flushing cooling system
/ flushing cooling system #1
cmyoung2
North west NC mountains
BCS 850, Kubota BX2230 w/FEL, mid mount mower, 41" tiller Kubota L3600 w/4-1FEL, Farmi winch
Finally get time to replace water pump and hoses on my 99 F250 V-10. Know the system needs cleaning, is one product any better than the rest? Prestone is handy, but I have time to look at other stuff. And what would be the best coolant to put back in? OEM stuff has lasted 220k+, hope the replacement will do as well. Replacing drive belt and belt tensioner at the same time.
/ flushing cooling system #2
That's a long time to leave the same coolant in. If everything looks good, as in radiator doesn't looked clogged up or gummed up, I'd just flush it with clean water. What antifreeze? What does the owners manual say? Some say to use a special antifreeze, some don't.
/ flushing cooling system #3
I'd poke around on a Ford or V10 specific forum for advice. I found an excellent step by step for a system flush on Dieselstop for the 7.3 Powerstroke I just sold.
/ flushing cooling system #4
I flush with clear water- with so many hoses/water passages I worry about getting all of a caustic cleaner out.
RANT: New Asian vehicles require special coolant that not only is expensive and hard to find, but usually only can be found pre-diluted, which means that any clear
water left in the system from a flush further dilutes the coolant.
/ flushing cooling system #5
Sent the wife's Hummer out for a coolant flush and Tstat replace on Friday..~$200...Well worth it for me.:D
/ flushing cooling system #6
Thats not a bad price when you figure in the parts cost.
Was the T Stat bad? I have never had one go bad on a vehicle but replaced a few after 120,000 miles. Now boats are another thing. I can't keep a T Stat more than 3 season. The silt buggers them up quickly.
Chris
/ flushing cooling system #7
One function of coolant is to prevent corrosion from dissimilar metals. I would replace much more often than 15 years.
/ flushing cooling system #8
Chris
The truck was throwing a low temp code when temps got into the single digits over the last year or 2...other than that, never mis-behaved temp wise..Figured since it was a 2006, it was beyond time for a flush and get the tstat done--The placement of which is not fun so had both done at the same time. Thought price was more than fair..That's with all recommended additives etc...That's the first thermostat I've replaced since I can't remember when. No complaints here.
/ flushing cooling system #9
Chris
Obviously not heat exchanger cooled, but then in a fresh water area no one spends the money for heat exchanger systems.
And of course, even exchanger systems can have "issues" with the raw-water side, as the government found out:
https://idea.library.drexel.edu/islandora/object/idea:1347/datastream/OBJ/view
/ flushing cooling system #10
I used to do a lot more "wrenching" on vehicles than I do now; water pumps, in-tank electric fuel pumps, starters & alternators, that sort of stuff.
All of it is pretty simple to do, *IF* you can get to the stuff, which is the problem now. Too much machinery crammed into too little space.
/ flushing cooling system #11
I'd just flush it with water. Be sure you drain the block. It will be a pain to do but it is the only way to get all the old coolant and crud out. I use whatever antifreeze the manual recommends. Prestone G05 is probably what it takes.
/ flushing cooling system #12
This is what I have always done. Flush with tap water [well water, not city water] drain then refill with distilled water, flush out. Refill with the correct antifreeze, distilled water mix. SCA's with a diesel. I have found the best run time with distilled water. CJ
/ flushing cooling system #13
Another bit of advice, they make some very low cost coolant testers. Its usually just some little balls that float that way you know you have a good coolant mix ratio.
/ flushing cooling system #14
/ flushing cooling system #15
I have a fancy hydrometer that I borrowed (stole) from someone.
While that will give you a freezing point, it won't really tell one much about the state of the additives in the coolant, which will "wear-out" (deplete) over time. I know there are test kits, for nitrites and such:
http://www.hastingsfilter.com/Literature/SpecSheets/F506.pdf
... that are commonly used to check the state of coolant on BIG machinery, but I don't mess with that on my stuff. I just change the coolant every so often.
/ flushing cooling system #16
Had our 2004 lincoln town car flushed/filled today for $99 bucks from a private shop.
/ flushing cooling system #17
I'm not really getting the difference between well water and municipal water here. In many cases well water can be extremely hard, contain sulfur, iron, etc. I've done it with municipal water, then then run a few gallons of distilled through it after that. Fortunately the block drains weren't bad to get at and loosened easily. I put them back in with some anti seize so that the next guy should be able to get them out, as I no longer own the truck.
Then the antifreeze was cut with distilled water. Bought the pre charged stuff for the 7.3 Powerstroke that I owned so didn't bother with additional SCA. But that can be had from the local NAPA store as NAPAcool. Test strips can also be used to test the SCA content, but it's my understanding that they have a shelf life.
/ flushing cooling system #18
I normally flush using the radiator cap (siphon and replace coolant until clear) or the lower rad hose at the water pump. Have been burned one to many times by the drain valve in the radiator. Also the drain valve in the rad is not normally located for an ideal drain.
Don't even mention freeze plugs, one time my neighbor was determined to do the best job possible draining his coolant, he knocked out a large freeze plug on the bottom side of the block. Spent the better part of a day trying to install a new freeze plug that didn't leak. Finally got it done but it was way more trouble than it was worth, still mention it whenever changing coolant comes up :), we love to mess with each other about our "good ideas". Seems like he always stops by after I finish a job and says "did you think of doing ......?", unfortunately his ideas are usually good, I always ask him, "where were you a couple of days ago?", he's a good guy and a great neighbor.
Q
/ flushing cooling system #19
I deal with municipal water with car washes and the crap that is added will eat away hydraulic fittings in sometimes less than a year. That is the only reason I stated that. If you flush it good, it should not be a problem but I 100% would not use it for a mix. Yes SCA's have a shelf life but test kits are only $50 or so. Any attempt is better than nothing but too much will wipe out water pump seals. CJ
/ flushing cooling system #20
Good enough. I was just curious. It's the test kits themselves that I understand have a limited shelf life.
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
2017 Volvo VNL T/A Sleeper Cab Truck Tractor (A64556)
2017 Volvo VNL T/A...
PETRATOOLS HAND PUMP SPRAYER (A64278)
PETRATOOLS HAND...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
