Comparison Home Stand By Generators
/ Home Stand By Generators #141
Cost is always a consideration... at least with me.
Heck, might as well go on vacation if the power is out if cost isn't a factor.
Moderation generally is the best approach for me.
Having the ability to cover essentials is great... that is doing better than 98% of the public around here.
Thanks Moss for crunching the numbers.
/ Home Stand By Generators #142
Yeah, I was just trying to figure out how much something like a 20KW generator was going to cost and operate on each of the three most popular fuels. Not begrudging anyone who enjoys 24/7 power up. More power to you.... pardon the pun. :p
/ Home Stand By Generators #144
7 gallons per hour seems like is a LOT of energy. My V8 pickup uses 4 gallons per hour at 70 MPH on the freeway.
/ Home Stand By Generators #146
I was not happy with those numbers, either, that's why I went looking. I'd be real happy if someone could post some numbers about LP.
/ Home Stand By Generators #147
I stand corrected... the fine print is litres per hour.WHEW!!! Gallons per hour is considerably less. I'll post the corrected numbers shortly.
/ Home Stand By Generators #148
Corrected numbers for gallons of LP per hour( not liters).
Numbers were for litres per hour, not gallons per hour. So the real numbers are below...
Real LP numbers are 1.89 gallons per hour. WHEW! That's better
1.89gph * $2.41/gallon = $4.55/hour * 24 hours = $109.00/day... That's better!!!
$765.00 per week at half load.
2.9 gallons per hour at full load * $2.41/gallon = $6.99/hour * 24 hours = $168.00 per day.
$1174 per week!
/ Home Stand By Generators #149
Did you once have a job refueling Air Canada jetliners? :)
Gimli Glider - Wikipedia, the free encyclopedia
The Gimli Glider is the nickname of an Air Canada aircraft that was involved in an unusual aviation incident. On July 23, 1983, Air Canada Flight 143, a Boeing 767-233 jet, ran out of fuel at an altitude of 41,000 feet (12,000 m) MSL, about halfway through its flight originating in Montreal to Edmonton. ...
... Fuel loading was miscalculated due to a misunderstanding of the recently adopted metric system which replaced the imperial system.
Bruce
/ Home Stand By Generators #150
So it seems that NG is cheaper than diesel in the summer.
At half load, diesel is $588/week and NG is $467/week.
In winter, diesel is still $588/week, and NG exactly the same.
LP is $765/week at 1/2 load if you bought fuel in the summer. If you have to refill your tank in winter, it could cost a dollar/gallon more, so, you're looking at $1114.00 per week at 1/2 load.
That's considerably more that diesel or NG.
/ Home Stand By Generators #151
Bruce
Actually, yes...sort of... :laughing: I used to work at the airport refueling airplanes and we had some Canadian aircraft from time-to-time.
/ Home Stand By Generators #152
Bruce
Great story! Thanks!
Here's the part I like... the pilot got demoted and an award for outstanding airmanship!
"Following Air Canada's internal investigation, Captain Pearson was demoted for six months, and First Officer Quintal was suspended for two weeks. Three maintenance workers were also suspended.[9] In 1985 the pilots were awarded the first ever Fédération Aéronautique Internationale Diploma for Outstanding Airmanship.[10] Several attempts by other crews who were given the same circumstances in a simulator at Vancouver resulted in crashes.[11] Quintal was promoted to captain in 1989, and Pearson retired in 1993.[12]"
/ Home Stand By Generators #153
Thought I would finally chime in. Use a small gas gen set for the house power isn't out that often and can make do unless winter without it except for the fridge and freezer.
Now the farm has an 80kw diesel generator. 160 hp 1800rpm Cummins. 400 amp auto switch gear that senses off both legs. I haven't run mine during a long outage. But my BIL has the same gen set. He got to run his during the '09 ice storm. 24/7 for 3 weeks. ( I didn't own my farm during that time.) Said his averaged about 40 gal a day. Just estimating load at about 25-30%. Even during summer our loads don't go over about 60%. But need the extra for startup draw.
We keep block heater plugged in 24/7/52. And a battery maintainer. New battery every 2 years. And annual fluid and filters. New anti-freeze every 2 years also with hoses.
/ Home Stand By Generators #154
They made a movie out of the Gimli story...
/ Home Stand By Generators #155
I'd venture to say that most, if not all, home stand by GenSets rarely ever run at full load. When they size them it's for worst case scenario. Now that's not saying they don't spike up close to full load at times, but I doubt if it's more than momentarily.
When you lose power (at least in this house) you kind of automatically go into conservation mode. Of course there are some things that you have no control over.... well, septic pump, fridge/freezer, etc., you get the picture. But a pretty much the rest of the house you do. The odds of all of the above starting at the same time are remote if any. So you'll most likely be running 1/2 load 90-95% of the time. I know around here when we're off the grid (not that often) and running stand-by, when an appliance kicks in, the GenSet don't even change pitch. When your taxing the smaller units you'll know it.
I think some of you are confusing cost per hour with peace of mind. I can deal with the cost per hour or I would not have installed the GenSet to start with.
You can't put a cost on Peace of Mind...... Priceless!
/ Home Stand By Generators #156
Thanks for that. I wondered what happened to them.
/ Home Stand By Generators #157
We were kind of stuck: the NH house has electric stove, baseboards, water heater, clothes dryer, and well pump. We wound up with a 14kw Kohler.
Thr cost to switch over the appliances was going to be much more than anything we would save from a smaller genset. Even the Rinnai needs electrical power and frozen and burst pipes can create immense damage.
Our house in Boston is natural gas and we can run the heat and fridge on an EU2000, and daisy chain a second one for more power. This allows us to run with minimal fuel consumption. We're probably the only house in the neighborhood set to run on generator power.
/ Home Stand By Generators #158
We have a Kohler RES17 (17 Kw) running on propane. The spec sheet indicates that it consumes 7.7 lbs./hr. at 50% load and 6.6 lbs./hr. at 25% load. This translates to 7.9 litres/hr. and 6 litres/hr., respectively, and at $.60 per litre translates to $4.75/hr. at 50% load and $3.60/hr. at 25% load, or $798 and $605 per week, respectively. I really doubt that the average homeowner would even run this generator at 50% load for long periods of time, however, as we got along nicely with a 5500 watt gasoline model before. In fact, the only reason we have a big one now is that we have a hot tub.
Hope this helps.
/ Home Stand By Generators #159
check those are more realistic numbers. This means my 11 kw runs 1.2 gph on low load and 1.8 on full which is a little less than your 17 kw which sounds pretty darn right. Never had a gas generator. I do know quite a few and they agree that if they could afford it they would definitely buy a propane standby generator any day just for the convenience of the automatic transfer switch and peace of mind.
/ Home Stand By Generators #160
Propane or Natural Gas does have advantages in the fuel department... nothing to get state and with Natural, it's a simple matter if it is already onsite.
The Hospital had Natural Gas unit back in the 80's to 1995.
We had to get rid of it unless we add very costly and large Natural Gas storage onsite due to supply concerns in the aftermath of an earthquake.
Diesel made the most sense because we could keep a supply on had and refueling if necessary could be done with 5 gallon containers...
Any fuel type can have auto transfer switch...
John Deere Hood Guard (A63116)
John Deere Hood...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2010 Kenworth T3 Class 7 Flatbed, 4x2, w Tuck-Under Liftgate (A63118)
2010 Kenworth T3...
2025 72in Hydraulic Grapple Rake Skid Steer Attachment (A61572)
2025 72in...
