5085M better pic's
   / 5085M better pic's #11
nice looking tractor.
   / 5085M better pic's #12
I like it too, not many open station tractors that size anymore, everyone wants cabs. Both of mine are open station too.
I will be using the tractor in the woods. I will be making trails for it, but still a glassed in cab would be a waist of $$. I have already looked into a wire cab and belly pan. About 4K and 2.5K respectively. Won't be this yr.
David
   / 5085M better pic's #14
Congrats, very nice tractor! Did you want the low exhaust instead of a stack or was that what was on the lot?
I wanted the horizontal exhaust. I ordered this tractor with what it has, was very surprised it came in 30-days. I wasn't able to look at an M series, they only had D & E's on the lot. Not many buying the M because of the extra $$ and not thinking it's worth it. If they would have one on the lot that people could compare, they would sell more.
David
   / 5085M better pic's #16
David
I use my 6415 in the woods too. I am sure I got a deal because it did not have a cab, this size everyone wants cabs. . I want the horizontal exhaust too. I'll have to buy thru parts department
Well, It finally showed up in my yard. Haven't got any good pic's yet.
David
Is there a gremlin on this site?
Lets try these. In the woods by it self and then with the other equipment.
   / 5085M better pic's #19
Very nice! Congrats! Are the rears filled? The loader will toss the rear-end of my 75M like a rag doll (450lbs wheel wts) without a rear attachment.
Also, noted that you found a manufacturer for a belly-pan. Do you have their info? Thanks.
AKfish
   / 5085M better pic's #20
Just what I thought your loader lines are tight to you loader mine loop way up. I spoke with my JD dealer about it and he said it was normal but all the pics I see there is no extra hose. IMG_2565[1].jpg
Case 721B (A47384)
Case 721B (A47384)
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
2013 INTERNATIONAL 4300 26 FT BOX TRUCK (A51222)
2013 INTERNATIONAL...
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
