BX25 for Creating Large Pond
/ BX25 for Creating Large Pond #21
How long have you owned or been familiar with the property?
My first thoughts would center on the newly discovered natural spring...does it stay wet/flowing all year long? Being "newly discovered" I would not go to any great efforts in creating a pond until I was sure the spring could keep up and maintain a satisfactory water level...
/ BX25 for Creating Large Pond #22
If all you have is a small tractor, then that's just what you use to get the job done. Nothing wrong with taking a little longer to get what you want. Springs are tricky things. What they are is an area on the surface where the ground water has worked its way to the surface. Some are at the base or side of a hill where the water is leaking out of the hill. These are the best types of springs to use for a pond because the water level is above the pond location and the water will drain down into the pond. The other type of spring is where the ground water is so high that it is coming up to the surface, or close to it. These are the worse kind of springs to create a pond with because the pond will rise and fall with the ground water. The water that fills the pond will also be the source of the leak when the water table drops. Think of a creek that runs most of the year. Even if it hasn't rained for weeks or months, where is the water coming from? It's leaking into the creek from the sides and bottom of the creek from springs. Once the table water around the creek dries up and lowers, the amount of water in the creek decreases and sometimes stops completely. A water hole might remain in certain areas all summer long because that is how high the water table is in the ground around it. Just digging a hole or building a dam does not mean that you will have a pond. Eddie
Agree with Eddie 101%
Sent from my iPad using TractorByNet
/ BX25 for Creating Large Pond #23
It will do the job, and it will do the job just fine, you just have to know that *(it happens, and it does not matter one bit if you have a "small" tractor or a large tractor. The only difference is if you get a large tractor stuck it is a great deal more work to get it un stuck.
So lets think about this idiot thing for a second. I get a little tractor stuck and in 20 minutes it is out and we are laughing about it. After getting a large tractor stuck, you are having to find even larger machines to get it un stuck, so personally I think your are even a bigger idiot if you plant a large machine, then a machine that comes in at less then 2000 lbs. Goes back to the bigger, is it really better, well if you don't make a mistake I guess it is. I know a great many on this forum are perfect and do not make mistakes and would never get a large machine in a problem area.....good for you, myself I make plenty of screw ups so I guess it is good I bought a little machine that will do every job even if it takes a little longer, and when (not if) I screw up, I have a guy behind me with a large machine to pull me out in 10 minutes.
I am really glad you don't make mistakes Eddie, and don't have to worry about getting things unstuck.
/ BX25 for Creating Large Pond #24
???? I have no idea what you are referring to.
I get stuck all the time and I get myself unstuck with what I have, no matter how long it takes. Worse case has been two very long days that resulted in trees coming out and a mess that took another day to clean up after waiting several months to dry out.
What is an idiot thing?
Using a small tractor to do a job just because you are afraid of getting stuck all the time is a pretty timid way to go through life.
Eddie
/ BX25 for Creating Large Pond #25
And all this time I thought they had no water in Texas.
/ BX25 for Creating Large Pond #27
With a BX you simply do not have the force available to excavate with the bucket. Youll need a 2' bucket to match the tractor force ability.
larry
/ BX25 for Creating Large Pond #28
larry
............on the back hoe:laughing:
/ BX25 for Creating Large Pond #30
Apparently he didnt see my post #20 above.
Digging a pond with a BX would be a very time consuming job. I don't think a BX would be capable of digging a pond here because the ground is pretty hard. If someone had a BX and wanted to dig a pond they would be better of renting a larger machine.
/ BX25 for Creating Large Pond #32
sort of a "hold my beer an watch this" moment :) but in reverse.
/ BX25 for Creating Large Pond #33
Don't forget while taking pain pills....if you are going to do it....do it right baby.
Actually what really happened is I was scooping outside the ditch, the front wheels went in a little further and my butt came off the seat....tractor stopped....safety switch. When it stopped it just rolled right into the hole....nothing I could do about it....I was twisted around backward to keep from hitting a tree, and could not get to the brake. Eh happens.
I am just amazed that a little mis fortune brings such joy to some people, disagree with someone about something and they take joy at bad things.....hay going to find out if I have cancer today that should make you really happy.
/ BX25 for Creating Large Pond #34
Thats a CUT not SCUT. Whered all that loose dirt come from? We dont have any of that here.
/ BX25 for Creating Large Pond #35
I think it could easily be argued that a Kioti CK20, a 20 hp tractor is a SCUT. My Cub cadet lawn tractor has a 22hp Kohler and it's definitely not a CUT :)
/ BX25 for Creating Large Pond #36
Horsepower does not have anything to with if it is a SCUT or not. It is the size of the machine.
/ BX25 for Creating Large Pond #37
The ck20 is 48 inches wide, has a 50 inch bucket and overall is very small. It meets my idea of a scut is.
/ BX25 for Creating Large Pond #38
Rut Ro:eek:. But is the max a scut?:stirthepot:
/ BX25 for Creating Large Pond #40
As some others said, you need to evaluate the spring first of all. Is it a true spring, high ground water, water trapped above ledge rock, or ??? That's what you need to know first.
Pics would help, but if the lay of the land is fairly flat, you could dig out a small frog pond about 20-30 feet away from the wet spot. Just pile the dirt up because you may be filling the hole back in eventually. Have an idea for where an overflow outlet could be and where that water would go. Then dig a small trench from the wet area to your hole.
If the spring continually supplies water to the small pond, enough that it overflows, and does that for most of an average year, then you have some water to work with and an idea of how much. It doesn't take a lot of water to keep a small pond full. Chances are you will get some ground water too.
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
CHEVY DUALLY TRUCK BED (A65643)
CHEVY DUALLY TRUCK...
SKID STEER AUGER ATTACHMENT (A62613)
SKID STEER AUGER...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
