Have soil report now what?
/ Have soil report now what? #1
RPW
Got my soil report recently and I have a few questions. I working with a hybrid of Bermuda grass called Texas tough. What I like about this grass is that it's a very drought tolerant grass and is very disease resistant.
First the report shows;
pH of 8.1
Nitrogen requirements 40lbs/acre 1st and subsequent cuttings.
Phosphorus requirements 55lbs/acre 1st and 80 2nd and subsequent cuttings.
Potassium 0.
Calcium 0.
Magnesium 0.
Sulfur 5lbs for 1st and on cuttings.
Everything else is 0 or N/A.
Now for the questions.
I will be using up the fertilizer on hand which is a 20-20-20 water soluble at a rate of 5lbs/100gal at a rate of 3-5lbs/acre. Does that mean that at that rate I'll be putting 20lbs/acres?
And if this is so to put 40lbs/acre all I need to do is double the dose (10lbs)?
Thanks.
/ Have soil report now what? #2
Thanks.
I'm assuming you meant to say "5lbs/100gal at a rate of 300-500 gallons per acre."
At that rate you'll be doing 15-25 lbs of fertilizer mix per acre, let's call it 20. The numbers on your fertilizer mix -- 20-20-20 -- are percentages of nitrogen, phosphorus and potassium. So 20 lbs of fertilizer has 4 lbs of nitrogen. So to get 40lbs/acre of nitrogen you'd need 200 lbs/acre of fertilizer mix. At 5 lbs/100 gallon that's 4000 gallons per acre.
I wouldn't make the mix any more concentrated than the label recommends. First, depending on the formula concentrated nitrogen can burn plants. Second, it may not actually dissolve at a greater concentration.
OK on the concentration. I looked at the label again and it said 3 to 5 lbs per acre. I'll contact the suppler to get clarification.
OK, have my answer. For the product that I'm using at the rate specified I would be putting down 1lb. of nitrogen per acre. So to get the required amount of 20lbs per acre I need 100lbs of fertilizer per acre.
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
John Deere 310K Backhoe (A65579)
John Deere 310K...
2006 JCB 506C HIGH LIFT TELEHANDLER (A62613)
2006 JCB 506C HIGH...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
2014 CASE 580N BACKHOE (A65053)
2014 CASE 580N...
2022 EZ-GO ELITE...
