Comparison Home Stand By Generators
/ Home Stand By Generators #121
The cost to run it is minimum when compared to the initial cost of the unit and the comfort it provides. If running cost is an issue, go cheap as you want. Heck, get grandpa to peddle the bicycle like on the Honda commercial.
Life is about choices, I made mine on whats best for the family. I've heard a lot of people say "I wish I'd spent a few bucks more and got something better". But I've never heard them say "I wish I'd gone cheaper".
Bottom line: buy what the budget can afford.
/ Home Stand By Generators #122
Its nice to know some folks don't have a budget. :laughing:
In all seriousness, I understand the need for sump pumps. And I enjoy convenience. I'd just like to know if anyone has figured out how much it would cost to run a large automatic generator 24/7 for a week, instead of everyone saying "who cares?", that's all. ;)
Well, when the day comes that I run my generator 24/7 for a whole week then I will let you know how much it cost me. Until then I just use whenever I need it. Like I said I am not worried about the price who cares lol
/ Home Stand By Generators #123
I cringe anytime I hear someone say they aren't concearned with how much something will cost.
Looking at this chart for diesels....
Approximate Diesel Generator Fuel Consumption Chart
A 20kw generator at 1/2 load consumes about a gallon per hour. So, 24 gallons of diesel per day. Let's say you get diesel for the price of $3.50 (based on below average prices currently, today, in my location).
24 * $3.50 = $84.00 per day in fuel.
$84.00 * 7 days = $588.00 per week.
At full load, its 1.6gph.
38 gallons per day * 24 hours = $134.00 per day, or $940 per week.
Another diesel chart.
Diesel Fuel Consumption Chart
Now lets look at natural gas/LP.
Can anyone find a general fuel consumption chart?
I can't, so here's a link to a 20kw Generac unit.
http://kt4qw.com/generator/generac20kw.pdf
Fuel consumption...
Natural gas:
1/2 load = 206 cubic feet/hour, or 4944 cu ft/per day, or 34,608 cu ft/week.
Full load = 294 cubic feet/hour, or 7056 cu ft/per day, or 49,392 cu ft/week.
With Natural gas prices fluctuating between $10-$17 per thousand cubic feet over the last 5 years
See chart U.S. Price of Natural Gas Delivered to Residential Consumers (Dollars per Thousand Cubic Feet)
Let's use $13.50/thousand.
1/2 load = 4944 cu ft/day / 1000* $13.50 = $66.74 per day, or $467.00 per week.
Full load = 7056 cu ft/day / 1000 * $13.50 = $95.00 per day, or $667.00 per week.
Should your power go out in winter, it's more likely to be $17 per 1000 cubic ft.
At those numbers,
1/2 load = $84/day or $588/week.
Full load = $120/day or $839/week.
Now look at LP...
EDIT EDIT EDIT...
Numbers were for litres per hour, not gallons per hour. So the real numbers are below...
That same NG generator using LP uses:
1/2 load = 7gph.
Full load = 11gph.
According to this chart, current propane U.S. price is $2.41/gal.
This Week In Petroleum Propane Section
If it follows annual trends, it will go up at least a buck a gallon by February, so buy propane now.
Let's figure it at the current price.
7gph * $2.41/gallon = $16.87 per hour * 24 hours = $405/day! That doesn't seem right???
But this chart says it costs about 3X more to get the same BTUs out of propane as it does natural gas. http://www.knoxenergy.org/uploads/File/Alternative Energy Conversion Comparison.pdf
YIKES! Its over $400/day on propane at 1/2 load! That can't be right can it? $2800/week???
Real LP numbers are 1.89 gallons per hour. WHEW! That's better:ashamed:
1.89gph * $2.41/gallon = $4.55/hour * 24 hours = $109.00/day... That's better!!!
$765.00 per week at half load.
2.9 gallons per hour at full load * $2.41/gallon = $6.99/hour * 24 hours = $168.00 per day.
$1174 per week!
So I googled propane VS natural gas and yep, its at least double and more likely triple the cost to use propane VS natural gas. More research is required!
Anyhow, before anyone gets any generator, you should really figure out what it really going to cost you when it runs... is it worth $500-$600-possibly thousands per week? Are you prepared to go away on vacation and come home to a multi-hundred possibly multi-thousand dollar fuel bill?
/ Home Stand By Generators #124
Well, when mine was first installed, I looked at the consumption listed in the manual and figured the tank they installed would last 2.5 weeks at 100% load. The tank costs about $1000 to fill in the winter or about $750 in the summer.
Thanks. :)
/ Home Stand By Generators #125
Who cares about the cost..... that about says it. :rolleyes:
Again, has anyone run one of these large generators for a week 24/7 and how much did the fuel cost?
Can't report first-hand, but a friend has a whole-house propane generator with auto-start that ran continuously for 4 or 5 days during a major summer outage awhile back and ran through a full 500 gallon tank (which at 80% typical max fill is 400 gallons) in that time. I'm guessing her home is around 3,000 or 3,500 sq. ft. Hard for me to believe that's a typical rate of use, even with central air, but I almost fell over when she told me about it. :eek: Her genset is 30 KW, which is way overkill, IMO. Our house is nearly 3 times that size, and we got along fine running a little 8250 W gas generator 10 to 12 hrs/day. That of course was without the air conditioning, which eventually got uncomfortable, but we slept in the cooler basement and I'll take that trade off. :)
/ Home Stand By Generators #126
Those prices make me cringe too cause they are outrageous. My manual says 1.2 gph at 1/2 load and 1.8 at full load sure is far away from the 7gph-11gph. Like I said I will find out for sure when I get a long black out.
/ Home Stand By Generators #127
Hi Moss,
I don't have a large generator, just a little 5 kw, but it powers the circuits we need, e.g., sump pump, well, furnace, frig, etc. During the ice storm earlier this year, we ran the generator 24/7 for about 4 days. 5 gallons of gasoline lasted approximately 10 hours, or .5 gallons/hour. At today's prices, that's .5 x $3.00 = $1.50/hour.
$1.50 x 7 days x 24 hours/day = $252.00/week.
/ Home Stand By Generators #128
If she has a 30kw GenSet, she also has a at least a 4 cyl water cooled industrial engine in it. That's like comparing apples to oranges when your talking the air cooled units we've been kicking around. That's a whole different animal.
/ Home Stand By Generators #129
Fuel consumption...
Natural gas:
At those numbers,
Now look at LP...
1/2 load = 7gph.
Full load = 11gph.
I'm not buying your consumption numbers or price for NG or LP. A gen set may run 12-72 hrs a year under load so the "diesel" savings will never break even with the higher price of the diesel generator. As for cold weather starting. A LP or NG will roar to life while the cold diesel just makes bad sounds as the battery dies. Have you figured the price of block heater power all winter ?
/ Home Stand By Generators #130
If you really want to know how much it costs DO the math.. From .75 gph to 2 gph.. and for as many hours or days you want...
As for the budget sometimes it gets busted ,, If the power is out I'm out helping those who don't have power so the wife is home alone and a happy wife is a happy life,, I have a very happy life :rolleyes:
I see you did the math,,hmm 7gph Who out there is running a 50kw gen set at full bore ????
/ Home Stand By Generators #131
Sounds like you're getting a nice unit that you'll be very happy with. :thumbsup:
/ Home Stand By Generators #132
Lets do a different type of math here,, I'll price up a 8kw Isuzu unit from CMD,,
1 Unit alone $6,600
2 Building to put it in "because it doesn't come with an enclosure " $2,000
3 Thru wall adapter $69
4 2 wire start "needed for the auto transfer switch" $425
5 Auto transfer switch $1295
6 19 gal. fuel tank.. "kinda small if you ask me" $375
7 Mis. parts and pieces " batt charger,, block heater,, exhaust piping " $200 or so
Lets see where are we,, Oooo about $10,700
I can buy a propane unit with all that for about $2,500 or maybe 2 of them because it's going to fail way before the diesel unit fails.. Ooo but I have a 4year warrantee.. Lets see what did they have,, 1 year,, sorry.. and anyway that leaves me with $5,000. left over to buy fuel.. lol
All in fun..:dance1:
/ Home Stand By Generators #133
I have a 18 kw whole house, wish I had bought a 25 kw. 1000 gal tank of propane I own and 500 leased. I fill up once a year around July. I believe if needed it would run for 3 weeks if early in the year. If I need it longer than that I will move out of state and come back when things are better. With well water only I don't really care what it costs.
Good Luck
/ Home Stand By Generators #134
This thread really has me scratching my head. Not about the tech data, but the human factors.
Unless it's somebody I know personally (meaning, in the real world) and they're depriving their kids of food/shelter/clothing, I have zero time to get spun-up about how other people spend their money.
There's some data here (why I've stopped by a few times), but also tinges of the Conventional vs. Synthetic Oil and Gas vs. Diesel Pickups diatribes that get rolling in other threads. :rolleyes:
Also some humour, not all of it intended. (I'm only using a blunt stick 3PT, so please don't take offence.... but your comment about someone's excessive spending, typed while sitting in a 10,000 sq ft house seems a bit ironic).
People have different spending priorities . Accept that, and life will get better. :thumbsup:
Rgds, D.
/ Home Stand By Generators #135
Yeah, my eyeballs popped on that too, that's why I had to ask. LP power was outrageous at the consumption rate listed in those specs.
/ Home Stand By Generators #136
Hi Moss,
Thanks. :thumbsup:
/ Home Stand By Generators #137
Well I'm not selling them, so you're all good there.
/ Home Stand By Generators #138
Go back and re-read that post.... That 7gph is for a 20KW at 1/2 throttle using propane.
/ Home Stand By Generators #139
Good Luck
1500 gallons of propane at $2.50 per gallon = $3700 for fuel for three weeks and you don't care what it costs? :rolleyes:
/ Home Stand By Generators #140
When the power goes out I get a little generator running, get the cord out ready for the sump pump. I give the freezer a hotshot twice a day, then the refrigerator too, and charge laptop & phone batteries whenever the generator's running. My girls run around and scrounge up all the candles in the house and set them around. They make me a cup of tea and ask for a fire in the woodstove. We dig out our books. It's a special time; actually look forward to it.
Luckily we don't have power out for more than a few hours. Very seldom more than a couple days. Aside from the last outage, (my generator had a little problem starting...) , it sounds like we have it pretty easy.
2015 Ford F-550 Service Truck (A61568)
2015 Ford F-550...
2006 Vermeer BC1000XL Chipper (A61166)
2006 Vermeer...
FORD 3000 TRACTOR (A62130)
FORD 3000 TRACTOR...
Genie Z60 Articulated Boom Lift (A64047)
Genie Z60...
GE WASHER & DRYER (A62131)
GE WASHER & DRYER...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
