Ford 9N 3-point problem
   / Ford 9N 3-point problem #11
wow, you resurected a 3 year old post to post your new question.
Many people will likely NOT see it.
In any case. you say you have rebuilt your pump, including a new relief valve.
have you pressure tested it? IE... chain lift arms down and plumb a gauge into the test port at the rightfront of the base of the pump using an ORB fitting. . that port is NOT pipe thread.
My guess is you are not building pressure int he pump due to ill fitting parts valves/springs..e tc.
   / Ford 9N 3-point problem #12
I rebuilt one of those pumps once and I don't remember if it was on the 8 or the 9-N that I owned. ???
That Scotch-Yoke pump is the WEIRDEST hydraulic pump that I have ever seen!! What were they smoking??
   / Ford 9N 3-point problem #13
There is a threaded port at the right front of the pump that is connected to the tube that feeds the cylinder. can i pressure test it from there? and how much pressure should it have?
   / Ford 9N 3-point problem #14
Just like my post #11 said... ( i'll re-quote it here since it was not read or ignored )
1500-1700-psi is expected pressure.
   / Ford 9N 3-point problem #15
Chances are the control valve is not moving properly when commanded by moving the lift lever up. The valve could be sticking or the "T" shaped valve actuator rod is broken or is not in the sockets on the "H" control fork. I'm assuming you have no leaks in the system and that sounds like a good assumption since you say it drops 3-4 inches in 24 hours. That implies pretty low system leakage. Also see my post above.
2012 Ford F-350 4WD Pickup Truck (A50860)
2012 Ford F-350...
Utility Trailer (A50860)
Utility Trailer...
2017 Chevrolet Colorado Ext. Cab Pickup Truck (A48081)
2017 Chevrolet...
2021 Delta Redirective Crash Cushion 75000 (A48081)
2021 Delta...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
