete the installation and then run conduit under the ceiling surface for the lights.
CPA, I'm not that far from you (St. Joe). I've been thinking about selling my drywall lift so I will send you a message.
My truss spacing is 2' I believe. I have attic trusses with a pull down ladder for access, but I don't plan on heating the attic space. The attic does have a floor in it, so I would have to insulate below that before I installed the ceiling. The attic is only about 12-15' wide, so a good portion of the ceiling is open to the roof.
2002 CATERPILLAR 963C CRAWLER LOADER (A65053)
2002 CATERPILLAR...
2012 Ford F350 Truck (A62679)
2012 Ford F350...
New/Unused Landhonor Quick Attach 3 Point Hitch Adapter (A65583)
New/Unused...
John Deere 772-A Grader (A62679)
John Deere 772-A...
2025 SDLanch SDLL60 Mini Stand-On Track Loader Skid Steer (A64553)
2025 SDLanch...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
