dragoneggs
Super Star Member
- Joined
- Jun 9, 2013
- Messages
- 14,548
- Location
- Seabeck, Washington
- Tractor
- Kubota BX-25D, Kubota Z122RKW-42
I am actually worried the clay/mud crap I get into would be permanently embedded unless subjected to a pressure wash which would be a pain.Back around post#244 I put pictures up and told of my snow plowing with cut tires. After using the tractor around the yard this summer, I wan't to let everyone know of the possible side effects of cut tires in mud and gravel. First if you operate in mud, the cuts will fill with mud and then if you then go down the driveway fast you will leave strips of mud flying that look like the rubber strips you cut out of the tires. Also left alot of mud strips in the garage when you go to use the tractor the next time. Second in the gravel areas I drive thru the cuts always seem to collect small stones in the cuts, again not a big deal until you go road speed and the little rocks come flying out. Not trying to knock cutting tires just reporting back on my experience with the cut tires is all.
