300UGUY
Super Member
Yum! French Fries!!
bumper
Funny. But dude, you just are a little off....
Yum! French Fries!!
bumper
So, if I understand this correctly, my backhoe should stay in perfect position when unhooked to hook it back up again? That thing relaxes and uncurls in a matter of hours after I unhook it. It is Brand new, no more that 20 hours on it total.
only drawback i see is PRICE. I asked my local kubota dealer today how much for him to add one on my tractor, $1000 he said. Surely it cant be that much can it? Isnt this something i can do myself?
I spent about $1200 on the Kubota valve kit to add two valves to an L3200, one was float which added to the price. I did the labor myself. So I can see $1000 for a valve and labor being about right from a dealer.
You can go aftermarket for much less, but the integration won't be as nice as a factory kit. But that gives you options so you can find the solution that fits your wants/needs/budget.
You must have a 2013-14 model. Before that, with a little work it was possible to have an aftermarket set some what integrated and actually be in and look better than the OEM stuff that hangs off of the ROPS in regards to the earlier std L model Kubotas.
Based on what I saw in the Kubota wholegoods catalog, I believe the same kit works on all L3200-3800 models going back to the model intro (2011?), but not sure. Mine is a 2013. Older L models indeed had a much less integrated kit, and I wouldn't pay a premium for that at all.
A cylinder with leaky internal seals can drift by extending but not retracting (assuming plugged ports). It is an undisputable fact. The rod seals aren't designed to hold a vacuum, and air is easily pulled in to make up for the lost volume of the rod extending out of the cylinder.
A cylinder that leaks internally doesn't draw air in from the outside, it simply allows fluid to pass from one side of the internal seals to the other side. Nothing from the outside world is needed. So they can and will leak off in either direction, depending on where the load is.
Apologies for making the point again, but isn't the inability of the rod-side fluid to go anywhere what really holds the 3pt blower in position, freeing the rear remotes to operate the directional chute, etc. without having to switch back to the mechanical toplink?![]()
[snip]
Considering that even if the piston main seal leaked like a sieve, heck even it it was missing entirely, the cylinder would remain hydraulically locked so long as its gland seal remained intact. This, as you correctly state, is due to the cylinder's overall internal volume or fluid capacity that changes as the piston is moved due to the varying length and thus displacement of the piston rod that is within the cylinder. Since in our "locked" cylinder, this displacement or capacity cannot change, the piston cannot move so long as the fluid is not compressible, the gland seal doesn't leak, and the quick connects remain sealed.
[snip]
Hmm, I'm not following that. If the piston main seal is leaking, as distinguished from the rod's gland seal, I think the piston can, in fact, move in the cylinder. The fluid on the rod side doesn't compress, it just moves past the piston as the piston descends, simultaneously filling the void left by the descending piston. In this situation, there is no void left unfilled, so no vacuum is created that could create suction to pull outside air in from any point. Again, as you say. we are assuming no leak in the rod-side gland seal or port. If fluid can escape the cylinder through such a leak, then yes indeed, the descending piston would create an unfilled void on the cylinder side, hence suction on that side.
Thanks, now I understand how it can't move even with a leaky piston seal or no seal at all. :thumbsup:------------------------------------
The rod an cylinder are completely hydraulically locked. We cannot push the rod further into the cylinder as to do so would require that we remove some of that oil - and it's not going anywhere - no leaks. Next we try to pull the rod out - also not happening, as to do that would require we get some more oil or air inside to make up for the increasing capacity and fill the vacuum. No leaks, no movement, and all with no piston.
If you accept this theory, then it is, at least hydraulically speaking, the very same thing as my previous cylinder with no piston seal.
bumper
Except you are forgetting one thing: The gland seal is designed to retain oil under pressure, not under vacuum,
as mentioned several times above. Air will enter at the gland seal, and the rod will extend.
The scenario with blocked ports and no piston is the same as one with an "imperfect" piston seal. Even
one drop of oil per hour past the piston seal under extension force, will cause a vacuum ON BOTH SIDES
of the piston.
When a toplink cylinder is new, the piston seal is very tight, but even after a few dozen hours of use, the
piston seals get looser, and even pass a tiny bit of oil. That is all it takes for them to extend while
loaded, with the ports blocked. Also note that some gland seals are better than others at resisting
air entering from the outside.
