L5450 feedback, please
/ L5450 feedback, please #1
geneP
Central Mississippi, USA
Case-International 385, Kubota L5450 w/LA1150A loader
I'm going to look at a l5450 with hydraulic shuttle tomorrow. It is 4X4 ( think all were) with a loader (did they all have a loader?). It has 2500 hours on it. Any feedback on this model would be extremely welcome. Is the hydraulic shuttle troublesome? The advertised price from an individual is $12,000, but he has it on a dealer lot. Looking at TractorHouse.com I see prices from $11,500 to $16,000 so this obviously isn't a killer deal unless they are a remarkable tractor. I'll be using it to clean up some land that was cut 8 yrs ago, then just bush-hog maintenance, etc. currently I'm doing this with a Case-IH 385 with a box blade and a bush hog. It is working, but slow.
Thanks for sharing your wisdom.
I found a few, but most are older threads. I was hoping for more recent experience since the tractor model is older now.
/ L5450 feedback, please #3
I have one that I bought a few years back with super low hours. Mine has a backhoe and I use it more than I would have thought. your price is about right if it was taken care of. Tough tractors. The 5 cylinder Kubota is smooth and starts without glow plugs down into the teens and maybe single digits. The Everclutch does nothing more than take the switching fluid away ahead of the forward and reverse clutch pack actuators. So effectively it is like putting it into neutral and disabling forward and reverse. So if your clutch packs are good, the everclutch is good.
Well, I looked at it today. It appears to be a logging tractor. It has a skid plate under the bottom and a shop made steel canopy and limb risers, all unpainted so it isn't a pretty tractor. It also has had two remotes added. All that would be fine but it suggests it maybe has had a hard life. I'm not ready to pay his asking price for it.
/ L5450 feedback, please #5
I told you they were tough tractors. But I understand the obvious concern.
Thanks, Tom. If I knew the tractor was used and maintained reasonably I wouldn't be so concerned because the skid plate would actually be an asset. But we all know how some hired hands treat someone else's property. The guy (not a sales person) from the dealership that showed me where the tractor was didn't know if the loader is considered a "quick attach" loader, or not. Can anyone address that question? I really don't think I'll want to run the loader on the tractor most of the time and would like it not to be an ordeal to install/remove it from the tractor.
/ L5450 feedback, please #7
It may depend on the loader you have. I have the LA1150A. I never take mine off but it has the set of kickstands above the steering wheel and it is all set to take it off.
The loader is just like yours. It even has the remote valve mounted on the fender as in the picture. This tractor has two bolts holding the brace in the cradle in front of the radiator. The steering tie rods that are ahead of the front axle are bowed, probably from running over saplings. That is a bad place for steering tie rods IMHO.
/ L5450 feedback, please #9
If it isn't pretty and has customized it, he may take a lower offer.
/ L5450 feedback, please #10
I'm a long-time fan of the L5450 - it is old-school over-built, one of Kub's best products ever in my book, a really nice robust machine. The Ever Clutch is almost always trouble-free but abusive slipping can warp the disks leading to a replacement job. For a while I had 2 L5450s, one with a cab and the other an open-station with canopy. No real trouble with either - 1 has 1500 hrs, the other around 2k. I sold the non-cab for $18k a few years ago and it's still worth that. For this one the $12k asking price with the LA1150 loader may not be out of line, even with the experience it has. BTW the loader comes off ok - I do mine 2-3 times a year, best done on a level surface.
Check the valve cover vent tube for excess blow-by (smoke). The exhaust on these engines smoke a little normally until warmed up. Look at the 2 dipsticks (engine and trans) for water or other contamination, and inspect the 2-element air filter - if inner or outer element is broken or missing it's usually a deal breaker. You can do a quick check of hydraulic system strength - with engine at idle, rolling the bucket forward should lift the front of the tractor easily. If it doesn't or if it needs more rpm, the front pump may be worn ($$).
To check the hydraulic clutch, carefully observe if it tends to creep either forward or back idling in gear, with clutch pedal up, shuttle lever in neutral. Block one rear wheel and jack up the other. The owner shouldn't object unless there's something to hide. For the test put it in 2wd, idle the engine in 1st low gear with shuttle still in neutral. Shift the shuttle into either forward or reverse - lifted wheel will turn. Move the shuttle back to neutral - the wheel should come to a stop. If it doesn't, try stopping it by hand - if it persists in turning that would indicate clutch drag, potentially a spendy repair.
The L5450 was intended for heavy use and when they turn up in the used market they are rarely pretty - but they are a lot of tractor and below 5000 hours they're definitely worth repairing. Good luck - Dick B
/ L5450 feedback, please #11
.... This tractor has two bolts holding the brace in the cradle in front of the radiator. The steering tie rods that are ahead of the front axle are bowed, probably from running over saplings. That is a bad place for steering tie rods IMHO.
Gene the front cradle bolts originally had L-handles on the heads. They tend to get lost and replaced with regular bolts. The tie rods are solid forged and quite strong. They're intentionally shaped to clear the wide front tires on sharp turns. IMHO the steering design is better than many.
The L5450 is sorta "up my street" so any questions fire away. Take care, Dick B
Thanks for taking the time to alleviate some of my fears, Dick. I just talked to the owner and have struck a deal. I'm going to pick it up this afternoon.
/ L5450 feedback, please #13
Fantastic. With your intended use, the skid plate and limb risers and maybe a little paint, you should have a good setup. What tires are on it? Also, would you mind posting pictures?
I'll post a picture tomorrow, It was dusk when I got home with it. It has (I think) 17Lx24 R4 rear tires, I didn't look at the front size. It is a '98 model and has quick change bucket and fork setups.
I found a 2008 post that gives an Ace Hardware paint code for the Kubota gray. I plan to tidy it up some.
/ L5450 feedback, please #15
Purchased in '98 would be one of the later ones made. Tractordata.com indicates Kubota stopped making the L5450 in '97. Mine was purchased in '99. A quick change bucket would be an after market retrofit which is what I did with mine and very well worth it. Looking forward to the pictures.
Tom, we were at the Kubota dealer for the transaction. He looked up the serial number and said it was made in August of '98. I've found Tractordata.com to be a good reference, but some of the data is general, at best. Here are two pictures of the homely girl.
It wouldn't let me post but two pictures in the above post. Here is another.
Also, apparently there are no provisions in the bucket for the kickstands to support the loader for removal from the tractor. I believe I could fabricate some if I had a picture. Can anyone help me with pictures showing the kickstand attachment points? Looking at the kickstands, they may be no more than a keyhole socket in the bucket somewhere. Thanks for any help on this.
/ L5450 feedback, please #18
You say she's homely - I say she's positively fine! Some examples: (1) the fender-mounted tail lights and blinkers are still intact -rare. (2) the sheet metal is all there - also rare. (3) the grille guard is still straight, as are the extra limb lifters (4) the rear rims look to be rust-free at the valve stems (5) the 3-point lower arms are reinforced with flat bars welded along the bottom - gives a clue about how a L5450 3ph will lift a house (6) I really like that it hasn't been repainted - there are some worn spots that show it has done honest work, but no hiding of old damage or weld repairs. I think this L5450 looks great - an honest no-bull beefy tractor. Congrats !
If you look under the floorboards along the loader stays, the 2 braces may be clipped on there. I'll see if my loader manual has a drawing I can post. The two bolts from the front cradle are used to attach the flat bars to the bucket - and the stays support the boom.
Dick, one of the reasons I bought the tractor was the story from the seller and the dealer: The seller bought it from the dealer about 4 months ago with the intentions of installing a log grapple on the three point hitch. He had the dealer install the remotes, belly pan, and limb risers/top when he bought the tractor. For some reason the grapple didn't work correctly on the tractor and he bought a Log Hog. The dealer had checked and serviced the tractor before the sale. So the tractor wasn't used in logging for very long, so hopefully it wasn't over worked.
I see some clips on the 3 1/2" x 45" x 1/4" steel bars that run from the main loader mount to a bracket on the rear axle. I guess the brackets are missing. Pictures or diagrams would be appreciated. I ordered an owner's manual for the tractor while I was there, I guess I need to call back and get a loader manual.
/ L5450 feedback, please #20
Here are some pages from the loader manual. Sounds like what's missing are what they call the "stands". From the Kub website the part number is 75560-55970 and they list for $48 each (ugh!) Before you order them ask the dealer to ask the prior owner to hunt around for them. If that fails, they could be home-made cheap using a couple pieces of 1/2 x 2" flat bar with bolts and slotted holes. I can get you dimensions from mine.
  • 9 reinstallation.pdf
  • 8 storage.pdf
  • 7 removal.pdf
