Buying Advice John deere 3230e vs kobota l3301
   / John deere 3230e vs kobota l3301 #1
Wideglide
Clarksburg,nj
Mf-210
Looking to purchase soon. To replace 33 year old massey fergerson 2210-4, which has been an awesome tractor. Any advice would be helpful.
   / John deere 3230e vs kobota l3301 #2
I went with the L3200 (same minus the tier 4 emissions stuff).
Reasons I ended up with the Kubota instead of the JD:
3 range hst instead of 2.
Folding ROPS.
Turning brakes.
Not an aluminum transmission case (a weak spot on the JD I hear).
SSQA.
The L's historically have had a jerky 3pt & my L3200 is a bit rough. The L3301 I tried a while back was smoother than mine & I hear all the new 01 series are fixed & smooth.
I keep thinking about upgrading mine to a cabbed grand, but will be looking at the equivalent pimped out JD as well.
   / John deere 3230e vs kobota l3301 #3
2-range transmissions should be limited to garden tractors!
   / John deere 3230e vs kobota l3301 #4
Quick attach loader instead of the JD permanent mounted.
The JD isn't bad, I just think the Kubota has more noticeably more features at the same price point.
   / John deere 3230e vs kobota l3301 #5
I was concerned about this when I bought my 2320 but in practice it hasn't been a problem for me. The ranges overlap with the HST and I haven't noticed any real limitation or annoying needs to shift.
I wouldn't be happy with a tractor without an easily removable loader but others say that's fine for them.
The quick detach loader is not a concern. The MF I have currently has a loader and I never had to remove it. What other features do you like about the kobota?
   / John deere 3230e vs kobota l3301 #7
any reason you aren't staying with a Massey? I'm not sure on the model number that specifically compares, I think it would be the 1732e ?
   / John deere 3230e vs kobota l3301 #8
I already listed most of em earlier, forgot the detachable loader (that I have yet to detach).
   / John deere 3230e vs kobota l3301 #9
Having a QA bucket can be really handy even if you never remove the loader itself. I found that pallet forks are on the FEL as much as the bucket.
   / John deere 3230e vs kobota l3301 #10
What kind of forks can you put on a FEL by taking the bucket off?
I've been wanting a set of forks for a while, and it seems I have two options. The kind that hook on the bucket, or the kind that require an SSQA.
I often take the bucket on & off, switching with a grapple, and would love a fork option.
Thanks!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A57453)
(1) HD 24ft Free...
2011 Toyota Prius Hatckback (A56859)
2011 Toyota Prius...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2015 Ford Explorer AWD SUV (A56859)
2015 Ford Explorer...
2015 Chevrolet Cruize Sedan (A56859)
2015 Chevrolet...
