base for gravel
/ base for gravel #21
The one time I had a large load of crusher run delivered to complete our driveway after we moved into our new house and construction traffic was done, I had the driver put it down with the truck. She (a grandma who drives a dump truck and makes big $$) opened the gate and chained it so that it would not open all the way, and then took off down the driveway raising the dump. It worked awesome. I had very little extra work to do with the tractor other than to compact and groom it with a box blade. I think it has to be a good experienced driver, and dry crusher run would certainly help. I can't see it working if it was damp.
An experienced truck driver is a wonderful thing. Years ago the town road crew would spread loads by themselves in mud season and if they stalled and left a pile had to shovel it around by hand so the next tax paying car that came along could get passed it without losing a muffler. Shovel a few yards by hand and you will learn how to do it no shoveling required.
/ base for gravel #22
In these parts with (granite) crusher run...it is always wet (unless in a drought)...the fines hold water...that's why (here) the yield is slightly less than say #57's etc when paying by the ton... But as 's219' related... with a good driver, spreading with the truck does an almost perfect job...usually just have to feather out the starting and stopping points...
Around here a good driver can (by adjusting the gate chain) lay it down as thick or thin as you want it...
/ base for gravel #23
Boy is that the truth. I once shoveled 30 tons of topsoil to spread it, and to this day my wrists have never been right. I occasionally have to shovel 1-2 yards of material out of my trailer into the tractor bucket, and it's not fun. One of these days I will buy a dump trailer. Or just suck it up and pay the haul fee for small deliveries.
/ base for gravel #24
A quarry in NC that sells ABC to DOT is required to maintain the moisture content in the gravel. It has to be within a certain range though. The quarry could rip off the buyer by having soaking wet ABC so there is a standard they are supposed to follow. From buying gravel over the years, the moisture content seems to be the same. I can't measure the moisture level but it always looks the same and spreads the same.
Later,
Dan
/ base for gravel #25
Later,
Dan
Measuring moisture in aggregate is no trick. take a sample of about a pound and weight it on a scale that reads to a single gram. Your wife's diet scale will do. put it in a cake tin and into an oven at 350 until it is totally dry. let it cool then weight it again. The wet weight minus the dry weight gives the moisture content in grams then divide by the wet weight to get the moisture in the sample as a percentage. If you had 1000 grams wet and 900 dry you would have had 100 grams of water and a 10% sample.
An out door stockpile is at the mercy of the weather. Clean sand will normally run about 3% moisture but the day after a good rain it will be 8 to 9 % as the rain water drains down through the pile.
. Concrete plants use sensor probes in the bins to adjust each load for the water in the sand and stone. It is the only way to get consistent results load to load.
If what you produce locally called crusher run holds more then that it has too much dust and clay in it to pass most specifications. Some soft rock sources turn into a very dusty product when crushed that may pack well in the south but would not stand freeze thaw cycles hear in New England.
/ base for gravel #26
Kind of in the same boat here in PA, I laid down a layer of #3 or #4 angular ( Not sure what size it was), no round river rock, as I wanted them to lock together to prevent the vehicles from kicking it out.., then graded it with my York rake.
This is prior to construction, so construction vehicles will compact it.. it will likely require another 15-20 tons of the same after wards, then I'll top with #2 crushed, so it too will interlock with the larger stones and also allow drainage without washout or migration due to vehicle travel.
This was in a clay base as well towards the bottom and middle of this shot, as it was tied into and older drive at the top which seemed compacted.. At the bottom of this shot the old drive was at 90 degrees to the road, I angled it to allow bigger tucks access, and built the wall along the hill and a bigger terraced wall on the other side, so allow an over run for the turn up the hill from the road... The main road is a cul-de-sac, allowing only one way in, so the drive was angled for that access.
You can see the old road in this image, it goes along the upper ride where I angled the stone wall so I could back it if I can't make the hill in the winter..
This is the over run area on the down hill side..
It took me 3 months with my Little BX23 to cut it in, timber, haul stone, stack, grade, regrade, and stone
Getting the house bid tomorrow.. reality check time!
/ base for gravel #27
The muddy part of my driveway that makes ruts looks awfully black, and I suspect it has a lot of organics in it. Can I still put 4" inch crusher run down over top of it as a base?
BTW the soil down deeper is Rocky Sandy.
/ base for gravel #29
You can but it won't last. An inch of topsoil can turn a foot of clean gravel into mud. If you dig out all the organic top soil and replace with good gravel or crushed rock it will last for decades.
/ base for gravel #31
Yes, I kind of figured that, but I am procrastinating because I have to dig it out with my 4' wide, BX25 FEL, and each bucket has to go 200' or so to dump it. Also, there are a lot of rocks, so I have to go thru with the BH first and get rid of them. Work, work, work....
/ base for gravel #32
That's what you bought the tractor for isn't it?:D
/ base for gravel #33
Soooooo, let me see if I got this right:
  • Take some rock from a dump truck and put in the wife's cake pan....
  • Use my wife's scale to weigh said rock...
  • Bake rock, in wife's cake pan, in the wife's oven...
While this technique certainly will work, I am not sure how well the technique will work out for me! :shocked::confused3::D:D:D
The ABC road base in NC is all hard rock, pretty sure granite rock and fines, from the three quarries I have gotten rock. In South FLA the road base was all limestone aka shell rock, that was dredged from lakes. The quarries flooded due to the shallow water table so you have deep lakes and not deep rock pits. :laughing: A few years ago, one of the kid's had a field trip to the local quarry. One of the quarries I used to go to allowed you to get sorta close to the pit but at this quarry I had not seen the hole. Well, we drove down into the pit. The quarry opened up maybe a decade ago but that pit is almost to China! :eek: Unreal how far down it goes. I was talking to one of the employees and it turns out he used to live in the South FLA when I did. He used to work in the shell rock lakes down there before moving up here to work in the quarry.
Later,
Dan
/ base for gravel #34
Well if you don't do the dishes and clean up after your on your own. :D
I used to do these tests in field lab trailers using a hot plate for the heat. Cheap bread loaf pans worked well and a couple would last the life of the project. You could also warm up your lunch on the hot plate using a different pan.:)
If your quarry has a hard rock in it they still need to run the product over a dust screen to make spec material for concrete or pavement aggregate. This gives them quite a pile of dust to dispose of. They sell as much of it as they can mixed with some 3/4 minus stone for driveway dressing. they usually come up with some trade name such as "Hardpak" for it. It is alright for unpaved drives but a spec mixture of 1 1/2" minus stone and clean sand is much better if your going to pave over it.
/ base for gravel #35
The neighbor excavator would have the job half done by the time I would talk the wife into using her pans to cook some gravel.
/ base for gravel #36
Well not everyman can have a beautiful, sweet, charming and obedient wife. :rolleyes: Unless you can convince her it will make "Her driveway" to "HER house" look better and last longer and save "Her money" you might be better off to buy a pan down at the dollar store and dry out your sample on "your grill".
/ base for gravel #37
Here I use what's called 3/4 minus as a top coat, it's aways wet as this keeps the fines from settling out and the drivers never have a problem spreading. On top of that my driveway is so steep and 1/2 mile long that they like to spread it going down hill.
