Belt Style Hay Rake
/ Belt Style Hay Rake #1
bjr
Eastern WA
Jinma JM354
Okay, anyone else seen these rakes advertised. Molon appears to be the only manufacturere of this style. They appear to be two larger Vee belts with tines attached. Does anyone have any experience with these? I'm needing something fairly small and very maneuverable as I'm getting more and more very small local baling jobs (the smallest is 1/4 acres) but it helps pay the bills. These look like something I should consider. I never intended on getting into custom baling, but I've just keep getting referred to because I have the only small baler, mower and tractor in the area. Now I need a small hay rake. My current rake is a very old IH no. 5 with the caster wheels in the back and if you try to go down a paved road (besides being extremely wide) you don't know where the rake going to go. Any input here is appreciated. bjr
/ Belt Style Hay Rake #2
I currently have an old Farendlose belt rake. I am very happy with it considering the small used price I paid for it. A lack of available replacement parts is the down side, which has forced me to start making the few things it has needed since I started using it. Mostly the plastic bushing, tine arm mount that bolts to the v-belt.
Most of my haying is done in small or irregular shaped fields and I find it to be very versatile and also very easy for the tractor to handle. I can only imagine a new one would be as good or better than this old one, plus having a dealer for replacement parts is all the better.
That's where I'm coming from small irregular shaped fields. And sometimes small access gates. I need to be small, quick and nimble with my equipment and narrow enough for highway transport. Are the big vee belts that the tine bars clamp to a standard available belt or are they proprietary to the mower? I'm always buying something that they "just quit" making parts for. I can do some fabrication to keep thing running though. Would tines be a issue or will there be some "will fit" tines available? I'll try to post the a picture of the proposed purchase. Do you recognize the manufacturer? I was told it was a ford, but I can't find any online verification of that. bjr
/ Belt Style Hay Rake #4
Depending on price that looks like it could be a decent rake. It appears to be in better overall condition than mine is. I don't recognize that rake model.
He's asking $1200. It's way down the freeway about 450 miles one way. I'm just apprehensive about the availability of parts as well. I've been looking at the various small rotary rakes too. The rotary's seem to be more plentiful and maybe better parts supply as well. bjr
/ Belt Style Hay Rake #6
Over the years there have been a few different brands of belt rakes in the US. Currently Molon is the only brand available here. As far as parts availability goes, for the Molon rakes all parts are available from Tractor Tools Direct. There is no guarantee Molon parts will work on other brands. In fact, it is unlikely.
Based on how you have described your haymaking needs, and your tractor model, you would probably want the Molon 180, at 7 feet wide. The next larger size is 9 feet, and the next smaller size is 6 feet. Here is a picture of the 180 working in an orchard, where space is very limited.2013-06-23_13-57-15_602.jpg
One thing to note - rotary rakes do a great job, but they will not spread hay, while a belt rake does have that functionality. So if you are in a climate that is humid or has a lot of rain, that can be an important feature.
/ Belt Style Hay Rake #7
My Ferendlose worked well for years in BC where I was working with 9 foot swaths. Brought it to the prairies and it was a different story. 14 foot swaths were too much for it, just dragged over the swath and didn't rake it. Also there were no parts available, and I had to call my original dealer and have him send parts out. Its still parked in the graveyard out back. They are great for 9 foot swaths and if you have a parts source though.
/ Belt Style Hay Rake #9
Hi live ireland and these hay turners are called hay bobs. I think they were made by a company called pz they also made mowers. I don't know if the company exists any more.haybobs were once commonly used but there are few of them to be found now.
/ Belt Style Hay Rake #10
I have the same rake and the same problem...my plastic bushings are starting to crack and fail...how did you remedy or replace?
/ Belt Style Hay Rake #11
Check with us at Tractor Tools Direct. It is possible that Molon uses the same bushings. We will need you to do some measurements and we can check them against our Molon parts. Give us a call after the holiday - 260-225-3429. Many of the belt rake parts can also be found here: Tractor Tools Direct | Product Categories | Molon Parts
/ Belt Style Hay Rake #12
I use an older 3 PT side deliver rake. they are only 7-8' or less wide hoked up (can go through an 8'gate) Works well in tight spaces as long as you plan your turns and the rake swing. Some of the 3pt rotary rakes are also compact and will fit tight spaces too.
/ Belt Style Hay Rake #13
Okay, anyone else seen these rakes . . . I'm needing something fairly small and very maneuverable . . . Now I need a small hay rake. . .
bjr
Have you considered a 3PT hitch wheel rake. No PTO, no belts, and they'll last forever.
If you didn't live on the other side of the country, I have a good used one that I'd make you a deal on.
It's been almost two years ago I posted that question, so, time for a update. I bought a 3 pt. RM-280 rotary rake from Agri-Supply last year. I initially had some problems with a bent wheel spindle/axle. Agri-Supply warrateed it promptly and I was going again. It rakes wonderfully (fluffy windrows and I have manuever around solid set irrigation riser pipes). I also bought a Hesston 4550 centerline baler and it's a dream to pull compared to the old offset baler I used to have. I pretty happy with the haying machinery I have now. But the custumers are thinning out, so, haying is slow. I have a LOT of other projects going on as well so I don't miss haying at all. bjr
/ Belt Style Hay Rake #15
I purchased a block of plastic online and made replacements with a drill press, forstner bits, drill bits and a jig saw. Patience was needed but them came out fine and have held up to thus far. The Molon ones look very close and might be a suitable option.
/ Belt Style Hay Rake #16
Hi, would be able to share the dimensions/measurements of the bushings you manufactured? I recently acquired a Farendlose rake, but the bushings are worn so bad I'm not even sure how to get a good measurement. I was going to see if any of the flanged bushings from this site: igus.ca/wpck/7103/plain_bearing_product_finder would be a suitable fit.
Thanks.
