Show your restored, repaired or repainted implement projects.
/ Show your restored, repaired or repainted implement projects. #1
yelbike
Near Winnipeg, Mb, Canada
John Deere 2305, 2320,Z465
I repainted my box blade this summer. Relatively easy project. Disassembled, sand blasted, primer with xylene based primer than painted with tremclad. So far I'm happy with the results.
/ Show your restored, repaired or repainted implement projects. #2
Looks nicely done!
/ Show your restored, repaired or repainted implement projects. #3
Good job maybe in a couple months when I retire I will do some of this
/ Show your restored, repaired or repainted implement projects. #4
Ferguson 2-Bottom 14-inch Plow
/ Show your restored, repaired or repainted implement projects. #5
Post hole digger, Box blade, and Flail mower, snow plow.
Post hole digger had to weld on new steel, rebuild U joints, gear box seals, and paint.
Box blade was just a clean up and paint.
Flail had to clean and sharpen blades, replace roller bearings, U joints, gear box lube change, clean and paint.
Snow plow was a complete adaption to SSQA plate for tractor.
/ Show your restored, repaired or repainted implement projects. #6
I have a Herd spreader that I got cheap. it was left on it's side so most of the sheet metal was rusted. Also the fertilizer had ate the aluminum plates (the spreader and hopper bottom) so I replaced them. I also installed new seals and shafts in the gear box. It's now basically new for about half the cost.
I don't have too many pictures on this computer but here's what I've got.
/ Show your restored, repaired or repainted implement projects. #7
Bought a Taylor Pasture Dream off CL cheap because the 3PT lift mechanism was worn and would not adjust.
Removed the original mechanical arm and installed a small cylinder to open and close the shutter bar.
Worked great!!
/ Show your restored, repaired or repainted implement projects. #8
I have a 67 loader on my '88 JD750. Over the years, I wore the bucket plumb out.
I checked with the local JD dealer and they were NLA. Off chance that he might be able to find an orphan through the dealer network, but the price plus shipping would have been breath taking.
I opted to just build my own.
Pictures and description here.
I've also bought a couple of used (up...) mowers and repaired them enough to use.
A Deutz RM72 finish mower
An Allis Chalmers sicklebar, since sold.
/ Show your restored, repaired or repainted implement projects. #9
This is a cutter I bought cheap and reworked this past year, it works very good and was worth the effort I put in it. I enjoy reworking equipment,implements and trucks
John
/ Show your restored, repaired or repainted implement projects. #18
Thanks. Sadly, I never use it, even though plowing is one of my favorite tasks. I now have a Truax no till seeder so I just don't plow. I need to sell it to someone who can use it
Those are some nice projects! Your MF reminded me of walking into this guys place one day. I was driving down the road and this place looked a little untidy but he had quite a bit of tractors and implements for sale. I stopped in and got talking, he lead me to his shop out back, a true craftsmen.
Check out his website, Idk if it truly makes him justice.
JJ Riverside Mfg Ltd - Rebuilt & Pre-Owned Tractor Sales, Parts and Service
/ Show your restored, repaired or repainted implement projects. #20
I bet the shipping to Nebraska would be expensive. :(
