bx1500 sitting idle for 6 years
/ bx1500 sitting idle for 6 years #1
Jono51
Grand Marais, MN
Kubota L3400
I was recently able to pick up a bx1500 while cleaning out an estate. It has been under tarps for at least 6 years. I charged up the battery and got the dashboard to light up a bit. The fuel pump buzzes and the solenoid clicks after I shut off the key, but no indication of wanting to turn over. I have an L3400 that I have had for 8 years. This bx is familiar, but just different enough to make me look for an owners manual. The air filter is clean and the engine oil looks good, but I plan on changing all fluids soon. Any advice on getting it to turn over would be appreciated Fuel and fuel filters first? Thanks in advance!
/ bx1500 sitting idle for 6 years #2
Sounds like a safety switch if it is not turning over. PTO, HST pedal, seat
/ bx1500 sitting idle for 6 years #3
yes check switches but could battery just be toast (not enough amps to turn but dash lights etc ok) after 6 yrs jump with known good bat/veh
/ bx1500 sitting idle for 6 years #4
I'd suspect a new battery is in order in any case. I wouldn't see it as an unnecessary expense, but a mandatory one.
Thanks Deano!
I'll check those things first.
Thanks guys, the battery is definitely on the list, too.
/ bx1500 sitting idle for 6 years #7
Also take care, if the clutch pedal was not blocked, the clutch plate can rust onto the flywheel. Ensure it disengages so PTO operation is safe.
/ bx1500 sitting idle for 6 years #8
My B2320 had the "block the clutch" procedure, but not on a BX. No clutch pedal to block.
I also bought a BX that had an absurdly low amount of hours put on it in 3 or 4 years. Likely a senior tractor owner, who knows. Just go through it with fresh fluids and filters, fresh diesel and fuel filters as well. I chose to even change out the HST fluid and filter and re-fill with the newer SUDT-2. Did everything short of changing in the air in the tires.
Come to think of it, I did change the tires/wheels. :laughing:
There is no clutch on this one which surprised me. The tires are all cracked, but holding air and it only has about 370 hours on it. I'll probably have to wait until the weekend to look through it again as there is not enough daylight anymore. It was senior owned, but he seemed to take pretty good care of all his stuff.
/ bx1500 sitting idle for 6 years #10
I tried putting a tractor picture on so it would come up when I post. I have the pic on my profile but it doesn't come up when posting. Any suggestion from anyone?
Thank you
/ bx1500 sitting idle for 6 years #11
I might suggest, that if the tires don't look healthy and you want to change them out, you might just order a full set of wheels and tires from a Kubota dealer, from Kubota Whole Goods. A full set, of either turfs or Ags can be ordered for around $400. You'd be hard pressed to buy just tires alone for that. They come on the truck to your dealer, all mounted, tires and fresh new orange wheels.
Order the set for the BX1870 and they will fit your 1500 just fine.
Uploading photos to TBN is a bit clunky. I feel your pain.
/ bx1500 sitting idle for 6 years #12
Thank you
I usually find a third grader to help me.
/ bx1500 sitting idle for 6 years #13
Me too but they are all grown up and out of the house.
Great verse!
/ bx1500 sitting idle for 6 years #14
The battery is junk. Put in a new one and it'll turn right over. You might be able to get away with jumper cables, but that's not a guarantee with a diesel.
/ bx1500 sitting idle for 6 years #15
Yep first thing is battery... don't screw around and just get a new one. I would replace the fuel filters and oil and filter too straight off. Good luck.
/ bx1500 sitting idle for 6 years #16
I might suggest, that if the tires don't look healthy and you want to change them out, you might just order a full set of wheels and tires from a Kubota dealer, from Kubota Whole Goods. A full set, of either turfs or Ags can be ordered for around $400. You'd be hard pressed to buy just tires alone for that. They come on the truck to your dealer, all mounted, tires and fresh new orange wheels. Order the set for the BX1870 and they will fit your 1500 just fine. Uploading photos to TBN is a bit clunky. I feel your pain.
BP, will the 1870 tires fit the BX1500 with 48" MMM and not cause any clearance issues? You have me thinking now about upgrading my turfs.
/ bx1500 sitting idle for 6 years #17
The only "set" of wheels and tires that Kubota now sells, from Whole Goods, is the 1860/1870 set. The diameter is what matters.
About 6 years back, I reckon, Kubota went to a lower profile, contemporary looking front tire. This allowed them to put a larger wheel on the front, but the overall diameter didn't change. The entire BX line got this new look. I personally prefer the old look because having more sidewall makes for a slightly more comfortable ride, ihmo. The newer, lower profile front BX look is very unforgiving and there is almost no side wall to cushion at all. Shrug.
Bottom line? If the outside diameter of the new BX1870 is the same as what's on your old BX1500? You'd be good to go. This assumes the bolt pattern is the same and I'm pretty darn sure it is.
/ bx1500 sitting idle for 6 years #18
Wiggle the PTO engage lever, my safety switch gets dirty and prevents the starter from turning. Needs cleaning, maybe use electrical contact cleaner around the switch.
Agree with above: change the fuel and fuel filters too.
I put a serious battery in it today and it started right up. It ran just fine and the only problem (so far) is a leak in the steering cylinder. We'll try to fix that when we drain all the fluids. After six years under a tarp it sounded wonderful. I couldn't believe it. Now the work begins. We got the 54" mower with it and upon closer examination realize that it has never cut grass. The underside looked new and there was no evidence the blades had ever cut anything. I seriously need to get an owner's manual. Thanks again for all the advice from everyone.
/ bx1500 sitting idle for 6 years #20
Thank you
Put the pic in your avatar, and it can't more than so many KB or it won't load.
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A61307)
1992 Talbert 70...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
2005 Suzuki King Quad 700 Fourwheeler (A61166)
2005 Suzuki King...
2020 SAVANA 3500 4X2 S/A 16FT BOX TRUCK (A59906)
2020 SAVANA 3500...
