Max 25 belt
/ Max 25 belt #1
Pitch1
Finger Lakes , NY
Max 25
Does anyone have a cross reference# for the MAHMX60 deck by Amerequip on a Max25. Part# 012763. Lowest price I find is 102 bucks without shipping. I know that their is a lot of OEM profit in that figure. Hoping someone can help me do better!
/ Max 25 belt #2
If its a single belt you can probably get the replacement from McMaster Carr for about 1/2 that.
/ Max 25 belt
Yes I know that there will be many sources that will be cheaper. My problem is that it is broken with a chunk missing and the numbers are worn off. The Mahindra or Amerequip is an internal part 3 and useless for cross reference
/ Max 25 belt #4
If you can pull back the tensioner and thread the old belt on its operating route you can get a pretty good idea of the outside length that will work.
larry
/ Max 25 belt #5
You need two basic measurements. the width of the flat side of the belt and the outside diameter. I just had to replace 2 large industrial belts on a shredder (178" OD) turns out amazon had the gates part number the cheapest. I took the vbelt supply part # over to gates website and crossed it.
/ Max 25 belt #6
You mean outside length. - Circumference.
/ Max 25 belt
For future reference if anyone has need, the belt for MAHMX60 deck, item # 35 in the mower manual part#012763 is a 134" belt which is a B131. OEM is a bit over $102.00 without shipping from online dealers,is $39.99 at NAPA.
I am sorry dealers, but OEM profit adding is way out of line, and I need to take care of myself first!
/ Max 25 belt #9
Thanks for posting back with the belt size, I bet this will help many ppl in the future :)
/ Max 25 belt #10
I have gone through this same process for this very same belt. NAPA could not cross the Mahindra part number and they did not carry the 134" industrial belt, but I was able to order it. So with a little more research for a higher quality agg belt we came up with the Gates Bladerunner part number 6485BR. This is a better belt for this mower application than your typical industrial/automotive belt. Please note this belt is 133.38 Inch O.D. though. My price $31.77.
/ Max 25 belt #11
As a follow-up, to this post... I was recently in need of replacing this belt and used this new BladeRunner Belt. Unfortunately I must report that this belt is too short! I was able to make work for now by skipping one of the center idler pulleys but I don't like how little belt wrap there is in the front spindle pulley.
The good news I was able to find a B131 in Kevlar for $29.35 here:
B131K Wrapped Kevlar V-Belt - $29.35
Im ordering a couple and see how it goes.
Woods: 18879
Cub Cadet: 954-04077
A&I Products: A-954-04077
Farm and Turf Products: P-954-04077
/ Max 25 belt #12
What has your experience since been with the off-the-shelf blue kevlar belts? We've tried those on our old Ford LGT14D, and they always had a relatively short life compared to the OEM belt. Granted, the AME deck on the Mahindra runs a lot cooler, but I'm curious what your experience has been.
Also:
It seems a Gates BladeRunner 6778BR would be a better fit than the 6485BR (134" outside, B-section). They're not as common, but can be found for about $60. I was thinking of trying one.
/ Max 25 belt #13
Well... As a matter of fact, I am still running that same Bladerunner belt since I posted that! Even though I re-routed the belt, all is good still and I mow A LOT!
/ Max 25 belt #14
Well that's certainly good to hear. I've been busy trying to find alternates for maintenance parts on the Max25, and having any confidence in an alternate belt is a huge relief. Thanks.
Now if only I could find alternates for the hyd/trans filters...
/ Max 25 belt #15
My belt broke and I made the mistake of ordering the AME 012763 belt from 4mymahindra.com The belt was over $200. When it arrived I found the belt was not an original Mahindra belt but one produced by A&I product part # B133k. I am fine with the A&I belt its the up charge that 4mymahindra.com made. If you order the belt straight from A&I it only cost $49.88 plus shipping vs $200.
B133K Aramid Blue V-Belt (5/8" X 136" ) | AllPartsStore
/ Max 25 belt #17
A bit of an update:
The bladerunner belts seem to be working okay so far. Lost a couple due to idler bearing failures, but they're definitely more durable than the plain blue belts. Compared to the OEM, they seem to be a bit tighter when new. They do seem to stretch after a while, but not much. An extra inch might be a good thing for spindle bearing life, and a bit less of a wrestle to install. That said, at 2000h, I can't exactly expect the spindles to last much longer anyway.
/ Max 25 belt #18
i bought my replacement belt for 4.65 from v-belt guys, it's the correct length and width, but i can't find any directions for putting it on
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
7102 (A61567)
7102 (A61567)
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
2009 GMC Sierra 2500 HD Pickup Truck (A61573)
2009 GMC Sierra...
2025 IRANCH IRLMB Mixing Bucket Mini Skid Steer Attachment (A61572)
2025 IRANCH IRLMB...
1999 GMC C7500 Dump Truck (A61573)
1999 GMC C7500...
