quicksandfarmer
Elite Member
I have an old dairy barn that is roughly 150 years old. It's three levels, with a cellar and a hay loft. The floor on the main level has become dangerously rotten and I've started tearing it out. I'm trying to decide what to replace it with. I'm going to use it as a workshop, so I want a nice smooth floor. I'll probably paint it. The existing floor is 2" rough lumber. I'm mulling a few different options:
I can get rough lumber from a local mill. It would cost me about $1.30/square foot for 2". This would be the historically correct way to proceed (it's possible this is the mill the original lumber for the barn came from). The problem with this is it wouldn't make a very good floor. It's rough surfaced, and even if I sanded it would be hard to sweep. It would expand and contract with the seasons, making cracks for debris to fall in.
I can get tongue and groove modern 2x6's. They're about $2.20 square foot. I think they would make a somewhat better floor than rough lumber.
I could also use sheet goods. The joists are on 21" centers, which means I would probably cut every sheet down to 84 inches, which means a lot of cutting and about 15% waste. An advantage of boards is there would only be 3" waste on a 16' board. I am a little worried that 21" might be a long way for a 3/4" sheet to span.
I could get BC sanded plywood (3/4) for $1.30/ square foot. Tongue and groove plywood ("DryPly" from Home Depot) is $1.32. T&G OSB is $0.54 and plain OSB is $.45.
I'm intrigued by Advantech, which is about the same cost as plywood ($1.32) but I've never used it. Will paint stick to it?
Anybody have any thoughts?
Thanks.
Thanks.
