Bucket Hooks Grab Hook question
/ Grab Hook question #1
iamaumnbn
Nothern, Ca.
Kubota L48
Hello,
I'm looking for idea on where to mount/weld 2 grab hooks on a Kubota 1747 bucket. The bucket has a round top edge.
If I drill the bucket to bolt on backing plates should I put a plate inside the bucket also?
Will 1/4" backing plates be sufficient?
Anyone done this or seen it done? Any help is appreciated.
The bucket is attached to a L48 Kubota. See pics.
/ Grab Hook question #2
I would use a backing plate. On my bucket I welded the hooks to a 3" by 1/2" piece of steel and then used a 3" by 3/8 piece as a backer using 6 bolts and large washers on each side of the 3 hooks. My bucket is now stronger than the tractors lift capacity.
/ Grab Hook question #7
I have that same style bucket. I used weld on hooks. I welded them directly on the edge of that angle gusset piece where the tube connects to the bucket edge. It was 3/8 thick on my bucket. Been there a long time and used hard with no problems.
Not the best pics
Edit: Found a better pic. I added the pic with the dozer track chains. They are about 1000 lbs
/ Grab Hook question #8
Thanks for all the kind words and referral's guys, but this HD style round back bucket is not friendly to the bolt on hooks-I recommend welding them on in this instance. 1/4" backing plates are perfect, we sell laser cut ones that are ready to weld, in addition to other products as well to complete this project.
/ Grab Hook question #9
I add a chunk of 1" shaft to mine so I can wrap the chain around.
/ Grab Hook question #10
You can weld a short piece of angle iron (4"x4"x1/4") from the top edge of the bucket to the gusset behind for reinforcement and then weld the grab hook onto it.
