Snowblowing rules of thumb
/ Snowblowing rules of thumb #41
Wet slush is OK as long as you don't slow down. Drive into the puddles with the blower full speed and it will blow without clogging. But dry slush will pack hard in the chute so at the first sight of clogging either stop and clear it or head for a melt puddle and hope the water will loosen the slush and blow it out.
A good tip that I heard from someone that ran over the Sunday paper (twice) is not to do it. As well as filling your yard with scraps of newsprint, said newsprint will eventually jam the auger and shut down the blower (or break a pin.) Same for branches. Keep your driveway clear before the snow covers it up only to be found by your equipment.
And my wife found that if you don't turn the chute away from house windows quick enough, that a blower will pack snow real tight between the screen and the window. Makes the room real dark, real fast!
/ Snowblowing rules of thumb #43
I was looking at some options for snow blowers. Our driveway is 2100 feet long so the the rear facing blower is not an option. The front mounted blower makes obvious sense but what about the rear mounted pull snowblower? Looks like it could work. Some comments about being able to tackle big snow with them, which is good. You can keep the FEL on as well. Any thoughts?
/ Snowblowing rules of thumb #44
Was she in the house when it suddenly went dark?
/ Snowblowing rules of thumb #45
I have no problem pulling my 74" pull type blower no matter how much snow we've had. I don't get huge drifts though and my drive is fairly level. If you're not going up hills, you should be fine. I use my FEL to move skids of firewood so removing it is not an option. I also love the blower for ballast, it's a lot of weight hanging a long way back, great for FEL work.
/ Snowblowing rules of thumb #46
2014-08-09_18-01-31_847.jpg I use a amber strobe warning light and try to use the wind by shooting the snow with it, if I'm lucky the wind works with me.
/ Snowblowing rules of thumb #47
In NH we have a 220 yard gravel drive that is plowed and I have an Ariens Pro 926 walk-behind to clear around the house. I expect to use the FEL to clear banks at the end of the drive, and will totally cheat the cold by using the Gerbing heated motorcycle jacket I have.
In Boston we have a much shorter driveway but the snow is actually a lot more difficult. We live very near the harbor and the Northeasters bring very heavy and wind-packed snow. Boston snowfall statistics are highly deceptive because they are recorded at Logan Airport, which is out in the middle of the harbor. While Boston officially averages 45" per season, the Blue Hills Observatory just a few miles away averages 60", which would put Boston in the top 25 snowiest cities. I upgraded twice to an Ariens 1124 Pro, an 11.5hp motor for a 24" bucket. That moves even the plowed, salt-infused snow we mostly have to deal with.
We're sailors so I have foul weather gear and on small boats we wear a "dinghy smock" top that has a sealable top collar. This is just the ticket for a walk-behind.
I also wear wetsuit gloves as the Goretex gloves I have soak through eventually anyway. A Balaclava and ski goggles and the wind doesn't really matter.
/ Snowblowing rules of thumb #48
I've got a 72" rear pull also, love it, ( they are a little more expensive though),,
It depends on the size and weight of tractor you have.
My L4200 handles it well in all types of snow.
/ Snowblowing rules of thumb #49
We have allot of cottages where we are, like others have said, ,
I usually take a dry run with the machine to look for obstacles etc,
set up a few "marker's" here and there, on those extremely cold mornings,
I plug er in for about 1/2 an hour then let er run for about 15 minutes to get the cab nice and warm,
turn on the lights and go out and play...lol
Around the end of Oct., I usually throw on the blower and front blade and pray for an early spring,
like usual, it never happens.
/ Snowblowing rules of thumb #50
It's a good idea to put in a few driveway reflectors (the kind that are 3' tall) so you know you're actually clearing the drive (instead of the lawn). I didn't realize I was clearing about half the blower's width (about 36") off the drive until the snow finally started melting last winter (snow in Vermont doesn't always melt between snow events).
/ Snowblowing rules of thumb #51
I do over 3 dozen driveways in our area and buy 3/8 rebar (20' lengths) and cut them into 5 pieces with a cut off wheel on a hand held grinder. They go in the ground easily, and if they get hit and bent over are easy to straighten up again. I buy cheap tennis balls at a dollar store and cut a small X in each ball, and place them on the exposed end of the rebar. That protects the end and makes them easier to see.
/ Snowblowing rules of thumb #52
Now why didn't I think of that:mur:
I do the same, but I put about a foot of rubber hose at the end, painted florescent orange.
/ Snowblowing rules of thumb #53
First rule of thumb: Keep your thumbs. And fingers clear. (Even a shut off snowblower, especially if jammed/plugged, can have stored energy in that coiled auger, which can release and turn the auger and the connected blower.)
/ Snowblowing rules of thumb #54
Clarence Modification for your Snowblowers. I've added them to my old Craftsman blower and many of my friends Blowers of various makes and models. It improves throwing distance and eliminates Clogging. ONLY issue is if you park the Blower without cleaning out the Impeller area, the impellers do tend to freeze to the Tunnel. Usually I just toss a bucket of warm water down the shoot just before firing up the machine for another run.
I read the whole thread and it seems like most of you folks are in Canada. Here in Lower New York and out on Long Island we seem to always get very wet heavy snowfalls. Can't just rev it up and push through it. Half cuts and slow Forward speed is the only way to get it done. Not to mention the wet snow makes it much more slippery then Very cold temps and dry snow. Lemon pledge, down the shoot, helps the wet stuff move freely.
My Coast Guard Overall Mustang suit keeps me too warm no matter what the wind and temps are.
No plow on my tractor shown in my AVATAR yet. The tractor is equipped with AUX hydraulics so ...someday.
/ Snowblowing rules of thumb #55
Hey Tony, I just looked at your "toys"....
Very nice, I like the chevy step side.
I didn't see a pic of your JCB there, just got myself one, a jcb 210s 4x4x4
/ Snowblowing rules of thumb #56
When I had a smaller tractor - Ford 1700 4WD - I would use the rear mounted snow blower to move the berms created from plowing with the rear blade. The first time always resulted in one or two shear bolts needing replacement - rocks or sticks or etc. The rule of thumb I found - - the blown snow will ALWAYS come back on you, no matter which way the chute is pointed - I had an open station tractor. Now that I have a larger tractor the rear blade will handle anything we receive here. And if it doesn't - - hey, I'm retired and in no hurry to go anywhere. I have a mile long, gravel driveway.
/ Snowblowing rules of thumb #57
Just looked on the JCB website. Looks like JCB stopped offering the 210 and my MIDI in the US. It's still on teh UK website. Benefits - JCB MIDI CX Backhoe Loader
I looked at the 210's when I was looking for a machine. The 210 is similar, if I remember correct, removable Hoe and Quick attach like the MIDICX. I will be doing many Agricultural duties so the removable Hoe was critical. I also wanted a Hoe where I just spun the seat around. Not like the Ag tractors where you are hoping off the Hoe seat and into the Cab to move 6 feet and continue your ditch.
Midi CX Backhoe Removal - YouTube
/ Snowblowing rules of thumb #58
At the start of the season I will drag my back blade over the driveway for a few snows and get the snow packed down for a nice smooth surface to blow on. I also put a couple of 2x4's under both the blower and the rear blade before I set them down on the ground. The rear tires are parked on old wooden doors that were destined for the dump. I have a dirt floor in my tractor shed and no heat.
/ Snowblowing rules of thumb #59
Ya, my 210 doesn't have the removable hoe, but I do like the idea of it "tucking in" and not stick out like a soar thumb. I'll see how it handles in the snow this year.
/ Snowblowing rules of thumb #60
I have B1750 Kubota with rear snowblower. Seasons other than winter I have a grader blade. Because I have half mile of snow removal the "ole" neck gets stiff looking backwards. This year thought I would just use the loader bucker and try the the grader blade. My problem is, I can't figure out how to stop the grader blade from swinging sideways which causes it to dip and ending up tearing up the road and grass on side of road. So what's the trick on how to stop it from swinging and to keep it straight and rigid in one spot???
Any suggestions would be a great help.
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
Margaritaville Decorative Metal Sign (A61569)
Margaritaville...
1999 Van Hool Transit Bus T2100 Bus, VIN # YE2TC63B3X2043319 (A61165)
1999 Van Hool...
