Battery Drain
/ Battery Drain #1
toyboyttoo
ON
john deere 4710
My John Deere 4710 (2003) had the battery replaced last November but would not hold the charge. I called the dealer who thought it might be a bad battery so we replaced it. Worked fine all summer but wouldn't start the other day. Trickle charged it, the ploughed snow for two hours. Went out this morning and dead again. Could it be another bad battery or do I have a battery drain problem. If a battery drain, where do I start? I don't want to call the dealer if I can fix it.
Thanks for any assistance
/ Battery Drain #2
Put a ammeter between the positive post and cable and see if you have a draw.
/ Battery Drain
Thanks, will try.
/ Battery Drain #4
Or a test light. If it shows a draw, I'd disconnect the positive wire at the alternator. If it doesn't show a draw, now, you have a bad diode in the rectifier bridge in the alt. It can still show a charging voltage, but it won't have the amps behind it to charge the battery. At this point if you still have a draw, hook the alt. back up and go to the fuse box and start pulling fuses, one at a time. I have found in automotive electrical the glove box or trunk lite doesn't shut off and will drain a battery in less than 24 hours. Happy hunting!:dance1: 445A
/ Battery Drain #5
Happy Hunting is right! These can be very fun and frustrating.
/ Battery Drain #6
the lamp or a ammeter should be telltale. disconnect wires till draw goes away. last thing you pulled when draw died was the culpret.
/ Battery Drain
Thanks everyone! Once I get it charged, I will plough the snow and then get it into the garage to start looking!
/ Battery Drain #8
I agree to check for voltage drain with a test light but I was taught to disconnect ground not positive cable and insert test light for ground cable to find drain.
/ Battery Drain #9
Jim, I believe it would work either way. The electrons have to make a circuit for there to be current flow.
/ Battery Drain #10
Absolutely correct!
/ Battery Drain #11
The safety police say always disconnect the negative cable first, if you don't and the wrench touches metal when any where on the positive circuit, it will draw an arc bigger than most arc welders can produce! :eek:
Also checking at the alternator cable won't show a drain any where else.
/ Battery Drain #12
Correct, and while it wont matter much on 12v, with higher ac it dc voltages its not a good idea to ever lift groun, or you might find yourself becoming ground path!
/ Battery Drain #13
Removing ground first is arc prevention, for our yes we need a closed circuit, not a disadembled one.
/ Battery Drain #14
An ammeter in series with the disconnected ground cable will show drain current flow anywhere in the positive circuit.
/ Battery Drain #15
I'm quite aware how an ammeter in series works.
typical tractor ammeter has number blocks in 10's and a few lines in between. some of these drains might be in the 1 amp range, and would be darn hard to read on a standard gauge ammeter. It it is under 10a, many VOM's have an unfused shunt you can use. or.. the test lamp works.
My post was illustration that I would not lift ground an insert it if it was a higher voltage circuit. lifting ground can make YOU ground.
For arc prevention ground is usually removed first so if your tool strikes chassis it doesn't arc.
If this was a high voltage dc or ac setup.. i'd be making sure i wasn't / couldn't be in the ground path. :)
/ Battery Drain #16
I should have said what I assumed everyone would know that I meant the ammeter in a multimeter. the one I use has a 10 amp range, then move the test lead to the mA input, where you select one of four ranges, from 200mA, down to 200 micro Amps
I would not trust a test light to show a small parasitic drain.
/ Battery Drain #17
I know voltage drain can be checked by disconnecting either battery cable then inserting test equipment BUT I was taught to always disconnect battery ground cable 1st to eliminate any chance for SPARKS(arcing) by wrench loosening positive cable accidentally touching the vehicle frame.
/ Battery Drain #18
OK, I can buy into that as always being good practice. Yes a dead short like a wrench across a battery supply can be a life changing event. A friend of mine took a telephone central office in England down by getting a wrench across the -48 volt battery supply of the Central Office. He described white hot metal near instantly and sagging and falling on to the floor. Also batteries can burst from heat and hydrogen gas production. Not a good thing to have happen.:shocked:
/ Battery Drain #19
And Oxygen production, as a water molecule is two parts hydrogen to one part oxygen.
Electrician's Mate retired, Submarine Qualified.
/ Battery Drain #20
oxygen, hydrogen, and heat, all the makings for a good bang!
2014 MAC FLAMELESS HEATER  (INOPERABLE) (A68842)
2014 MAC FLAMELESS...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Autocar...
2019 FREIGHTLINER CASCADIA 125 DAY CAB (A67714)
2019 FREIGHTLINER...
PALLET OF HEAVYEQUIPMENT PRESSURE WASHER PARTS (A68842)
PALLET OF...
2020 PETERBILT 367 (A67714)
2020 PETERBILT 367...
2012 MACK GRANITE-GU713 (INOPERABLE) (A67714)
2012 MACK...
