Proud owner of a new owner's manual
   / Proud owner of a new owner's manual #11
Over 14h now, I finally got to do some welding
I also added two 3/8" hooks to the front brush guard so as I have a sold tie-down point for transport.
View attachment 385983View attachment 385984
Watch those tie downs that far forward. I was running a chain right behind the grill guard and saw that when i cinched the over center binders, the frame tweaked quite a bit. Being i transport on a lot of rough dirt roads i saw this as an issue because as the trailer would flex it would pull on this area even more. I ended up making plates and bolting them to the double frame over the axle and it don't move at all....... http://www.tractorbynet.com/forums/ls-tractors/319273-xr3037c-front-tie-downs.html
   / Proud owner of a new owner's manual #12
I added four 3/8" hooks to the bucket and three 2" hitch receivers. I have the hooks facing forward and back so I can place the chain anyway I please.
The 5/16 chain hooks fit through the receiver openings but the 3/8" chain will not but the give me a good termination point if needed.
Just an FYI. Rustoleum Sail Blue is a much closer color match than the blue you used.
That is sail blue.
   / Proud owner of a new owner's manual #14
That is sail blue.
It must be the camera or lighting that makes it look darker. here's the comparison pics. I used Sail Blue from Rustoleum quart can to spray my mower. The spray can of Sail Blue is the same. Yours looks darker, more like Navy Blue.
Here is a better picture
Finished painting the box blade.
Not sure if you can tell but I tinted the head light bezels, looks much better I think. I wanted to remove the grill also and paint it also but its much more difficult to remove. It uses push and lock type of washers/retainers.
   / Proud owner of a new owner's manual #18
nvmyhd. Wow, you have half as many hours as I do and you have already customized your rig! I have not welded hooks, upgrades speakers, or made up hydraulic lines to run to the front of my loader on the P7010C. I have just been catching up on work that has been piling up between when my Farmall died and I received the P7010C.
Sharp looking tractor! :licking:
How do you like the light bars?
CT
I'm at 36 hours now. When it comes to lights you can never have enough. I'm happy with the front LED bar, the two 2x2 in the back are ok but I think I will replace the front bar with a larger unit and move it to the rear.
   / Proud owner of a new owner's manual #20
I would like to replace both the front and rear work lights with light bars. I have some 4" LED's like you put on the rear installed on another open station tractor and our ZTR. They are "ok". The OEM lights are better than I imagined they would be. My concern with the light bars are, Side lighting and edge of beam cutoff? My experience with LED lights with reflectors have a VERY sharp side cut off and make it difficult to see past that point. Are the center LED's spot and the sides diffused floods?
I'll probably hit 30 hours today if I am able to get some seat time. :drink:
CT
COLE 1R PLANTER (A52708)
COLE 1R PLANTER...
2022 Delta Gooseneck Equipment Trailer VIN # 4MWGF4022PN059238 (A57453)
2022 Delta...
2016 Ford F-350 (A56858)
2016 Ford F-350...
INFLATABLE BOAT & TRAILER (A52708)
INFLATABLE BOAT &...
LOT OF CHICKEN EQ. NEST, BROADER & FEEDER (A58374)
LOT OF CHICKEN EQ...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A58018)
2019 KENWORTH T680...
