What do you do with your forks?
   / What do you do with your forks?
Can you post photos of your forks?
I've recently built a set of 42" forks that will mount on either of my BX's. In order to not damage the FEL I welded a 1x6" black pipe nipple onto the forks. I hook the nipple under the top bucket lip and rotate it down to the FEL. Increasing the bearing surface on the lip has, so far, eliminated any deformity of the bucket. If you can weld they are pretty simple to build.
   / What do you do with your forks? #32
i dont use them for everything, but i used them atleast once a week. I use them more than my factory bucket probably. I dont move anything heavy by hand anymore. I put it on a pallet and then i move it with the tractor. I move IBC's full of water to the top of our pasture to water goats. (IBC's are 275 gallon containers for food powders and liquids, they have a built in pallet). I'll occasionally fill an ibc with water and carry it to a bonfire so i have a way to easily put it out with a gas water pump. I use IBC cages to store firewood. I split firewood and throw it in a cage and it stays there untill I'm ready to burn. I just carry the cage and set it outside the house when I need more wood. So the only time i move the firewood is at split and burn time. No stacking or restacking. I also store lumber and building materials on pallets so they can be moved and stacked in my barn when necessary. If i have to lift anything with a chain, i prefer to use the forks because they have more reach and are easier to hook onto. Having the forks and eventually the IBC's has really changed how i do everything on my farm. I have food grade IBC's for water, and cheaper (10 dollars a piece) industrial IBC's I just use for firewood. I put scrap metal in steel drums on pallets so when its time to load on a truck to go to the scrapyard i dont lift it - the tractor lifts it and the scrapyard uses forks to offload it. Most of the things I use forks for require a lot of lift capacity so i'm not sure I would have any use for clamp on forks. 3PH forks sound like a great idea, particularly for really heavy stuff like water containers. I dont have any yet, but would love to get a set on day.
   / What do you do with your forks? #33
I picked up a set of 3pt forks from agri supply and they work great for the IBF totes. We use them for collecting maple sap, which is slightly heavier than water and the forks have performed great despite going over their stated capacity. Great buy for something in that price range.
   / What do you do with your forks? #34
We use them for collecting maple sap, which is slightly heavier than water .
The heck with the forks, do you have pictures of your maple sap collecting?
   / What do you do with your forks? #35
I used the Northern Tool 1500 lb clamp on fork to take my 3'x6' trash pallet to the pickup point, 300 ft drive.
My trash pallet has two large containers on it, the Trash Truck comes by picks up the containers, dumps them and puts hem back on the pallet.
That is all so far it who knows where from here.
   / What do you do with your forks? #36
One of my uses for pallet forks is to load firewood onto my deck. The deck is 6' high fork firewood 005.jpgfork firewood 006.jpg. I took out a rail section and built a hinged gate. fork firewood 001.jpg
How many types of QA sytems are there? I know of the Skid Steer design.
Are there other QA designs, as well?
Thinking of looking into QA adapters for my FEL and would like
to review the correct style, if there are options.
   / What do you do with your forks? #38
There are quite a number, but I think the John Deere and Kubota styles were fairly common.
   / What do you do with your forks? #39
I'll have to start a thread about it sometime.
   / What do you do with your forks? #40
Bought the Titan 48" x 4000lb. forks for our NH TL100A and they also work great on new LS XR4046HC.
Worked great to unload new Woods grader.
We bought set of the Titan 48" x 4000lb. clamp on forks for our Kubota B2710 which had a pin on bucket. They work very well with light loads.
Sold the Kubota last month so, the brand new clamp on forks with Titan stabilizer are for sale in Colorado County, Texas. PM me if interested.
Sent from my iPad using TractorByNet
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2020 DRAGON ESP...
2011 Chevrolet Impala Sedan (A59231)
2011 Chevrolet...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56438)
2016 KBH...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
