Shackle for Drawbar?
/ Shackle for Drawbar? #21
The screw in pins are more for cases where you attach/detach often, like for logging or towing, and you need to pay attention to them -- over long term use, any swiveling action can start to loosen the threads. They generally have a bigger diameter pin for the same size clevis.
I have one that I use for logging or if I need to pull someone out of the mud (usually can attach clevis to teeny factory tow hooks, and then get a tow strap through the clevis). But for long term "install and be done with it" use on a tractor, I think pin with clip is the way to go. The factory drawbar itself is usually held in with a pin/clip, though it may be a different style.
/ Shackle for Drawbar? #22
I'll adopt the TBN solution: straight with pin, straight with screw pin, Twisted, and chain hook. Need a hitch pin too!
TBN says you also need these! :D
Chain Grab Links | Electric Chain Hoists| Northern Tool + Equipment
Chains, Cables & Grapplers | Forestry & Woodcutting | Husqvarna Chainsaws, Outdoor Power Equipment and Tree Care Supplies from Baileysonline
Ba Products N711 8E 2 5 16" G70 Chain Adjuster Grab Hooks on Pear Link One PA | eBay
/ Shackle for Drawbar? #23
Love choker hooks (middle pic). I found a place online that sells them for about $6-7, which is a deal.
/ Shackle for Drawbar? #24
If you will be driving through any weeds or tall grass, put the pin on from the bottom so the clip will be on top and protected. I lost several clips while bush hogging before I started installing it this way.
I do it the same way! And the drawbar pin itself too! Too much pin snagging brush around here.
/ Shackle for Drawbar? #25
A box full of misc hooks, loops, shackles, etc. is essential for any tractor owner. Don't just stop with one, get a bunch, you'll never know why you need it until you need it! ;)
/ Shackle for Drawbar? #26
Link?
/ Shackle for Drawbar? #27
A problem with loose pin shackles compared to screw pin shackles, is that the loose ones can more easily bend open if you happen to get a hard side pull on it. Only the safety pin in shear stops the spread.
Bruce
/ Shackle for Drawbar? #28
Bruce
Well, now, see you taught me something there. Of course it makes perfect sense, but I had not thought about it before.:thumbsup:
True enough, but the 7/8" shackle I bought has a safe working load limit of 16,000 lbs. I don't think I'll be seeing any distortion......
Anchor shackles on boats are virtually always the screw type, and the screw is ordinarily safety-wired closed, or at the very minimum has a cable tie through it.
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
John Deer MX8 Bush Hog, 3pt, Dual Gear Box, PTO (A62679)
John Deer MX8 Bush...
2010 Case 580N (A60462)
2010 Case 580N...
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
EZ Trail 3400 (A63688)
