Buying Advice John deere 3230e vs kobota l3301
   / John deere 3230e vs kobota l3301 #1
Wideglide
Clarksburg,nj
Mf-210
Looking to purchase soon. To replace 33 year old massey fergerson 2210-4, which has been an awesome tractor. Any advice would be helpful.
   / John deere 3230e vs kobota l3301 #2
I went with the L3200 (same minus the tier 4 emissions stuff).
Reasons I ended up with the Kubota instead of the JD:
3 range hst instead of 2.
Folding ROPS.
Turning brakes.
Not an aluminum transmission case (a weak spot on the JD I hear).
SSQA.
The L's historically have had a jerky 3pt & my L3200 is a bit rough. The L3301 I tried a while back was smoother than mine & I hear all the new 01 series are fixed & smooth.
I keep thinking about upgrading mine to a cabbed grand, but will be looking at the equivalent pimped out JD as well.
   / John deere 3230e vs kobota l3301 #3
2-range transmissions should be limited to garden tractors!
   / John deere 3230e vs kobota l3301 #4
Quick attach loader instead of the JD permanent mounted.
The JD isn't bad, I just think the Kubota has more noticeably more features at the same price point.
   / John deere 3230e vs kobota l3301 #5
I was concerned about this when I bought my 2320 but in practice it hasn't been a problem for me. The ranges overlap with the HST and I haven't noticed any real limitation or annoying needs to shift.
I wouldn't be happy with a tractor without an easily removable loader but others say that's fine for them.
The quick detach loader is not a concern. The MF I have currently has a loader and I never had to remove it. What other features do you like about the kobota?
   / John deere 3230e vs kobota l3301 #7
any reason you aren't staying with a Massey? I'm not sure on the model number that specifically compares, I think it would be the 1732e ?
   / John deere 3230e vs kobota l3301 #8
I already listed most of em earlier, forgot the detachable loader (that I have yet to detach).
   / John deere 3230e vs kobota l3301 #9
Having a QA bucket can be really handy even if you never remove the loader itself. I found that pallet forks are on the FEL as much as the bucket.
   / John deere 3230e vs kobota l3301 #10
What kind of forks can you put on a FEL by taking the bucket off?
I've been wanting a set of forks for a while, and it seems I have two options. The kind that hook on the bucket, or the kind that require an SSQA.
I often take the bucket on & off, switching with a grapple, and would love a fork option.
Thanks!
Truck Mounted Carpet Cleaning Extraction Machine (A57453)
Truck Mounted...
2009 GMC Sierra Pickup Truck, VIN # 1GTEC14X29Z187521 (A57453)
2009 GMC Sierra...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56438)
2017 Yale GLC050VX...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
CAT930K (A58214)
CAT930K (A58214)
2012 Ford Expedition 4x4 SUV (A56859)
2012 Ford...
