Shackle for Drawbar?
/ Shackle for Drawbar? #21
The screw in pins are more for cases where you attach/detach often, like for logging or towing, and you need to pay attention to them -- over long term use, any swiveling action can start to loosen the threads. They generally have a bigger diameter pin for the same size clevis.
I have one that I use for logging or if I need to pull someone out of the mud (usually can attach clevis to teeny factory tow hooks, and then get a tow strap through the clevis). But for long term "install and be done with it" use on a tractor, I think pin with clip is the way to go. The factory drawbar itself is usually held in with a pin/clip, though it may be a different style.
/ Shackle for Drawbar? #22
I'll adopt the TBN solution: straight with pin, straight with screw pin, Twisted, and chain hook. Need a hitch pin too!
TBN says you also need these! :D
Chain Grab Links | Electric Chain Hoists| Northern Tool + Equipment
Chains, Cables & Grapplers | Forestry & Woodcutting | Husqvarna Chainsaws, Outdoor Power Equipment and Tree Care Supplies from Baileysonline
Ba Products N711 8E 2 5 16" G70 Chain Adjuster Grab Hooks on Pear Link One PA | eBay
/ Shackle for Drawbar? #23
Love choker hooks (middle pic). I found a place online that sells them for about $6-7, which is a deal.
/ Shackle for Drawbar? #24
If you will be driving through any weeds or tall grass, put the pin on from the bottom so the clip will be on top and protected. I lost several clips while bush hogging before I started installing it this way.
I do it the same way! And the drawbar pin itself too! Too much pin snagging brush around here.
/ Shackle for Drawbar? #25
A box full of misc hooks, loops, shackles, etc. is essential for any tractor owner. Don't just stop with one, get a bunch, you'll never know why you need it until you need it! ;)
/ Shackle for Drawbar? #26
Link?
/ Shackle for Drawbar? #27
A problem with loose pin shackles compared to screw pin shackles, is that the loose ones can more easily bend open if you happen to get a hard side pull on it. Only the safety pin in shear stops the spread.
Bruce
/ Shackle for Drawbar? #28
Bruce
Well, now, see you taught me something there. Of course it makes perfect sense, but I had not thought about it before.:thumbsup:
True enough, but the 7/8" shackle I bought has a safe working load limit of 16,000 lbs. I don't think I'll be seeing any distortion......
Anchor shackles on boats are virtually always the screw type, and the screw is ordinarily safety-wired closed, or at the very minimum has a cable tie through it.
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2 Rolls of Screen (A62613)
2 Rolls of Screen...
LS XP8084 (A64126)
LS XP8084 (A64126)
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
Caterpillar TL9430 (A64126)
Caterpillar TL9430...
