Weird Battery Failure
/ Weird Battery Failure #1
mswlogo
Gold Member
NH, USA
Kubota B2320 DT (Gear)
I just got my tractor back from dealer installing rear remotes and replacing hydro fluid.
I used it for like 1/2 hr spot fixing the road and moving trailer/boat around.
I then went to go hook up the new implement that I got the hydraulic remotes for.
I must have started it 10 times already.
Get the implement all hooked up and go to start and nuttin. I thought for sure it was some interlock it was not.
Flasher just buzzed on and off with no lights.
So I pulled the battery and put it on a charger. The Green Eye was Green.
The Charger thought the battery was charged.
I temporarily hooked up a boat battery and it started right up.
Hmmm, did dealer break my alternator?
So after a few hours on charger I hooked a heavy duty lantern to it. It was real dim. Then it Went bright and then dim again. When it was dim I could hear the battery gurgling.
The battery just crapped out instantly.
Do these batteries typically fail like this?
I think the battery is like 5 years old. with VERY low hours.
Can any recommend good sources for batteries? Besides the dealer.
/ Weird Battery Failure #2
5 years is all I get out my batteries. I think you may have been ready for a new battery no matter what the dealer did.
/ Weird Battery Failure #3
For many years we bought DieHard Gold batteries. Last year the two year old DieHard Gold battery failed in her pickup. Dead cell. Yes they can fail that quickly. All $200.00 worth.
/ Weird Battery Failure #4
If you get 5 years out of battery your doing well. I have had batterys test good and still be the problem. prorated warranties usually only help for about a year. In fl. the first good cold spell gets more batterys than anything else
/ Weird Battery Failure #5
Yup, it happens. With the lack of shock absorbers on tractors, the batteries take a beating. What you describe sounds like a plate broke loose! If you want the best go with an Optima Yellow or red. They are glass mat and can take a real beating,
/ Weird Battery Failure #6
My batteries normal life is 5-7 years. I've been tempted to get an Odyssey AGM battery. They advertise 3X life span - they are 2X the normal price also. I had a gel cell that lasted eleven years. I always keep an extra fully charged battery around - you never can tell when the tractor battery will crap out. The "green eye" is only good if you are into wizardly stuff.
/ Weird Battery Failure #7
Batteries can do weird things...5 years is the average life of most batteries in equipment I've owned.
I had a car battery when I was in college that refused to start the car on Mondays. Rest of the week it started great LOL
/ Weird Battery Failure #8
that green eye only ties to one cell ... and shows the fluid level and specific gravity for that one cell .... ( just a float in side a green yellow and black tube ) 5 cells can be bad and the green eye will still show OK ....
/ Weird Battery Failure #10
Get an Interstate battery of the correct size and CCA for your application. I was a dealer for them when I owned my foreign auto shop, years ago. Have selling dealer verify date of manufacturering from code stamped into case of battery by factory to verify fresh stock.
I have two in my boat, 1 in each of 4 Toyotas, 1 in my Scag, ATV, Dr. Mower and Dr. mower trimmer. You don't need AGMs in a tractor, especially for the price. Lack of use is as detrimental to life of any battery, regardless of brand.
/ Weird Battery Failure #11
If you want to get more years out of a battery, try keeping it hooked up to a battery tender when it is not being used.
On my Corvette, which sits about 364 1/2 days per year, the first one lasted 4 years.
After replacing that one, and adding a battery tender, the next one lasted 19 years.
Now I have one on every vehicle I own, all five of them, plus my Kubota.
If it isn,t being used, it is plugged in.
I,m a believer.
/ Weird Battery Failure #12
This is caused by a cracked or corroded thru conductor between two of the cells in the battery. Its a fairly unusual failure. I have only had 2 fail that way. Both strong young batteries - then suddenly they would not put out current. A meter says 12.6V no load. Instrument lights come on bright and will burn all day. But try to pull more power and the voltage crumples because the broken connection wont conduct it.
,,,,Its actually a dangerous condition because sparks can occur at the break and could ignite the H and O2 evolved from the acid during the latter stage of charging. Trade it in pronto. Costco has good car batteries - long warranty. More power available in car batteries size for size. You might be able to find one that fits.
larry
/ Weird Battery Failure #13
my tractor is a 2005 and still have the same battery and got 500hr on it but i put a slow charger on it every 3 month it might let me go this winter
After googling around it seems it's a few folks with this tractor had a similar failure.
Starts one minute and little while later it's dead. Reads good until you put load.
I agree 5 years is good. I don't think a battery tender would have stopped this particular failure.
Mini Skid Steer (A60352)
Mini Skid Steer...
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
Chery 21'x24' Double Carport (A64127)
Chery 21'x24'...
2016 Ford F-350 Pickup Truck (A62613)
2016 Ford F-350...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
