New cheap saw
/ New cheap saw #1
Kenneth in Texas
Gold Member
Pretty good ways from DFW, Texas
Kubota L2800 4wd, FEL
but seems to work good, when she breaks buy another one.
/ New cheap saw #2
That's the 50cc model 20" correct?
I have the 42cc model 18". I cut 6 cords per year for the last 6 years with it. Never had the spark plug out. Never fails to start or run. A little weak on 18" wood, but fine on 14-16" wood. The only problem I've had with it is the fuel line turned to mush and I had to replace that. I blame the 10% ethenol gas. (can't prove it, but fun to blame something! :laughing: ).
I think Poulan undersizes their motors for the bars they put on them. Put an 18" bar on that thing and it will be a terror. If my 18" ever dies, I'm buying the 20" like yours and putting my 18" gear on it. For the money, they are a very good deal. :thumbsup:
/ New cheap saw
yes thats the 50cc 20" bar, seems like it was an excellent price at $199 at TS, so far i really like it, has a lot of power and so far pretty easy to start. Bought it for the size engine, really didnt need the 20" bar but a 16 or 18" bar and it would be a monster.
/ New cheap saw #7
I`ve had a Poulan for the past 9 years as well as a Stihl 026. The Cheapo Poulan ALWAYS starts and is much easier to handle for my use. The way more $$ Stihl will go through wood like a beaver on amphetamines, but it`s always a bugger to start.
No complaints so far about my Crappy-tire saw.
:thumbsup:
/ New cheap saw #8
I always seem to find some nasty wood to cut up, that a cheap saw would be handy for.
/ New cheap saw #10
Well, I'm happy for you. I also needed a new chain saw. I was reluctant to buy the HD/Lowes/TSC units even at a reduced price. My Poulan Hedge Trimmer disappointed after a few years of ownership. My Husqvarna Leaf Blower though runs like a top. I just purchased an Echo Chain Saw from my local dealer, a CS400 (a top of the home owner line) with an 18 inch bar. It was $299 but there was a promotion and I got the case/baroil/2cycle gas mix thrown in ( a $40-50 retail value). The Echo or Stihl was my preferred choice & I was leaning to Echo, so that sealed the deal for me. (I've owned my current Stihl/case for over 25 years, but today's machines are not the same. Good Luck. I hope to own my Echo for 25 years! Yipes at my age I hope to own anything for 25 years!!:)
/ New cheap saw #11
Got a 380 poulan at a auction a couple of years back. When I got around to using it I was surprised how much I liked it. Now shopping around for parts I find that the saw is already past it's prime and parts are hard to find. Looked at a saw this morning and the Stihl MS880 brought 1000.00 even at auction. Do not have to worry about parts- could not afford it used.
/ New cheap saw #12
I think the point of this thread is that for occasional use or a second saw, these cheap Poulans are hard to beat for price. Sure, a Stihl would be nice, but I have no need for a saw that expensive. And if I drop a tree on it or run it over with my tractor I won't be out big bucks.
/ New cheap saw
Ive owned most all brands of saws over the years, mostly mid to high priced ones, this poulan is the first Ive ever owned that cost under $200, i was very skeptical at first, 50cc engine, 20 inch bar plus a carrying case AND SO far after 4 tanks of gas of pretty hard use, im 100% happy with it, hope it stays that way, time will tell BUT worst case scenerio if it just lasts one season im not out much money. Either way i think im done with buying $500+ saws, after all im not a professional lumberjack, im just a working guy that uses it as needed on my 10 acres.
NOW my next question, instead of starting another thread, in years past Ive always had a guy at the mower place sharpen all my chains for $5.00, well he retired couple months ago, so how tough is it for someone to sharpen their chain themselves? Without spending a lot of money ($100+) on a sharpener, what do you all suggest as far as sharpening the chain?
/ New cheap saw #14
I went through the same thing my man sold his shop and sent me to someone else. The new guy treats me way better than the first. I bought a file and just touch it up between trips to the pro.
/ New cheap saw #15
It's a skill that is easily learned with time & practice. Working with my dad in the woods as a teenager it was my job to keep the saws fueled, lubed, adjusted & sharp (and split, stack, load & unload the truck :thumbsdown: ) I average 10 federal cord a year (for the past 5 years) and have never paid to have a chain sharpened in 40 years. Frequent touch ups with a file are better IMO than long runs between sharpening.
/ New cheap saw #16
I sharpen 3-4 times in a typical cutting day, or more frequently if needed (a sharp chain can go to heck in an instant). It should be a go-to skill for anyone running a chainsaw, otherwise you're probably cutting with a dull chain or wasting time swapping chains during the day.
The downside to cheap Poulans are things you might not think about, like maintaining good chain tension, consistent oiling, cooling under load, maintaining tune/compression over a temperature range, etc. Use it hard enough and the rough edges will start to show.
Poulan made great saws back in the day. I have one circa 1972 and it's a very nice saw (consider it a family heirloom). But I'd skip their newer saws and put the money towards something better.
One easy way to sort saws is to look at the emissions sticker and see how many hours they are rated to maintain emissions specs. The good saws will say 300 hrs. Cheaper saws will say 50 hrs. Interestingly, you can see a 300 hour sticker on a homeowner Echo saw, but only a 50 hr sticker on a Stihl homeowner saw. Stihl doesn't start rating at 300 hrs until you get to the higher end of their product line. So it's not always what you think. In case anyone is wondering, the emissions spec relates to quality of pistons, rings, liners, etc, as well as assembly quality.
/ New cheap saw #17
They are not meant for commercial duty but I have gotten great service from a couple of Poulan saws..
Have been using a "Farm-Hand" 2775 (20") for going on 15 years and it still runs and cuts great...I also have an 18" bar that does make it a bad azz saw...I always flip the bar over when I change chains...I also have a 3314 that never fails to start on two pulls...
I wish the 2775 had a fuel primer bulb though...
/ New cheap saw #18
quality.
That is an interesting metric for the newer saws, if you can find it out. I wonder what the rating is for this
new Makita DCS460 I have here.... I will check.
I have and work on many saws, and I find the sweet spot for years of manufacture to be in the 80s, due
to the adoption of electronic ignitions and plastic fuel tanks, but before the conversion to all-plastic or
nearly all-plastic bodies. The 87 Poulan 4000 I have here is 65cc of glory.
The biggest differentiator on longevity I have found is whether they use 2 or only one piston ring. Pro
saws seem to "all" have 2, tho it is not easy to find out. I imagine the pro saws or better-made saws
also use more durable cylinder metallurgy, too.
As for the current crop of Poulans, I would put them up against the low-end Stihl MS170 in terms of
quality and longevity. You can get a lot of work out of the Poulans if you take care of them. The
usual models you see in the stores are the 3314 and the 4018. That PP5020AV is not as easy to find
in the stores, but definitely a bargain.
Currently refurbishing an 83 Husky 2100. It has many 100s of hours on it.
/ New cheap saw #19
I have a 73 Poulan S25 tophandle saw, which were the choice of arborist-tree climbers back then. 2 piston rings and
all-magnesium construction made this unit very durable. A pro saw, for sure.
Poulan (part of Husky now) has changed hands several times over the years, but they were tops a few decades ago.
Poulan WAS Freddy Kruger's preferred saw, after all.
/ New cheap saw #20
I have the cheap 29.00 sharpener from harbor freight. Works great. I have 5 chains (7 as of yesterday, as I found new Oregon chains for my 18" Poulan for $12.95). I keep the sharp ones in a zip lock bag with some oil. That fit in the case with the saw. When I get down to one in the bag, I sharpen them all. Takes 5 minutes.
In the field, I use a file with 5-6 strokes on each tooth if the feel dull. Works for me.
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
UNUSED KJ 45'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 45'X25'...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A63118)
2025 Mahindra 6075...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
