Oil & Fuel Do I need to pull the head?
/ Do I need to pull the head? #1
Sspiderman
Williams Lake, BC, Canada
YM155D
I have just purchased a 1978 YM155D that had the injectors removed 5 years ago. They don't have the injectors, seals or hold downs, but I think I can order all the parts I need from Hoye. The engine cranks on battery power like a champ & seems to have decent compression, etc. My concern is that there looks to be crud (spiderwebs, dust, etc) in the injector holes. Is there a way to clean the intake out without removing the head? Even if I remove the head am I going to be able to clean that area out without tearing the head right down and hot tanking it or something?
/ Do I need to pull the head? #2
I'm going to make some assumptions here because what you write is not entirely clear. By cranking the engine over you have already sucked some junk into the combustion chamber so if you add a bit more I would say it's not a big deal. To clean out the injector holes they need to be wire brushed with a round wire brush. I haven't checked but you should be able to find these at Acklands or a similar store. For sure your local diesel shop should be able to loan you theirs or supply one for you. Round wire brushes come in different sizes so measure your holes before you go shopping.
Since you ask about cleaning the intake out I'm going to assume that the intake manifold was removed. This I would have done before turning the motor over but it's to late now. I would make sure the intake valve is closed for the intake port you are working in. Then blow air into it while brushing with a small wire brush as much as you can. If you can't reach everything then get some brake clean and wash the whole port down thoroughly while blowing air. Some brake clean might leak through the valve but not enough to worry about.
Clean the intake ports first and then start on the injector holes. Next make sure the intake valve is open but not the exhaust valve for the injector hole you want to clean. I would stuff a rag into the intake port along with the air blower. As you are wire brushing the injector hole blow air into the corresponding combustion chamber. This will blow the crap out the injector hole while you are cleaning it. All the rust if present and junk needs to be removed from the injector hole before you install new injectors. If you have to force them in something is wrong. Make sure the old copper washer at the bottom of the injector hole gets removed. Test fit the injector and then before you bolt it in give it and the hole a light coating of never seize. That will make the next mechanic who removes the injectors happy. Before you hook up the injection lines I would at least make sure diesel is coming out of each line while you crank the engine over. At least then any loose junk in the line will be flushed out.
/ Do I need to pull the head? #3
You have an upper and bottom chamber under the injector. Assuming they are still down in there here is a picture of what the bottom chamber looks like. Yanmar Tractor Parts INJECTOR CHAMBER - BOTTOM *OUT OF STOCK * This is not yours but yours will look similiar. Since you have already spun the engine I would blow in there good with air, put the injectors in and see what happens. Do you have any history of what was going on with it when the injectors were pulled? If you had a gauge now would be a good time to check compression. Yanmar Tractor Parts: Search
/ Do I need to pull the head? #4
well if your cranking it all that crud is bouncing around inthe cyl. If you did it with a tester in it most likely blew it out exhaust if no injector it prolly blew it out the hole. But as easy as it is i would pull the head.
/ Do I need to pull the head? #5
There has to be a reason why the prior owner pulled the injectors then abandoned the project. It's simple to pull the head from a 2 cylinder Yanmar, I would just pull the head and take it in to a diesel shop for inspection and rebuild as necessary.
I expect this will avoid much aggravation between now and the day you put the tractor back in use.
/ Do I need to pull the head? #6
How are you going to know the condition of the rings without either checking compression or cranking? Head gaskets are also expensive.
/ Do I need to pull the head? #7
" seems to have decent compression"
What are you basing that on?
/ Do I need to pull the head? #8
yea but buying a head gasket is cheap insurance when you do pull it. I would hate to see him put the injectors back in and then just have to pull it all back down again to take to a shop that does deisel heads, then still have to put a gasket in it.
Based the compression by the amount of air movement through the engine and the force it was exploding out with.
This is my first diesel but not my first rodeo, I have rebuilt several engines, from 1 lung 2 stroke dirt bikes to big block fords. I rarely pay mechanics (except for the computer crap), but I always do plenty of research (except when I get excited and crank the engine to soon... DOH!), before tearing into a project so I'm really comfortable when I do dive in.
I appreciate the comments and suggestions regarding my tractor. After I recover from hernia surgery, I will include the top end gaskets with my injector order and pull the head, as that seems like the prudent move. The previous owner (my brother-in-law) didn't pull the injectors, his ex-girlfriends dumb assed brother did & nobody knows why, so better to spend a little extra than cause more damage.
Parts in Canada for this model seem to be hard to come by, they want $600 plus shipping for the 2 injectors (no hold downs) vs $81/ea from Hoye. Fortunately, my father lives in Wa State, so I can ship parts to him and pick them up during visits.
Question for Winston1, how do I check compression on a diesel?
/ Do I need to pull the head? #12
Call Hoye, i bet they will ship to Canada if you ask. there actually real people down there and really nice too. I wanted some fuses but didnt want to spend $14 to ship it. I asked if they could just charge me like a dollar or two and put them in an envelope and they did!!!
They make deisel compression testers.
/ Do I need to pull the head? #13
As Winston pointed out, you need Hoye's Adapter - or some sort of dummy injector, probably made from a junk injector - because these tractors don't have glow plugs and the only opening into the cylinder is the injector hole.
Clemsonfor, yes, they will ship to Canada, but the tax and duty on 2 $84 injectors will push them to almost $500 CDN, so if I order a bunch of parts it's cheaper to drive down, visit my kid and pick them up or have my son bring them up and ship them from this side of the border.
California, I have decided to pull the head and check the cylinder and clean everything up properly to make sure I don't have a worse problem down the road.
Thanks for your help with this folks.
/ Do I need to pull the head? #15
:eek:
Thats crazy!!!! What the heck is the tax up there. And what is a Duty FEE ??? It must be astronomical!!! Yall dont want any trande with the US i guess!!!
The duty is for importing items instead of buying them up here. Sometimes if the parts cannot be sourced up here, you can get them to waive the duty, but normally they ding you for the taxes (12%) because the govt always wants their money, then if you just have it shipped, they send it through a broker who charges a processing fee (15%) and then customs charges duty, if I have it in hand and bring it up myself, I can get it waived, but it's a 6 hour drive each way to the border, so I'm hooped either way.
/ Do I need to pull the head? #17
I guess I'm a little more fortunate then. I live about an hour and a half from the border and if I plan on doing business in town the day I go then it's only an hour to the border (Sweet Grass MT) from Taber AB. I usually wait until there is at least $700 worth of goods at the border before I go. I have a freight depot (FedEx) there and also a box number. The post office only holds a month but they will send it to FedEx which holds parcels for a year. Usually the customs guys will do my paper work for me. I would say 95% of the time I only get charged GST at 5%. One time clothes were 18% duty and another time I paid 3% duty on an exhaust system. I think your broker is doing the fees wrong as there is no duty on most items manufactured in USA because of the free trade agreement.
I don't mind bringing in goods for people as long as you aren't in a hurry as sometimes it's 6-8 weeks in between trips to the border. Pm me if you want to know all the details. Suffice to say I could probably save you a few dollars since Alberta has no sales tax. If you need it right away a person could reship by bus or freight once it's through the border. I do have a trip planned sometime in early January as the neighbour boys need some quad parts. The parts aren't ordered yet so we have a few days to work things out if your interested. If you pm me your phone number I don't mind calling either.
pmsmechanic, thank you very much for the offer. I ordered the parts yesterday and they are enroute to my son in Oak Harbor Wa. I will keep you in mind or future fun & games. Do you by chance smoke cigars?
/ Do I need to pull the head? #19
No problem I just hate seeing our system rip people off.
No I'm one of those guys that doesn't smoke anything!
/ Do I need to pull the head? #20
so you have to declare this stuff? HOw do they know? If you dive a truck with toolboxes and stuff all in it how do they know that you have say 2 new injectors in your tool box. I mean dont keep them all boxed up and packing slips. Just put the slips in a pile of paper ditch the box at a gas station and put the injectors in with all your other crap!!
no way they could find stuff like that in my truck!!! Wifes car thats another story.
Now if you have a truck load of snowmobile and quad parts and a back seat full of chlothes that would be hard as well.
