Loader Lifting Logs
/ Lifting Logs #1
otherguy
Member
MO
Kioti DK45SE
I am looking at purchasing a 1999 JD 4500 that has a Woods 1012 loader, the lift capacity is rated at 1375 lbs. Maybe that lift capacity is at the top??
Will this tractor/loader combo be able to lift 8 foot logs, anywhere from 18" to 36" in diamter??
I don't need it to be lifted very high, the highest ever would be to get it on a trailer but that wont be all the time. I didn't know if someone here has used something similar to lift logs and have done fine with it. Just as a guide an 8ft White Oak log weighs about 1648 lbs (from what I can find).
Thanks for any info.
/ Lifting Logs #2
The lift capacity depends on what attachment you have on loader for example a ssqa set of forks weighs usually less than a ssqa grapple. most of the time if you can pick it up it will lift it all the way up. Have to be careful when moving with heavy load the higher it goes the more unstable it is. so not knowing how much each log weighs you just have to try make sure you have weight on 3 point hitch to counter balance load
/ Lifting Logs
Good point, was probably just going to used chains on the bucket, wont have any other attachments for the loader except the bucket that comes with the tractor. I wasn't sure if the capacity is 1325, and the log is 1650 or more, if it still can be lifted, at least some.
/ Lifting Logs #4
The only real way to know is to try it. As you probably already know, logs that look identical can have very dissimilar weights.
The hydraulic pump will go into relief if the log weighs too much.
If you can somehow get the too heavy log off the ground, then the FEL should be able to maintain the height although not lifting it any higher. Sometimes we use a second tractor to help team lift a log and the tractor will hold it where it is.
Another trick is to slide forks under the log all the way. (I know you don't have forks...yet!) Then curl the forks. If they will curl then the log will be a few inches off the ground. It is enough to move the log around a bit on flat ground. Loading it on a trailer would require another tractor to team lift it.
Be sure to use a BIG counterweight.
/ Lifting Logs #5
Will this tractor/loader combo be able to lift 8 foot logs, anywhere from 18" to 36" in diameter??
I think you answered your own question if you look at the numbers you posted.
/ Lifting Logs #6
Not necessarily. He is not sure that if a loader is rated at a given capacity when fully elevated means to its capacity if it is only lifting less than half way. The loader on my last tractor was rated for 850 lbs but routinely lifted a 1000 lbs a couple of feet off the ground.
/ Lifting Logs #7
Possibly but he also has 200 to 300 lbs or more with his bucket or forks. That puts him at 500-600 or more pounds over capacity. Unlikely it will work.
/ Lifting Logs #8
Not only is the weight a problem if the specs are to be believed, but I think 8 foot logs are going to be a bear to balance unless they are very uniform and symmetric. I like lifting 4'-5' sections myself, since they can fit inside my bucket and I know they are not going to shift or tip. For longer stuff that is for lumber, I skid them on the 3-pt. If I do have to lift them with the front loader, it's just up into the cradle on a sawmill, which is only a 3-4" inches off the ground.
/ Lifting Logs #9
Specs aside, I find 8 ' logs extremely easy to balance as they are only overhanging most buckets 18" off of either side.. Even this log only took 2 tries to find it's balance point. Walked it down about a 100' with no issues at all. Joking aside, I refrain from lifting anything that heavy and moving with it with the front end loader for the enormous torsional stress on front end componetry. The light logs you see on the bucket is as large a load as I would go traveling a distance as combined, I doubt they weigh 400 lbs
/ Lifting Logs #10
Is it 4 wheel drive?
If it is you can adjust the pressure relief a little higher, the front axle will handle the extra weight.
/ Lifting Logs #11
I routinely lift chunks of very large ponderosa pine - 18" to 36" diameter. As best I can figure my max lift is around 2750 lbs minus the grapple = around 1930 pounds. I've made a cheat sheet that will tell me the approximate weight of pine logs. I check the cheat sheet to see if I can lift a ten foot or five foot chunk before I do any lifting. So far this has worked well. The last thing I want to do is break something or become unstable.
Most likely your lift capacity is calculated with the weight 24 inches forward of the lift pins and 24 inches off the ground. No matter what I'm lifting - log wise - I never get the load more than 6" to 12" off the ground. Bad things seem to always happen faster than the speediest of reaction times.
/ Lifting Logs #12
Math, be my friend.
A 36" diameter log is 1 cubic foot of wood for every 1.7 inches. Put another way, 7 cubic feet per foot. I come up with weights much higher, depending on density. Most hardwoods are around 40-45 lbs cu ft, but some like Live Oak are higher (60 lbs cu ft, yay USS Constitution). So @ 40 lbs cu ft an 8', 36" diameter hardwood log would weigh at least 2,248 lbs.
24" log is just about 7" per cubic foot (or about 12 cu ft for an 8' log), way lighter, about 480 lbs.
The fun comes in because of course the logs are usually smaller at top, may not be round, etc.
/ Lifting Logs
There is also a JD 1520 (1972) with loader, has more HP (around 50 I think) but of course it a larger tractor. Most of the time the tractor will be used for plowing, tilling, gravel work, maybe some dirt. Logs will be a secondary thing and most of the time the logs will be pulled/pushed.
I don't know if I want a tractor as big as the 1520 since it's not as maneuverable for the uses it will mostly be used for, and takes up more room. If someone brought me logs on a trailer I could always just use can't hooks and push them over the edge (how I've been doing it) and the use the tractor to pull them to where I needed.
I am just trying to find the balance between what the tractor will be used for mostly and for instances that will show up only occasionally. If I start getting more logs then maybe I will just have to look at another machine or something.
/ Lifting Logs #14
You could make a ramp out of 2 timbers, each with 1 end leaning against the side of the trailer and the other end on the ground, set wide enough to drive between.
Then you can skid the logs to the ramp, then push them up the timbers onto the trailer. Something like this:
Unloading would involve pulling them off, from the back.
If you have a winch you can parbuckle the logs into the trailer.
/ Lifting Logs #15
This is a helpful post BG. That's what is great about this site and how it shows various methods to solve a problem. This place is like "embryo of ideas" where solutions are eventually born.
/ Lifting Logs #16
Be careful when doing this, if you remove the second tractor all the weight will be on the first obviously, but more importantly you're taking the relief valve out of the picture with the valve in "neutral". What I mean is if the tractor cant lift it without going into relief, placing that same load on the bucket, it may hold it but you could over pressure the system and blow a hose and you might get hurt. I've done this back dragging with my bucket too steep. I hit a something immoveable and with no relief in place the weakest point was the hose(s). Just something to keep in mind.
/ Lifting Logs #17
There is little way for this tractor to lift a 36" diameter 8' white oak at over 3500 lbs wet. You may have a shot at a 24" as this log will be less than half the weight of the 36" one.
/ Lifting Logs
36" would not be the norm but have got them a couple of times, 24" would be more the norm when I did move logs.
Here is a 4020 that is also in the area. (1967) 90hp I think
the 1520 (1972) 50hp
and 4500 (1999) 39hp
the 3010 55-60hp
the 2020 (1970) 54hp around
just remember what I am using it "mostly for"
thanks for all the help and advice.
/ Lifting Logs #19
Smaller 4x4 over larger 2wd any day in my book. If moving a large load with 2wd you will need massive rear ballast to keep the rear tires in traction. Factor in soft muddy ground and the skinny non-driven front tires sink, creating more drag, and unloading the rear tires more.
In my book, loader tractors need mfwd (4x4). The smaller tractor can still move larger logs, just get creative with ramps, chains, and other leverage type mechanical advantages you can add to the mix to compensate.
/ Lifting Logs #20
For loader work you will be much better off with 4WD.
I use my little machine (smaller than the 4020 you posted) for moving dead trees to the burn pile.
This 30 footer was one of the heaviest.
This 40 footer was the tallest.
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2023 John Deere 317G Compact Track Loader Skid Steer (A64553)
2023 John Deere...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
Year: 2014 Make: Chevrolet Model: Equinox Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 134,356 (A64557)
Year: 2014 Make...
