JDRULES
Member
This past June I traded up to a John Deere 4320 from a 3320 and just learned that there is not enough room in the standard rear wheel position for the road chains that came with the new tractor, as they will rub against the inside of the fender. So I turned the wheels like had been done for the 3320 and the wheel width is now unfreaking real! It's now slightly wider than my 84 inch rear blade. Has any one out there run into the same issue and had any success with adding a two inch skid steer (or other?) wheel spacer to a JD 4020 series compact? If so, what is the brand, product number, cost, and retailer you used? If only John Deere would not have taken the cheap skate route and discountinued the 8 position rims that they had sold on the 4020 series for years! I can't be the only one out there that needs to run tire chains on this size tractor. Thanks in advance for any recommendations.
