help w WRLong 3rd function elec over hyd
/ help w WRLong 3rd function elec over hyd #1
JoeL4330
Harpers Ferry WV
Kubota L4330, 6 rear remotes
can any one provide the wiring diagram for the rocker switch-on-joystick to the solenoid body ?
/ help w WRLong 3rd function elec over hyd #2
Here is a picture of the switch from W R Long.
http://www.wrlonginc.com/Spare Parts Photos/KICBEAAAA.jpg
12 v goes to the center terminal, and one solenoid wire goes to the grapple up terminal, and the other solenoid wire goes to the grapple closed terminal.
One wire from each solenoid is tied together and goes to ground.
You might need a fuse in the circuit, but depends on the circuit you use.
/ help w WRLong 3rd function elec over hyd #3
The red wire on the switch is connected to a hot wire
One of the black wires on the switch is connected to one of the black wires on the valve
The other black wire on the switch is connected to the other black wire on the valve.
The valve is internally grounded.
Nelson
/ help w WRLong 3rd function elec over hyd #4
Nelson,
Do you not have a wiring schematic on your web site for the 3rd function and selector diverter valves .
I looked for one.
2009 Ford F550 Flatbed w/ Lift Gate (A62613)
2009 Ford F550...
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
5' Bush Hog (A62613)
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
Woods 72" 3Pt Mower (A66408)
Woods 72" 3Pt...
