What do you do with your forks?
/ What do you do with your forks? #41
my pallet forks are on 90% of the time. The bucket is really only good for scooping the forks come in handy all the time. I use them during the winter to bring pallets full if split firewood to the porch
I read this on other TBN threads recently...having the forks mounted more often than the bucket. Originally I was going to purchase a set of clamp on forks for occasional use. Now, I am thinking that I may use than more than I thought and may want to purchase a better set. Thought this thread would bring me up to speed on how they are used by the guys who use them everyday.
I don't have a QA bucket set up, so I am trying to figure out the best way to mount a better set of forks. Don't know if the pin on style is practical-difficult to swap out?
Also, interested in the make and models that forum members are happy with, how they are mounted, and photos too. Thanks-John.[/QUOTE]
Hey Jode,
If you are going with forks that attach to your bucket, think seriously about getting the chain-on type, they don't pivot or move sideways like clamp ons can.
I didn't research your tractor or loader's capacities, but it is hard to find a better deal for chain-on forks than The Yankee Warehouse (at yankeewarehouse.net), where we got ours. They currently sell for $159 + shipping, and for their 42" useable length, they are rated for 3500#.
We have used ours for lifting anything and everything that they can fit under or be chained to... Including rocks, brush, our log splitter (palletized from Lowes), our pallet bags of firewood, pallets of logs, logs awaiting bucking to length, the rear of one of our cars, the window A/C unit, tires, and anything else my old back is too old, sore and tired to carry into our barn/garage, or basement, or lift into or out of our truck bed.
We never seem to get around to taking many pictures, though I keep trying to remember to do so.
I'll have to resynch my phone and see if the ones we had taken are still on there.
T
[Hi Tom-
Thanks for the photos. I have a few basic questions.
If I purchase the Kubota QA, will they fit many attachments or just Kubota brand attachments?
I am looking for a set of forks. So with the Kubota set, what type of forks would I look for-pin on forks?
Will different aftermarket companies (ie Titan) forks fit onto this QA?
Thanks!
QUOTE=TomSeller;3990125]There are quite a number, but I think the John Deere and Kubota styles were fairly common.[/QUOTE]
/ What do you do with your forks? #43
[Hi Tom-
Thanks!
[/QUOTE]
Each style is specific. So if you purchase the Kubota or Deere style for your tractor's FEL, you will need to purchase that style attachment which will limit your choices and likely drive your costs up. SSQA is more widely adopted and many more attachments are made for it. Titan does make some John Deere style attachments. I have not looked for any Kubota forks.
/ What do you do with your forks? #44
Kubota SSQA attachments are widely available. Getting SSQA was the smartest thing I did.
We use forks to pick up snowmobiles and load them in the truck, and easily move large logs
And large rocks
With relative ease.
/ What do you do with your forks? #45
Do you have a photo of the ssqa set up on your tractor, with the forks or bucket mounted? Thanks
What brand are your forks?
And large rocks
With relative ease.
/ What do you do with your forks? #49
As an earlier post stated, I have the forks on almost as much as the bucket. I use it to move hay into the barn and then to the feeder; pick up down logs, move stall mats, move lumber, aerate the compost pile. My forks are from a 5000# forklift so I've also used them to get under small trees and shrubs to up root them.
/ What do you do with your forks? #50
I suggest that you remove your pin on bucket and put it back on. That will show you if it is worth having a QA. :D
My FEL is pin on and to make it easier to swap attachments, I set them on a dolly. Put the pins in the arms first, then do the cylinders, lining it up with the curl valve.
I made this fork frame over 30 years ago for a garden tractor. The forks are 24" long
The bucket is 42" wide.
Here it a dolly for forks that I saved in my to do file.
from Artillian Tractor Attachments - Light-Weight Heavy-Duty Pallet Forks for John Deere Subcompact & Compact Tractors
Are yours mounted with a skid steer quick attach?
Thanks for all of the good ideas..appreciate it.
Their slip on dolly is a nice design. Could make a
pair with a plank of PT wood, pair of casters and
a pair of u-bolts? Quick and easy?
Plan on going to a QA setup, or staying with pin on?
I will try your bucket removal idea..nothing better than
life lessons to show you the way.
I suggest that you remove your pin on bucket and put it back on. That will show you if it is worth having a QA.[/B] :D
View attachment 404434 View attachment 404435
View attachment 404436 View attachment 404437
from Artillian Tractor Attachments - Light-Weight Heavy-Duty Pallet Forks for John Deere Subcompact & Compact Tractors[/QUOTE]
/ What do you do with your forks? #53
I will stay with pin on, I don't use it much now and I can lift the bucket and all of the attachments by hand. So it is just that it takes longer to swap attachments, but being retired, I am in no hurry. :D
/ What do you do with your forks? #54
All the replies in this thread have been very helpful-thanks to all.
I now understand some of the many uses for front forks and the value
of owning a set. Now need to decide on the type of connection I will use
and the Brand of forks to buy. Called Titan today and was informed that
they do not sell pin on forks-wasn't happy to hear that. With a $280 set of
oem Kubota loader adapters I would be able to use my bucket as is
(now cutting and welding) and have
a version of a quick attach that would seem to work for my needs.
I will have to see who else makes a set of pin on forks at a reasonable cost. Any ideas?
I am not yet sold on the expense of converting to a SSQA style. I don't think I
will have enough of a need or use to warrant the expense. Unless I am missing something.
That leads to my next question. What other attachments would I possibly be using on this
30hp tractor and my 4 acres. I don't need a snow blower or pusher...what other attachments
are used up front?
/ What do you do with your forks? #56
are used up front?
Consider these (in addition to the forks):
A boom, bare fork frame, front weights, log carrier for stacking / loading / bucking. Not pictured is a mounting plate, which can be welded to just about anything to make it attachable to the FEL.
There are others attachments as well. Check a Ritchie Bros. Auction for a number of FEL attachments, both hydraulic and not.
http://www.rbauction.com/
Go to the skid steer attachment area of the website. Look through the possibilities. You may want to add a hydraulic control to the FEL if you see something really desireable.
https://www.rbauction.com/skid-steer-attachments?id=ci&s=Y2l8Tj0wJk50az1FcXVpcG1lbnQuZW4mTnR0PXNraWQrc3RlZXIrYXR0YWNobWVudHMmTnR4PQ==
/ What do you do with your forks? #57
are used up front?
beyond pallet forks, and the regular bucket I LOVE my brush grapple. If you have any land clearing to do or ever cut down firewood trees its EXTREMELY useful. If you mostly have a cleared out farm you probably wouldn't get enough use to justify it, but if you are rehabbing an overgrown farm like lots of people are these days (including me) its well worth it. I can spend all day cutting 10 large trees and clean all the brush mess up in about an hour with the grapple.
/ What do you do with your forks? #58
The quick attach is also nice in the event u need to remove your bucket for some reason. Like mowing close to something, transportation, added lift capacity but forks have been main use. I have had clamp ons and quick attach. Quick attach Definitely the way to go.
/ What do you do with your forks? #59
I have forks for SSQA and the 3PH. I keep my firewood on pallets so the forks get used a good bit moving firewood. I also keep a bunch of random stuff like metal, mulch, bricks, and blocks on pallets so if it is my way or I need it for a project it is easy to move. Forks on the loader are nice if you need to lift something high. Forks on the rear are nice if you need to lift something heavy your FEL can't lift.
Carry all for forks
Used to unload from a semi
Used to lift a shed of blocks so it could be moved. I also pushed the shed into place with the forks.
If you can't tell I used my forks more than anything:laughing: They are a real time saver.
/ What do you do with your forks? #60
Nice attachments. Sure is nice to see someone else that drags along multiple chainsaws.
