Kubota's next BX generation. 2015?
/ Kubota's next BX generation. 2015? #1
Iaco
Parkton, MD
None
I am on the market for a BX25. Effectively this design is 2 years old. Thinking to hold assuming next generation is coming next year (2015). What are your thoughts?
/ Kubota's next BX generation. 2015? #2
I am on the market for a BX25. Effectively this design is 2 years old. I bought my first BX25 Feb 2010Thinking to hold assuming next generation is coming next year (2015). What are your thoughts?
My thoughts are that it's not going to happen. This BX25d is a new this year update. The BX23 was around 11 years ago and many years later went to BX24 (Bought a BX2350 June 09 which is the BX24 series) which was their bad series with plastic body parts and abrupt stop in reverse and a few years ago at least prior or in 2010 I bought one that year Kubota went to the BX25 which has this year evolved into the BX25D which I believe will be around for at least 5 more years but what do I know?:D I believe you will be disappointed following your logic even if the do a BX26 it will just be a BX25 with a different series number, probably cost more since they go up in cost every year which pulls the older models up in value to so waiting to me makes no sense. Again my :2cents:
/ Kubota's next BX generation. 2015? #3
/ Kubota's next BX generation. 2015? #4
I think right now, their engineers are flat out on migrating everything over 25 hp to being final tier 4 compliant. I don't think they'll be making major changes to the BX line for 2015, but you never know. Was posted here that the dealers are up on the changes for next year, but no mention of a new BX series. There is an auto-connect MMM deck coming, however.
/ Kubota's next BX generation. 2015? #5
I have a kubota BX2370 2013 and its great, you would love the BX25 but if it has the old gauge cluster that just shows the engine temp and fuel meter and rpm while running and not hours while running don't get it. I have the gauge cluster that shows rpms, fuel meter,engine temp and hour meter all while running and i love being able to monitor my engine while running to see whats going on.
The auto-connect MMM deck is one of the features I will like to be added to the BX series. Any solid leads when Kubota will come out with one? Thx
/ Kubota's next BX generation. 2015? #7
Already in production. Barlows said he has 3 coming and he doubts many people will buy them.
/ Kubota's next BX generation. 2015? #8
If the BX tractors start getting any more capable, it will cause a chain reaction of all series needing a bump as well. Which I'm sure is what they're moving towards eventually, but those BX25's are pretty awesome as they are. Dad has a 2005 BX23 and it is simply amazing for it's size.
In my opinion, about all they can change on the BX series would be creature comforts, possibly tilt steering, L/R braking, 3pt upgrades like pos. control, telescoping end links, ratcheting lift links, etc. Maybe they already have some of those, I haven't checked. I would think the BX25 is nearly as capable as the B2320 in most ways.
/ Kubota's next BX generation. 2015? #10
The auto-connect MMM deck is one of the features I will like to be added to the BX series. Any solid leads when kubota will come out with one? Thx
I was at a Kubota dealer a couple of days ago test driving the Bx2370. The salesman told me the new Bx's will have an optional drive over MMM this spring.
He told me he was just at a regional meeting and had a brochure regarding the drive over decks, which he made me a copy of. The model numbers of the decks are:
RCK60D-26BX
RCK54D-26BX
He said they option will cost approximately $500 more than the regular MMM and that he ordered several of the Bx series with drive over decks for this coming spring.
Here is the brochure: img002.jpg
/ Kubota's next BX generation. 2015? #11
Has anyone ever tried driving over the current decks? I don't know if it would damage it. They are built very well.
/ Kubota's next BX generation. 2015? #13
500 bucks for autoconnect? Ouch...
IF you are removing/installing the deck often, AND auto connect works like it should, I don't see why it wouldn't be worth that or even more.
/ Kubota's next BX generation. 2015? #14
May destroy the plastic covers on the old decks if you drove over them, plus still stuck connecting that darn PTO shaft. Thats always been the hard part for me. Be nice if they made a kit to convert the old deck to the new style.
/ Kubota's next BX generation. 2015? #16
Just traded my BX25 in on a new BX25D-1. 832 hours were on the machine traded. No problems, did all the maintaining myself except the dealer did the 800 hour valve clearance check. Sadly I let someone use my BX25 and in one afternoon more damage was done to it than what I had ever done to the tractor. I learned a lesson about letting someone borrow anything of mine. Only 4 hours on the new tractor. This machine stays home now.
/ Kubota's next BX generation. 2015? #17
That is rough - did the person at least cover the damage?
/ Kubota's next BX generation. 2015? #18
The fellow paid for parts. I swallowed the labor since it was my fault for loaning the tractor out. Mechanically the tractor was sound, but the loader arms had chains wrapped around them secured to the front bucket welded brackets. Bent the side of the loader bucket, and bent the bucket brackets. Hood had a 4 inch dent right over the front reinforcement, both headlight lenses gouged. One tire was cut. Left inner tire rod end boot smashed. A clean hole punched in the grille. The guy tried to move a metal scrap pile with the tractor. 753 dollars worth of damages. All repairs done before the trade, but it just wasn't the same anymore. 150 bucks in parts the rest labor.
/ Kubota's next BX generation. 2015? #19
Good grief. If I were operating and did ONE of those dings I would find a better way to do stuff. I'd have "let" him pay the whole bill.
/ Kubota's next BX generation. 2015? #20
I was lucky to get 150 bucks out of the deal. Had I presented the entire bill I probably wouldn't have gotten a penny. Now that the episode is all over with and the new Kubota is in the garage my life enjoying the tractor is back on a happy trail. I lived and learned. A person has to know what a disappointment feels like before a good thing is really appreciated. Life goes on.
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2020 BOBCAT E42 MINI EXCAVATOR (A60736)
2020 BOBCAT E42...
Pallet of Iranch Hydraulic Thumbs & Mini Excavator Couplers (A60463)
Pallet of Iranch...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
2015 GENIE S-60 MANLIFT (A60736)
2015 GENIE S-60...
