Project work shop...
/ Project work shop... #21
Great looking shop! I had same issue with no light at garage door so I installed lights on the garage door that I can turn on when working with door up.
Ericher,
The heater works good in my shop. Last winter it got down to -27 for a couple of days. That little heater kept everything warm. It looks small but puts out quite a bit of heat.
Scooter,
How did you connect the lights to the door? I have a low ceiling so I don't have the room to put lights above the garage door, and have never considered putting them on the door itself.
/ Project work shop... #23
I cut wood strips out of 1/8 plywood and attached lights directly to that. The lights are wired in series so only one is plugged in. I also have lights attached to ceiling so if door is down I have light and they are up flush to ceiling so that when door is up they don't hit.
/ Project work shop... #24
At my old shop I had planned to put a work light on a pivoting arm, so that it would work with the door up or down and swing out of the way if bringing in something tall. Never got a roundtuit. :(
/ Project work shop... #25
The out feed table isn't bolted to the saw. They are separate. My solution for cutting MDF is something different. I will try explain it here. It starts with 2 saw horses. Then I have 6 pieces of 3/4" plywood. 3 pieces are 4ft long and 3 pieces are 8ft long. All pieces are 6" wide and have slots cut halfway through. 2 of the pieces sit on top of each saw horse. Then the 3 long pieces are interlocked with these 2. The third short piece is used at the middle to prevent wobble in the center section. I have tried to include a picture so you can see what I am trying to explain. The best part of this is that it breaks down into a small bundle for storage. Saw horse sheet good system
Dan;
Cutting up sheet goods is awkward at best. I built a table to make the process easier. Built it with pressure treated lumber so it can stay under roof but, outside. It is easy to pull full sheets of plywood, MDF, etc straight out out pickup bed.
Also built below storage rack for full and partial sheets. It is on HD casters to make it easy to move around.
kCGImageProviderAlphaIsPremultiplied = 1;
/ Project work shop... #26
Nice use of space. I really like all that flat area you have for your table saw!!! That must make ripping plywood easy
Eddie
/ Project work shop... #27
Looks gooder-un! :thumbsup:
All of my power tools are on castors, including the drill press.
I have an 8' long workbench on a hospital gurney.
Dan;
What are you guys using for casters and where do you get them?
I've been looking at casters for equipment but so far the best bang for my buck has been the Harbor Freight 1000 lb. Capacity Mini Mover's Dolly I bought when they were $6 and $7 each.
The best place I've found on line so far is Surplus Center and I need a lot of casters eventually.
/ Project work shop... #28
Most of mine came from Surplus Center. I have a lot of my attachments on dollies.
I think these are two 5" and one 3.5".
I got the Mini Mover's Dolly on sale at Tractor Supply, with a full size dolly that I removed the casters from, to use on another dolly.
The attachment dollies: http://www.tractorbynet.com/forums/...do-you-store-your.html?highlight=#post3971277
I like the idea of having a table for cutting up plywood/MDF and other sheet goods but I don't have the room. That's why I use the breakdown system like I posted a link to. I find it great to use to make the cuts I need. Then when it's not needed it breaks down to an 8ft long x 6" x 6" package that stores easily.
I also like the swing out light idea. I may find a use for that in the other garage for when I have vehicle work. Things like changing tires at the end of the season, brakes etc.
As for the casters, I get them from the local hardware store. Mine are polyurethane with a softer rubber coating. This gives me the weight I need for the benches and tools with the ability to roll over dust, dirt or cords that might be in the way. My casters have a total height of just 4-1/4". This gives me the most usability. A caster that is higher will start to limit my cabinet size. The 4" height is basically the same size as a toe kick so I don't lose anything in terms of storage space.
It reminds me of something I did for buddy when I wired his garage. He did a lot do automotive work. So I set up a row of fluorescent lights about 2ft off the floor. The lights ran down each side of his garage. By doing this he never had to use trouble lights when working tires, brakes, axle seals. These lights were on their own circuit and switch so he didn't have to have them on all the time. When the car was up on a lift the whole under side was lit up, and because the lights were below his line of sight he never had a glare problem from the lights themselves.
/ Project work shop... #30
I built my sawhorses the same height as my table saw (on casters) and benches. It makes ripping 4x8 sheets pretty easy.
/ Project work shop... #31
Cuttin sheet goods is much easier when they are stood on angle against a frame, then using your skillsaw with a guide.
Just a thought....
/ Project work shop... #32
I just bought some 3 in cast iron casters from Lowes - $6 per. Actually cheaper than TSC.
Somehow things got mixed up.
Just a thought....
I though of that. But I don't have the room to store it when I am not using it. The system I use gives the most room with the easiest use. IMHO
/ Project work shop... #34
Nice shop newfie! High and dry boys, when we build our buildings from now on, let's be sure to make'em high and dry! Way off the ground. Well, maybe not on stilts, but dagnabbit, I'm about to the point of wanting everything up off the ground! Tired of drainage, water, rain, just anyway good old h2o can, it will find a way in!
I agree with MacLawn. When this place was built by the previous owner, he did it wrong. It was built among the trees. The previous owner cleared enough trees to build the shop, then removed the topsoil. This left the floor of the shop as a low point. When we had big rain storms or during the spring thaw, the water naturally found the floor of the shop as a low point. Of course the framing got wet creating the mold that I eventually had to remove.
Since we bought this property we have done quite a bit of work. This included a second much larger garage for the vehicles, some paving to help direct water away from my wood shop, landscaping to help direct water away from the house, towards the back of the property. We had eaves trough put on to also help control water flow. Since this spring we have not had any water issues with the shop or the house.
Some of the landscaping included removing some small standing dead trees, laying sod, having to redo the sod because it just water in place and did not allow it to drain away. The back lawn would stay wet for days after even a small rain. Now, even with the heaviest rain, the water all drains off away from all of our buildings.
/ Project work shop... #36
lots of great ideas.
Some I have done.
Built a pair of saw horses that are truck bed high, when I need to cut or use sheet goods, MDF etc I back into the garage and use the truck bed as 1/3 of my saw horses. (I do have air shocks on back of the truck so I can level it out easy however I rarely do.) I slide out the sheet far enough that the drop section can be twisted in the truck bed with the end laying on one saw horse. The other saw horse is back far enough to catch the drop so it dont hit the floor or twist up much. I'm it is a 4x4 near middle split that may crack out I slide two sheets out & when I twist the top sheet after cutting most of it so the bottom sheet supports the cut.
Casters are great on equipment but be sure to get the locking type so they stay put, I have a set of free wheeling ones with out locks which makes keeping the machine stationary an issue some times.
On my work benches I have over hangs on 3 sides to which I add 2~3" wood screws & hang levels hack saw or squares on. I can take a pick if ya want but not hard to do and keeps them off the flat surfaces, (so you can pile more junk one the flat working area.. :/ ) lol
On the shop smith I have also done this to put in collets etc and hole sawed holes large enough in the 2x6 boards to drop in the steady rests, used 1/4" bolts and wing nuts to secure extra circular saw blades or sanding disks.
uploading some pics now will edit and link them shortly below.
Pic of the updated Shop Smith with holes drilled for the tools and or bolts on end of legs to hold saw blades and rests etc, (Click thumbnail for the pic and others of the update.)
try to ignore the messy shop, it is well lived in ;)
Mark
I have something similar Spiker. On my table saw I have all of my blades stored. Below the top on the right side I made a slotted storage rack to keep my blades separate, so they don't clap together and damage the cutting edges. Below the top on the left I made a rack to store my dado blades. It is basically 2 small pieces of 1/2" plywood laminated together. Then I drilled holes at about 25 degree angle. This keeps all the dado cutters on the pegs I put into the holes. This keeps all of my blades close at hand.
On my lathe, I boxed in the factory legs and used the leg spreaders as shelf supports. This gives me a place to store the various chucks bits and other accessories I use.
On the miter saw at the very back, I made a cabinet with drawers to help store smaller items. Because it is a 12" sliding saw it is very deep. I made the cabinets on each side to march the depth. This gives me lots of assembly area on top and huge amounts of storage below. I can slide 2 milk crates in front of each other with room to spare. A lot of my small power tools are in here. My bottom corner cabinet has the turkey frier in it. Along with my tenoning jig, tackle boxes, and a few other things.
If anyone wants I will post a pic of this a little later.
/ Project work shop... #38
I got some of the 2 hole straps (1/2" to 1" sizes for electrical conduit mounts or pipe mounts) that I screw down in/onto the edges of the saw too. Those work great to hold items dropped in like chisels or keys for chucks etc... Lots of small parts on those SMs so to keep them handy it works out, in pics ya can see some of the sawdust it made ;) (Ok lot fo that sawdust was from modifying the saw as I bought it this summer for 100 bucks.
M
Caterpillar 572E Tracked Pipe Layer (A64553)
Caterpillar 572E...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A64553)
2025 GIYI GY-PG72C...
FORD 3 BOTTOM PLOW (A64278)
FORD 3 BOTTOM PLOW...
2015 Kubota ZD221 48in. Zero Turn Commercial Mower (A64194)
2015 Kubota ZD221...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
