? Re: decompression lever & starting
/ ? Re: decompression lever & starting #1
Garycw
Oh-Ky-Fla
JD 1025R w/ fel, Farm Pro 2425, ford 841 & 851
I'm new to diesel & just bought my first Farm Pro 2425. I'm a little confused about the decompression lever coming out the lower center dash. What is its primary use? Will it run with lever in decompress ? Does it return to normal when started or manual return. I've not turned this and tractor starts fine.
/ ? Re: decompression lever & starting #2
The decompression lever allows the engine to turn without the pistons developing any compression. The engine won't run with the lever in decompress. It makes starting easier on the engine by allowing you to get oil pressure up before starting. It makes starting easier on the starter and battery by reducing the torque needed to get the engine moving.
Here's how I start a cold engine:
1. Turn decompress lever.
2. Turn key.
3. Let starter run until oil light goes off.
4. Release decompress lever but keep starter on. Engine should start.
/ ? Re: decompression lever & starting #3
+1, easier on the starter and bearings...
Should this be used even in warm weather? And / or when engine is warm?
/ ? Re: decompression lever & starting #5
Although not the same model and make of tractor mine starts without issue to date (knock on something) where I have found the compression release extremely useful when I was new to it was when I forgot to disengage the kill switch and tried to start.. This would often take me a second to understand the guy in the seat was the problem and get a real rich mixture in the cylinders.. This made it very hard to start once I pushed in the kill switch so I would like said above throw the compression release and spin it for awhile to help clear the cylinders and allow it to turn faster for start.
/ ? Re: decompression lever & starting #6
I use it on every start, warm or cold, no starter issues, and still using the 2005 chinese battery that came with the tractor... It's bigest advantage IMO is that it allows oil pressure to build in the crank before you apply the compression loads to the rod bearings...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2017 CHEVROLET 5500XD S/A BOX TRUCK (A59914)
2017 CHEVROLET...
3142 (A63117)
3142 (A63117)
2019 HINO 195 18FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 HINO 195 18FT...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
