Good morning!!!!
   / Good morning!!!! #27,961
Good afternoon all. 40F this morning, overcast light wind. High was 44F low tonight is forecast to drop all the way to 39F. Made it to church ok but the Saturn acted weird and needed to be jumped to come home. More cooking for tomorrows trip and watch the Lams loose another football game :(
   / Good morning!!!! #27,962
Afternoon all, More clouds and no sun again. Merc lost another battery 3rd on since new.
   / Good morning!!!! #27,963
RSWYAN is still MIA? Hope he is well and not busy welding the furnace repair man into his truck sarcophagus. :eek:
I'm about ready to ...
After about a week of the furnace functioning largely without a hitch, it's back to doing the same thing: burner lights, runs for a few seconds, and then shuts off.
Called the furnace dude and told him and he sez: Well, that's different than what it was doing before ... so it must be something else ... we'll be out Monday ...
Ah nooooo ... it isn't really different than what it was doing before ...
(Sometimes the burners would fail to light at all ... but that was less prevalent than than the furnace lighting and then going out after a couple of seconds)
Fortunately, I managed to get the wood stove plumbed into the duct work of the HVAC system of the house ... so it's scavenging more heat off the stove ... even when the fan on the wood burner isn't running.
Seems to me it's either:
1. Another defective gas valve ...
or ...
2. Gas valve was never a problem to begin with, and it's some other component whose faulty operation is intermittent ...
Of course, it could be a combo deal ... :rolleyes:
   / Good morning!!!! #27,965
I wondered if RS got Cupcake upset then got banned from her computer since he had talk about the backlight dying on his.
Since RS is tech support for Cupcake's computer - and pretty much everything else - that will probably never happen ... :D
She certainly is squeakin' about it tho' ...
Upside for the 'Cake is that I fixed the Flash video playback problem (found a hacked version of Flash) ... and she's going to get the RAM doubled and a new AGP graphics card installed ...
Might even upgrade the hard drive while I'm at it ... throw a RAID 0 in there or something and see if that doesn't perk up the paging with VM ... mebbe I can squeak another few years out of a 14 year-old machine ... :rolleyes:
I guess we don't rate :(
Nah ... just limited time is all.
And political discourse is way too easy to get sucked into ...
   / Good morning!!!! #27,966
<snip>
What a pi**er.
If the burner lights should mean the blower vacuum operated switch is working, it shouldn't get as far as lighting in the start-up sequence if that switch isn't made. Of course, it can drop out after lighting and it will shut off the gas if it does. I am assuming your furnace does have a vacuum switch-- Small diameter rubber hoses going from the blower housing to a gizmo with wires connected to it. The vacuum switch usually controls a relay somewhere.
Two things you can check regarding the vacuum:
1) Turn on the furnace with a thermostat calling for heat. Just after the blower has started to run, jumper that vacuum switch. You may have to mess with trying different wires to find the right combination. I don't know if it is a normally open or a normally closed switch. There are specs for inches of water vacuum my furnace blower should develop, probably for yours too. That can be tested with a vacuum gauge if you know the spec with just the blower running, don't need the flame.
2) Make sure the air passages for the intake, air plenum around the burner, and exhaust flue are clear of any obstructions, not full of weed seeds and desiccated mice like my burner plenum box was. :laughing:
The other main suspect is still the flame detector, what they call the "roll out" I believe. If the furnace shuts down after truly firing (you see a flame) for ~5-10 seconds, it can mean it senses no flame heat, so it shuts off the gas supply (in the gas valve) for safety.
I just have the feeling that something is not being satisfied in the start-up sequence because it never truly finishes start-up.
   / Good morning!!!! #27,967
or ...
My SNL was having a similar problem with his furnace. Burner would light and furnace would start but then would shut off. Found the flame rollout switch was being triggered because the heat exchange was cracked. Hope that isn't your problem because the SNL had to replace the furnace.
   / Good morning!!!! #27,968
Good evening on the shortest day of the year. Ron thanks for the reminder on G2's Christmas gift, he would surly be upset if forgotten. Hope you make it back in time for the Michigan sales tax vote, but since you do most of your shopping down South you probably won't be affected. :D
I haven't seen the sun for 5 days, however my solar gate is still working so all is OK for now. 55˚ and cloudy and we had an inch of rain last week. Christmas will be 65˚ and sunny!
We had a pre Christmas party at my parent's yesterday and gave them their present - a recliner/lift chair. My parent's love it - and need it. (I caught my Mom sleeping in it after lunch already.:thumbsup:)
   / Good morning!!!! #27,969
What a pi**er.
Check for water in that hose too. I had some I had to install a tee into it with a short piece of hose pointing down with a capped end. Something like a trap.
   / Good morning!!!! #27,970
The outside unit is almost rusted out and leaks freon. This is reason for replacing. By the way both units are Trane
Might want to look at Rheem or Rudd (same thing, different labels apparently)
Despite our recent issues, our air conditioning unit and forced air (gas) furnace have both been largely reliable for a long period of time. I think one unit is circa 1988 and the other is circa 1990 ... so that's 26 and 24 years respectively.
I don't think the AC unit has ever had anything done with it as far as repairs go ... just the normal yearly cleaning. The first major issue with the furnace was the heat exchanger about 3 to 5 years ago IIRC ... and Rheem provided the new parts for free, we just had to cover the labor to install them.
   / Good morning!!!! #27,971
RS, come back, I'm going through withdrawal not seeing pictures of the Eiffel Tower getting built.
I'll see if I can get some pics of the new duct work for the wood burner to satisfy your jones ...
It's not really finished yet ... still have to remove the mill scale off the 10 gauge sheet I used on the top of the stove so it can be painted ... but that ain't gonna happen until the AC unit runs again ...
And no, I'm not going into UnFriendly Politics to find you.
LOL ...
:thumbsup:
   / Good morning!!!! #27,972
Mac nuts sure are tough. Don't know about percentages, but need to dry them enough to husk. If I don't wear gloves I get blisters on my fingers. Friends gave me a Mac nut cracker for my birthday a couple years back with about about 20 lbs of husked nuts from their trees. Of course they sold the property this year, so doubtful I'll have any more of those nuts. The friends that just gave me nuts used to sell commercially. Told my wife that in the hey day, they got $1/lb, not so today.
David Sent from my iPad Air using TractorByNet
   / Good morning!!!! #27,973
Spent the day running cable to the garage and overnight and reseeding the trench Cold and windy but at least the sun shined. Got my box and breakers today, gotta pick up the door openers when I decide which units.
Lost my dad 50 years ago today which was my brother's 18th birthday, my wife's dad 20 years ago yesterday, my sister in law 10 years ago yesterday, my brother 2 years ago Dec. 8, my grandmother 22 years ago on the 29th. But hey, the birth of Jesus trumps all that!
   / Good morning!!!! #27,974
What a pi**er.
Yup :(
Yeah ... it does ... a couple of them in fact.
To left of the draft inducer and below the tube to the flue:
"New" (possibly unneeded) gas valve:
There are a number of wiring diagrams glued to the inside of the cabinetry ... I'll scope them out and see if I can find any specs, and see if I can discern the normal state (open/closed) and how they operate.
I've got several (automotive) vacuum gauges so I can check it ... but dunno if they are sensitive enough though ...
Right.
The top portion of the furnace (bonnet, plenum ?) that houses the AC evaporator is part of the original Bryant system's cabinetry. I've already noted that that it isn't correctly aligned with itself or the part of the Rheem f/a furnace below it that it connects to ... there is significant air leakage at one corner ... so I'll probably tear into that tomorrow, and see if I can't get it lined up and taped up better. Will scope out the evap housing for debris while I'm at it.
Will do the mice check as well.
I'm likin' that possibility too ... although the burner doesn't stay lit even that long ... three seconds tops.
For as cheap as it is ($10), you'd have thought that these dipnoids that are working on it, would have already just replaced it - to eliminate the possibility. At the very worst, it wouldn't solve the problem and I'd have a spare flame sensor on hand ...
I do notice that the positioning of the sensor seems somewhat problematic (in that it is just barely in the flame) ... the bracket that holds it is clamped around a burner tube ... and of course with all the heating and cooling cycles it is rusted and seized and probably can't be repositioned without destroying it. Would like to find a pic showing the correct positioning from the factory but I dunno how successful I'll be at that.
Yup ... my thoughts as well.
Couple of other data points:
1. There is a resettable breaker on the draft inducer housing (top center) ... this will occasionally trip and need to be reset ... but it's pretty rare in the big scheme of things.
2. The draft inducer motor itself is pretty noisy ... seems like one of the bearings/bushings are going bad ... it's probably near, if not at, EOL. But it runs.
3. The flame of the second burner (of five) is pretty disturbed ... like there is (exterior) air blowing on it ... so maybe the heat exchanger is cracked again ... or something wasn't done correctly as far as sealing things up when they replaced the heat exchanger a couple of years ago.
I mentioned this last possibility to the (older) service guy and his immediate response was something along the lines of "Oh no couldn't be ... that's just not possible ..."
Ahhh ... really ?
Seriously dude ... that's what ya wanna go with ?
Maybe ya wanna take a look at how they lined up and sealed the evap cabinet back to the furnace ... :rolleyes:
The young dude that installed the (original) replacement gas valve managed to sneak off with the original. I didn't let him do that with the controller board when he replaced that, and I wouldn't have let him do it with the gas valve either ... if I had been paying closer attention at the time.
Older dude says "No problem ... we'll get it off his truck" ... but he didn't bring it the last time he was here ... so he's going to get queried on that tomorrow ... before he comes out.
I really hate to say it - because I'm not inclined to do it typically - but these jokers may find out what disputed credit card charges are all about before this is all over.
   / Good morning!!!! #27,975
Yeah ... I hope it's not either ...
I wouldn't think it would be, given that the heat exchanger is only a few years old ... but who knows.
Might have to see if there is any warranty left on it if it is.
   / Good morning!!!! #27,976
I see the problem. You are using Cupcakes hairdryer, but nice touch calling it a draft inducer.:thumbsup:
   / Good morning!!!! #27,977
Thanks murph ... I'll check it out :thumbsup:
I pulled the draft inducer a while back and there was evidence of moisture intrusion (rusting on mounting point and down inside where the impeller/fan is) ... but the (older) dude said that that is typical ... but who knows ...
   / Good morning!!!! #27,978
You don't think that will work ?
It is one of those fancy shmancy Conair units after all ... :D
   / Good morning!!!! #27,979
Yup :(
The vacuum sensing switch is the part mounted on the side of the cabinet center-left in this pic--I think. It looks sort of similar to mine.
I have a tee in my vacuum hoses near the switch. There is a hose going to the gas valve and one that disappears into the sheet metal box that encloses the burner. That box is what I think of as the burner air plenum, the combustion air inlet pipe is attached to that sheet metal enclosure.
   / Good morning!!!! #27,980
Drew,
Here's your fix ...
Even installed a damper in the ducting, so it can be closed for summer cooling activities ... :rolleyes:
60'' SKID STEER BUCKET (A56857)
60'' SKID STEER...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2020 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2020 GENIE...
2013 KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
2013 KOMATSU...
2020 Chevrolet Silverado 1500 Pickup Truck (A59230)
2020 Chevrolet...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
