JD 4120 Transmission issues
/ JD 4120 Transmission issues #1
dunhamg
Waterville, IA
LX 279, 4120
Anyone else ever have this happen with their 4X20 tractor with a PowerReverser Transmission? When I am in C range either 3rd or 4th and get over about 1500 rpm's I get a terrible grinding noise from the transmission. Slow down and it goes away. Tractor has about 300 hours on it and a month out of warranty. Just happened Saturday driving over to the neighbors to help him unload a feed bunk with the loader. Happens both in 2wd and 4wd. Waiting for dealership to come out and take a look at it tomorrow.
Thanks,
Grady
/ JD 4120 Transmission issues #2
I am having this same issue on my tractor Have you heard what the cause was mine has 1440 hrs
Thanks in advance
/ JD 4120 Transmission issues #3
:welcome: to TBN
You may want to send a PM to member dunhamg to get some feedback, hopefully here so others will learn what was the cause of the grinding noise he experienced.
:welcome: to TBN
Sorry, apparently when I replied earlier it didn't post.
It was a loose hose clamp on a hydraulic return line and apparently it was sucking some air and the hydraulic pump is what was making the awful racket. The dealer found it and had to replace a few o-rings in the pump, but otherwise it was good to go. Ended up being a $300 bill for the fix.
Grady
/ JD 4120 Transmission issues #5
Grady
Thanks for the update. :thumbsup:
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
18ft Suzuki Lighted Sign (A65579)
18ft Suzuki...
Farm King 300-bushel Gravity Wagon (A66408)
Farm King...
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
Wilbeck 2109 12ft. Digger Disc Chisel (A65640)
Wilbeck 2109 12ft...
Landhonor Quick Attach Log Grapple (A66285)
Landhonor Quick...
